Old 06-11-2020, 09:14 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
When can I switch into 4HI?
I've got the 2020 TRD Off-road and I've read the features outlined over on trail4runner and other places, but I almost get a bit scared where it seems:
1) You should try to "regularly" drive in 4HI for a bit to keep everything working well
2) You should absolutely not use 4HI on dry pavement and risk damage.
So.. what's sort of the baseline for safely using 4HI? Can you use it on a road when it's actively raining, even if the pavement isn't pooling any water?
What level of "non-pavement" can you use it on? For example, there is this pretty well maintained service road:
It's not pavement, but is generally in pretty good condition. But there could be gravely spots, definitely some potholes, yeah...
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 09:45 PM #2
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Hey there and Welcome! You really don't need 4Hi in the rain on pavement, snow and ice you might need it. You can still create binding in the 4x4 system when turning sharply even in the rain, and the traction control in these vehicles will help quite a bit on wet roads in 2wd anyway.
The gravely road you pictured might be ok for going slowly on in 4Hi as long as your not taking sharp turns. Now that same road in a heavy rain is where you would want to use it.
Using your 4x4 system definitely needs to be done several times a year to keep everything working properly for years to come.
What I've been doing recently since I haven't been able to get out to the trails lately, is heading over to a road by my house that is not heavily traveled, and has a good dirt and grass shoulder off to the side. I will engage the 4x4 and just slowly drive the shoulder for a mile or so and turn around without getting on the pavement just drive back down the shoulder. I might do this 5 or 6 times, basically looking like an idiot, but I'm exercising my systems. Because you have an Offroad model, this will include both your 4Hi and 4Lo systems as well as your locking differential in the rear axle. If you can alternate the hi and lo system a few times and lock in the differential as well, this is good for the servo motors and the systems that engage the gears. Think of the servo motors like an electric window motor that never gets used. Eventually it will not work correctly from corrosion and sitting around too much. Doing this every couple a months will keep them working properly. But, I highly encourage you to get out there off road on some trails and use your truck like it was designed to do. It's a blast! Hope this helps and Good Luck!!
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 09:52 PM #3
M22's Avatar
M22 M22 is offline
M22 is on a distinguished road
M22 M22 is offline
M22's Avatar
So as far as the routine of using 4hi for just getting things moving and lubricated it is ok to use on wet pavement and best just to use when you can exercise it on relatively straight stretch of road the less turns the better and for sure no sharp turns. Service roads such as loose gravel and dirt it is probably ok for 4hi, if it’s needed. Basically, if it’s dry and there is too much traction you won’t need 4hi anyway but if you have it in 4hi and there is too much traction you will get binding and you will feel it when the 4wd is unhappy for sure. No need to worry too much it’s a fairly robust drivetrain that can take quite a bit of abuse so if you hear feel it binding simply put it back in 2wd.
M22 is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 10:03 PM #4
cmilviper's Avatar
cmilviper cmilviper is offline
cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice cmilviper is just really nice
cmilviper's Avatar
If it's been a while since I hit the trail, I would not hesitate to put it in 4-HI, on a relatively straight stretch of dry pavement.......I do it all the time, no problems.
As stated above.... a long as you are not making sharp, parking lot, like turns in 4wd, on pavement....you'll be fine.
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
cmilviper is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 10:31 PM #5
Okay thanks guys, it's easy to get overwhelmed when some of this stuff is new to you and there are official and anecdotal warnings everywhere!
Old 06-11-2020, 10:33 PM #6
Zjbond Zjbond is offline
Zjbond is on a distinguished road
I was just thinking this same thing as the OP. I too just got a 2020 ORP. Not sure when I will be able to hit some trails. Straight stretch of road on 4hi is no problem. Can the same be done for 4lo at slow speeds on pavement? What's an ideal frequency to keep things optimal?
Sent from my Pixel 4 XL using Tapatalk
Zjbond is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 11:08 PM #7
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Many of us have forgotten to shift from 4wd to 2wd when back on pavement.
It's undesirable, but not the end of the world. The steering will feel heavy and a little vague, and when making sharp turns, you will hear the tires scrub.
So don't do it, but don't worry about it if and when you do it.
delloro is offline   Reply With QuoteReply With Quote
Old 06-11-2020, 11:48 PM #8
Whippersnapper02's Avatar
Straight, dry roads are fine. Just remember to disengage it when you need to turn because it will feel like your Runner is broken as the driveline binds up. I do this a couple of times a month without issues. I also select low range on empty back streets and exercise the locker. Just get it to where it locks in and you can just unlock and lock it on the spot. I don't always have time to get to a dirt road for this.
I also used to 1/8th mile drag race my supercharged Tacoma in 4wd. No issues ever.
4hi , bit , pavement , pretty , road
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 11 10-23-2021 03:51 PM
Dome light switch assembly... after market switch? giguchan 3rd gen T4Rs 2 12-03-2017 04:59 PM
FS,BNIB: Switch-Pros 8100 Switch Panel PAKM4N For Sale: T4R Items 2 12-28-2016 05:14 PM
Stupid question. Seat heat switch light. How do you remove the switch? Gavin S. 4th Gen T4Rs 6 02-15-2016 02:02 PM
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
