Old 06-12-2020, 02:05 AM #1
Run Forrest Run's Avatar
Run Forrest Run Run Forrest Run is offline
Run Forrest Run will become famous soon enough
Ironman 4x4 Nitro Stage 2 Lift
I spent months reading and learning lift options & variables for my new 5th gen. This is a daily driver that will be on road 95% of the time. I knew I wanted a suspension vs spacer lift. On the short list was Wheelers 5100/T1/T13, Bilstein w/ OME 885/895E and Ironman 4x4 Foam Cell Pro. I planned on SPC UCAs Budget for parts was @ $1800.
After a ton of research, I was ready to jump on the Ironman. I called to ask a few questions about spring options and Luke was quick to suggest I save my money and go with the Nitro kit. This was based solely on how little I will be off road and the conditions I am in on logging roads in the Northwest. Foam Cell Pro would have been overkill.
Luke suggested Performance springs & told me to expect 2.5” lift front and rear. At $1299 on sale with UCA and assembly, price was great.
Here’s The specs on my kit:
Front Coil Springs - TOYO55B, 0-110 lbs, 380mm, 669 lb/in, 17 mm
Rear Coil Springs - TOYO56B, 0-660 lbs, 395mm, 280 lb/in, 17 mm
12710GR Front Struts, Nitro Gas -
12682GRC Rear Shock Absorber - Nitro Gas -
UCA001FA - Front Pro Forge Upper Control Arms
Before measurements center hub to fender with a full tank:
DF 19.5”
PF 19.875”
DR 21.5”
PR 21.75”
I did have them add a 5mm (.2”) spacer beneath the DF coil seat for a .4” compensation for lean.
Kit came today and it took me 6 hours for a solo install. Ironman GX460 Facebook video was a great help. Everything went smooth and I’m extremely satisfied with the result. Here are my new measurements after a test drive and @ .5” settling up front:
DF 22.5” +3”
PF 22.75” +2.875”
DR 24” +2.5”
PR 24” +2.25”
Will be letting it settle, then plan on an alignment and some new shoes. At the moment Im very happy with the results & recommend it highly.
Update: Added images of before lift with Bridgestone 265’s and after with BFG KO2 285’s
Ironman 4x4 Nitro Stage 2 Lift-d334505e-9a4e-4e2a-8c2c-d156dc9e161c-jpg  Ironman 4x4 Nitro Stage 2 Lift-f3d95733-8a14-4dcd-91a6-25ee63dc2d05-jpg  Ironman 4x4 Nitro Stage 2 Lift-eab5123e-4dac-4d01-93c9-ed724b79505c-jpg  Ironman 4x4 Nitro Stage 2 Lift-d8430fe5-56f7-4e03-a689-f822be749e9d-jpg  Ironman 4x4 Nitro Stage 2 Lift-6fed6faf-4b01-41c5-a9ec-4d5de855aa95-jpg  Ironman 4x4 Nitro Stage 2 Lift-0f2177a4-47d8-418d-86c6-950d2cd13c3b-jpg
2023 TRD OR, Lunar Rock
Run Forrest Run is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 07:49 AM #2
Dinosaur Overland's Avatar
Dinosaur Overland Dinosaur Overland is offline
Dinosaur Overland is on a distinguished road
Thanks for the review I plan to pull the plug shortly on this lift also.
Dinosaur Overland is offline   Reply With QuoteReply With Quote
Old 06-12-2020, 05:01 PM #3
Dreaddy72 Dreaddy72 is offline
Dreaddy72 is on a distinguished road
Looking good bro, hopefully my kit will be here in a couple weeks
Dreaddy72 is offline   Reply With QuoteReply With Quote
Old 06-13-2020, 08:34 PM #4
DAY 3 Update and Alignment:
I have about 50 road miles on the lift.
No additional settling noted after the first day measurements.
My opinion: The ride feels tight in a good way. Braking feels better, probably because of the reduced dive. Cornering feels sportier and more planted. Nice difference felt going over speed bumps- no second bounce like I felt with OEM.
