06-11-2020, 11:52 PM
Yet another Icon squeaking thread...
I've searched around and haven't found any answers that apply to me, so I figured I'd post my own.
I've lowered the LCA on a jackstand and the only vibration I feel from the noise is on the lower arm of the shock, I'm thinking I maybe busted a seal and lost oil? Not sure, working with Icon support told me to buy Silicon lube but hasn't responded with anything else.
Steps taken:
1. Silicon Lube all the moving parts and lower shock link to the UCA
2. Tighten Skid plates to spec
3. Confirm torque of LCA bolts, Lower arm to LCA bolt
4. Check SPC LT UCA grease + tighten UCA bolt
Video 1: YouTube
Video 2: YouTube
Video 3: YouTube
Yes, it's loud, and it's gotten louder lately. So loud my neighbors and people in the parking lot look over. It's my daily driver and it's driving me crazy.
@offRoadxp | 2019 4Runner TRDO ⁌ RSG Rock Sliders ⁌ RCI Skid Plates ⁌ ICON Stage 2 Extended Travel w/ SPC UCAs ⁌ ICON Rebound Wheels ⁌ 285/75/17 Yokohama Geolandar G003s ⁌ Prinsu Full Roof Rack ⁌ FSR Evolution RTT ⁌ SSO Offroad Bumper w/ Smittybilt 12k Winch
06-12-2020, 01:14 AM
ICON Coilover Lower Mount Replacement Bearing Kit
I had the same noise, spray down the bearings the best you can with some silicone grease and give the truck a shake. If the noise stops, then you'll have confirmed its the bearings. Mine were completely broken
06-12-2020, 01:24 AM
Damn, I've sprayed everything except for the bearing as I didn't want to wear any components down with silicon. I've had these on for 6 months so I hope they aren't already shot!
Having said that I'm hoping Icon responds with something other than "Silicon lube". Have you had this issue again since you've replaced them?
Edit: Actually the lower arm bolt I've sprayed around quite a bit. Did you have to take it apart to get the bearing lubed? I've soaked this thing in silicon lube at this point.
06-12-2020, 01:56 AM
Nope!
I talked to the guys at metal tech and they actually told me about this bearing noise issue, which is apprently common with icons, but not a well known fix ( if that makes sense).
So to test their suggestion I saturated both sides of the bearings with silicon spray and the noise stopped instantly. The noise would stop for about 1-2 days in the summer after spraying.
So i ended up ordering the bearing kit and had to pull out my coil overs and replace the bearings as my old ones were completely rusted out and in pieces.
Hope that helps
06-12-2020, 02:32 AM
I had a similar noise on my wife's 4Runner a while back, and thought it was the UCA. I had been all up and down the suspension, greased the UCA ect/the vibration of the noise even felt like it was coming from the UCA....
I tried spraying some lubricant around the sway bar mounts and up under the skid plate/where the the sway bar runs across.....and the noise hasn't been back since....It's worth a try to narrow it down.....
2017 4Runner TRD Pro - Cement Icon RR CDCV (700 lb) w/ Icon Delta Joint UCA's/Billet Rear Link Arms || Icon Overland 3'' Rear Springs+Dobinson's 15mm spacers on top || C4 Fab Sliders || CBI Front Bumper || Shrockworks Rear Bumper || Gobi Stealth Rack/Ladder || Baja Designs & Rigid Lighting || 285/75r17 Toyo MT's (34") || Safari Snorkel || ARB Diff. Breather Kit || Spidertrax || ARB Awning 2000 || Maxtrax || XD Philips 4300K HID's || Warn Winch/Factor 55 || IKamper Skycamp 2.0 4X || SCS Ray10's || Durobumps
2015 4Runner TRD Pro - Super White (Wife's) Icon Stage 2 w/ Icon UCA's || Toytec Superflex HD Rear Springs || Expedition One Sliders || 285/70r17 BFG KO2's || Gobi Stealth Rack/Ladder || 40" Rigid Radiance || Spidertrax || XD Philips 4300K HID's || Philips Yellow LED Fogs
06-12-2020, 06:13 PM
Steps taken:
Video 1: YouTube
Video 2: YouTube
Video 3: YouTube
It’s 100% your spherical bearings either the top or lower one on that particular coilover. I have the exact same noise and just waiting for my new KING coilovers before I pull my Icons off the truck.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
06-12-2020, 06:14 PM
A shame you only got 6 months out of yours. Mine lasted about 2.5 years and 40,000 mi. A good chunk of them off-road
06-12-2020, 06:27 PM
yeah it seems like a bearing, I was hoping Icon would honor a warranty since it's so new but it appears that getting a response from them other than "buy silicon lube" is near impossible. I'll keep calling I guess...
06-12-2020, 06:37 PM
I would remove your coilover and see if there is any play in both those bearings. It’s actually pretty cheap and easy to replace them
06-12-2020, 07:42 PM
I have a intermittent squeak as well.
It can happen one time then when I park and go again its completely gone. I'd always thought it was the UCA bushings so I kept re-greasing them and noise went away for a bit. Now I'm thinking it might just be me dropping the suspension a bit to get in there which was the temp fix.
Do I need a special press or anything for this bearing kit?
2018 TRD OFF ROAD
My Build
06-28-2020, 10:00 PM
You guys are awesome, I finally got a hold of Icon support on the phone and got them to send me a bearing. 20 minutes to get the shock off.. ended up having to go to harbor freight and get one of their presses... pressed that sucker out and pressed the new one in and BOOM no more noise! Took maybe an hour total.
Ended up following this guide to get the clips in and help navigate pressing the bearing in/out. Wasn't too bad.
All in all, I hope this isn't an issue I face regularly considering it's been only 6 months. However it's not too bad to replace.
Check out the movement on the old bearing, the new one barely moved!
06-29-2020, 09:34 AM
Which press did you get from HF? I might need to do this real soon along with a full service of the shock.
2015 Super White TRDP - Shrockworks, Gobi, ICON, SPC, Auroa LED, Dobinson
06-29-2020, 05:31 PM
This is the one I ended up getting, maybe overkill but it made things way easier.
07-02-2020, 11:03 PM
A socket and hammer work better than a press. Best price on the COM10T bearings is from Summit Racing. I think I have replaced my Icon lower bearings at least 10-12 times.
That looks a lot like my write up
Icon Shock Rebuild
07-02-2020, 11:06 PM
I have been reading a lot of bad things iCon...
