Old 12-05-2020, 09:59 PM #46
Sagi28 Sagi28 is offline
Sagi28 is on a distinguished road
Originally Posted by Engineer View Post
Just finished installing this on my wife's 4Runner so I figured I would grab you a couple side shots etc. Not to hijack this thread as its not an install thread but wanted to give some comments as I went into this "blind" - took me about 4 hours over 2 days. Note a couple of the side shots do not show the black back cover installed - you can not see the silver mounting rails and screws with the cover on (photo #3)
*I think the OPs photos make this head unit look a little more "tucked" to the dash then it actually is, I don't think it looks bad installed and prefer this to the T8/T9 or Alpine options from a visual standpoint but it is still and always will be "tablet on the dash"
*There are a lot of parts to move over from the OEM headunit to the Metra dash kit - the vents, vent adjusters and emergency flashers - this likely comes to no surprise to anyone who did an ounce of research but like I said above - I thought it looked good, was tired of the OEM radio locking up and it was something the wife wanted for Christmas so I went to Crutchfield , ordered the kit and winged the install (the directions are terrible imho)
*This does block just a bit of the vents even in the lowest setting, I think the 10" would look far to big but to each there own
*There is a RATS NEST of wires now, I assume this is standard with aftermarket Headunits but as this was my first install I was shocked how many wires, dongles, adapters it takes to do this - its not what I would call "clean" but I think it is what it is in this world.
*You have to flash the Idatalink Meastro RR - was easy but did not realize I would have to do that going into this
*The metra dash kit black matches very well with factory paint, no would would notice imho
*I did not reuse the OEM mounts even though I did grind off the alignment "knobs" - the Metra/Pioneer mounts seem solid enough but I kept the OEM incase I change my mind
*I tucked the GPS receiver behind the unit, not sure if you are supposed to do this but the signal strength said "ok" after install and it appears to work - does not matter much to me as we will be using Apple Car Play 99% of the time
*Overall the install was not to bad but its very intimidating the amount of wires/adpters/connections - I did not find the IdataLink or Crutchfield instructions all that clear as far was what gets used and what does not so is was a bit trial and error
*Wired and Wireless Carplay seems to work fine - I will be installing a wireless charger under the lower cubby in the dash so we can just place phones there and charge/Wireless Carplay
*As the OP mentioned the OEM backup camera appears pretty grainy on the screen (cameras fault not the Unit) - I think it looks worse in person then the photo I attached shows.
*I have not had a chance to play with settings so it might be changeable but only have 4 icons across on the screen makes them "large and in your face" imho
Appreciate this! Helps a lot with the decision!
Sagi28 is offline   Reply With QuoteReply With Quote
Old 12-05-2020, 10:03 PM #47
Wonder if you can get it to go lower and not block vents if you put the pocket on top and head unit at the bottom?
Would the heater against the screen not be good over time?
Old 12-06-2020, 12:05 AM #48
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
lol my Alpine Halo sits WAY closer to the dash than that. I have no visible screws, just sayin
Old 12-06-2020, 09:56 AM #49
Engineer's Avatar
Engineer Engineer is offline
Real Name: Charles
Engineer has a spectacular aura about Engineer has a spectacular aura about
Engineer's Avatar
Real Name: Charles
OMG no way? Thats so awesome! - How about you give us some measurements and photos so others can follow in your footsteps or maybe read the post fully where it says the screws are shown because the cover is not on.....
This place really has gone to shit and sad to see you have gone along with it
2014 Trail Edition Premium, 285/70/R17 BFG KM2, RadFlo 2.5" Coilovers and Rear Shocks, 50qt ARB Fridge, OTRATTW Switches, BudBuilt Bumpout Sliders, Gobi Rack + Ladder / 40" Rigid E2 /Rotopax and MaxTrax mounted, ARB CKMTA12, 270amp Alternator, Southern Style Slimline Hybrid Front Bumper w/ Warn Zeon 10S and Front Fogs, Metal Oil Canister, Sound Deadening Insulation w/ Focal Front Speakers,Black Weather Tech mats and custom pin striping & dents (the trees & bushes did it for free)
Engineer is offline   Reply With QuoteReply With Quote
Old 12-06-2020, 10:00 AM #50
Engineer's Avatar
Real Name: Charles
Engineer's Avatar
Real Name: Charles
I don't think it can go any lower as I am on the lowest mount setting. I don't think its blocking enough of the vents to cause issue with the screen - but I guess only time will tell. Luckily its winter so hopefully if an issue would arise It will happen within the warranty/return period.
Its certainly not the perfect option but while many seem to not have issues I was not willing to gamble on the T8/T9 Clones as the main reason we did this was the bugginess of the factory units and neither of us liked the blank space left by double Din units on either side so a floating head unit It was......So far liking it more and more as I have had a chance to play with the brightness and color settings along with some of the other functions (gauges, setting Quicklinks etc)
Old 12-06-2020, 06:18 PM #51
Agreed! T9 is a waste of $$ according to many YouTube reviewers. I’ve always liked the sound quality of pioneer over the alpine IMO. The only problem I would have is the screen will slightly block my lcd heater control unit. I have the limited version.
Old 12-06-2020, 11:18 PM #52
Real Name: Chris
Real Name: Chris
Old 01-05-2021, 09:50 PM #53
arouth arouth is offline
arouth is on a distinguished road
Spent a bit of time reviewing this thread and have a few questions. After reviewing the various options out there this seems to be my top choice to replace the Etune Radio in my 2015 Trail.
1. SiriusXM Radio Presets: Does it skip b/w presets with the SiriusXM tuner or just go from like channel 20 to channel 21.
2. Screen dimming at night: I saw one post that said it didn’t dim properly at night. Another that it did and that the lights on the left side were still on but not overly bright. Just thought I’d ask on that one since I’ve had a radio that did not dim properly.
3. Navigation- Confirm there is no stock navigation with the radio? It looks like it’s just Carplay or Android Auto.
Thanks!
2015 4Runner Trail Edition Premium, Red, KDSS
(Sold) 2004 4Runner Sport Edition, V8, AWD, Silver
arouth is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 07:35 PM #54
utctscanr75's Avatar
utctscanr75 utctscanr75 is offline
Real Name: Bird Dog Overland
utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light
Used the print outs off of Crutchfield to compare the the 8600 vs the 7600 vs my installed 8400 (7”) from the driver’s seat. While the 10” is nice, I’m leaning more towards the 9” to keep from blocking the vents and HVAC knobs.
utctscanr75 is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 05:40 PM #55
jppower's Avatar
jppower jppower is offline
jppower is on a distinguished road
jppower's Avatar
Just installed the Kenwood equivalent of this last Sunday with this dash kit. 2 days later it was stolen and all they had to do was pull because it is secured with just the tabs to the dash. I will be replacing it and its probably a good idea to figure a way to reuse the oem brackets and maybe use security bolts.
Does anyone know if the Scosche kit bolts to the factory locations?
jppower is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 07:41 PM #56
rhadam's Avatar
rhadam rhadam is offline
rhadam has a spectacular aura about rhadam has a spectacular aura about
rhadam's Avatar
Had no idea Pioneer had this unit out.. I guess I should have done more research. Currently having a bit of buyers remorse as I just installed the Halo9 last week and my biggest gripe is the 480P screen. I don't notice as much washout on maps as others have mentioned.. but the opportunity to have a higher resolution screen would be a blessing. Seriously considering ripping out the Halo9 and sending back to Crutchfield and installing this Pioneer. Decisions decisions...
2017 T4R OR Super White
RRW RR4-V bronze wheels, Diode Dynamics SS3 Fog + Ditch, C4 Fab Lo Pro Winch Bumper + Smittybilt 10k synthetic, UpTop Overland Bravo Roof Rack
Dobinson's full suspension 2.5" front 1.5" rear - Dobinson's UCA - DirtKing LCA
Kenwood eXcelon 10.1 headunit + Kenwood speakers
rhadam is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 08:18 PM #57
jppower's Avatar
jppower's Avatar
Originally Posted by cmoekim View Post
Here's a pic of the OEM brackets used in conjunction with the plastic Metra ones. You may need to drill out or grind down some alignment nibs so they sit flush. I decided to use both together because I wanted to keep the ability to reinstall/remove as a single assembly like OEM. I have a standard double DIN and don't have any direct experience with the newer floating style head units, but it looks to me like the best course of action may be to install the chassis first reusing the OEM brackets and skipping the metra ones all together, install the trim piece over the chassis, then mount the floating display last.
Any reason not to just skip the metra brackets?
Old 03-05-2021, 05:35 PM #58
Deimos Deimos is offline
Deimos will become famous soon enough
Haven't logged on in awhile. I recently installed the ICS bracket, so while the bezel was off, I trashed the metra bracket and used the OEM bracket after a little bit of drilling. Works way better now.
Occasionally the unit does not want to connect to my iphone, turns out it was just my cable. So I replaced that.
I updated the firmware on it finally, but had to go the long route (downloading to a USB stick and uploading via the USB port). The Pioneer iOS app to do this is useless. Note, there was a recent firmware update on 2/12/21, I've yet to install that one. This solves some connectivity issues others have been having on Android Auto (I don't use that).
Deimos is offline   Reply With QuoteReply With Quote
Old 03-05-2021, 06:11 PM #59
Whippersnapper02's Avatar
The only thing really holding me back from purchasing is connectivity issues. My current Pioneer Avic 8000NEX has been a pain in the ass since new in 2014. It wont respond to steering wheel control track skipping or even direct headunit skipping at times. I get resetting and complete loss of any control or connectivity at times. I don't want a repeat of it.
Old 03-05-2021, 07:16 PM #60
umidkusername umidkusername is offline
umidkusername will become famous soon enough
out of curiosity, when you bought the different pieces did they say they weren't compatible with your vehicle?
I don't know about the 2019, but in the 2020 Pro with the JBL stuff, there is no kit. If you go to Crutchfield they recommend you don't mess with anything. I wonder if there's a sharp difference between your edition and the 2020 Pro. I would imagine it can't be that much different.
umidkusername is offline   Reply With QuoteReply With Quote
display , dmh-wt7600nex , floating , installed , pioneer
New Pioneer floating head unit - anyone tried this? MillerPKA 5th gen T4Rs 47 04-12-2022 02:43 PM
XPEL Clear Bra Installed - Impressions WTERUNNER 5th gen T4Rs 19 09-17-2018 12:41 PM
FS: WA - JL Audio 500/1 and Pioneer 8" sub in box toomuch50 For Sale: Non-T4R Items 1 06-07-2014 12:44 AM
audio display on????? baldilox 5th gen T4Rs 6 09-26-2013 09:59 PM
Ultra-Gauge installed: First impressions... Martinjmpr 3rd gen T4Rs 11 12-27-2010 07:30 PM