Went to local shop assuming it should be simple with the new UCA‘a. I requested caster between 3.8-4.2. Tech worked diligently for 2.5 hours but it was obvious didn’t have experience with lifted Toyota’s. I should have asked about this before taking it in. Great guys and they were honest. End result is that all is in spec, but they couldn’t get Caster above 3.0 on drivers side and 2.8 on passenger. It drives great though. Think I will drive it for a few thousand miles then align again elsewhere when I get new shoes....if I can hold out that long.
Old 06-14-2020, 12:29 AM #5
Dam that's wack. I will be good if I can keep my current readylift height, but if not I got an idea
Old 06-14-2020, 09:39 AM #6
I ordered a stage 3 Nitros for our 2019 4runner. Really looking forward to it arriving.
Old 06-14-2020, 09:50 AM #7
Originally Posted by Dinosaur Overland View Post
I ordered a stage 3 for our 2019 4runner. Really looking forward to it arriving.
Nice, looks like a few of us on here will be running these kits. So far all good reviews. Did you order the foam cells or nitro? I went with nitro because mine is a daily driver and I dont need a full offroad set up. Hope you used the code.
Old 06-14-2020, 10:56 AM #8
Chris @ Ironman actually recommended the Nitros after we talked about how we use the 4Runner. So that is what I ordered!
Old 06-14-2020, 10:41 PM #9
Day Four update:
Went back and got a refund on yesterday’s alignment- Going to make some calls and find a pro to do it right this week.
Washed and detailed today, so it will definitely rain tonight in Eugene...
Took some measurements- no setting since day one. Also took frame to ground measurements. Very interesting to see that a 1.25”-1.5” rake measured from center hub to fender visually looks like a good rake. Measuring from ground to bottom of frame, I only have a .375” rake. So glad I didn’t go with a shorter spring/smaller lift in the rear.
Full Tank of gas, center hub to fender:
DF 22.5” +3”
PF 22.75” +2.875”
DR 24” +2.5”
PR 24” +2.25”
Frame to ground:
DF 16”
PF 16”
DR 16.375”
PR 16.375”
Center Skid Protector- 12.375”
Ironman 4x4 Nitro Stage 2 Lift-e53a6465-a0b8-4070-93f8-47828a74968e-jpg
Old 06-20-2020, 09:03 PM #10
Found a local off road shop that dialed in my alignment this week- Caster is now at 4* and all else is in spec.
Installed BFG KO2 285/70R17 in load range C. Had some rubbing at full lock on incline, so removed front mud flap, pushed front fender liner forward and trimmed the bumper. Was a little nervous to do this...after some reading, was a simple job. Well worth the work to fit these tires. Clearance looks good now and the stance is exactly what I was wanting. Will report back after some more miles.
Ironman 4x4 Nitro Stage 2 Lift-e76af5f6-9208-4656-b8ec-6dc7d8ed9d33-jpg  Ironman 4x4 Nitro Stage 2 Lift-e7614a26-5e02-42f0-a8f6-1341566f208e-jpg  Ironman 4x4 Nitro Stage 2 Lift-690570ca-c76b-4f7e-af92-7538bf4c075a-jpg
Old 06-20-2020, 09:50 PM #11
Dope, glad u got ur tires to fit. I have ko2's too, same size. Hope I dont have to do more trimming when my kit gets here
Old 06-20-2020, 10:39 PM #12
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
Looks good.
Congrats.
shrub1 is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 10:05 PM #13
dirtydurley's Avatar
dirtydurley dirtydurley is offline
Real Name: Ryan
dirtydurley is on a distinguished road
Real Name: Ryan
Looks good!!
dirtydurley is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 07:46 AM #14
Have you noticed how the lift and larger tires effected your fuel mileage? I ask because this is the same setup we will be using
Old 06-22-2020, 08:05 AM #15
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
Installed BFG KO2 285/70R17 in load range C. Had some rubbing at full lock on incline, [...]
So you still had back rubbing with a 4* Caster on 285s? I have Falken AT3W on 285s E with OEM UCAs and it makes me thinking if indeed the Ironman UCAs will perform... hmmm
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
front , ironman , kit , lift , nitro
Ironman 4x4 Lift r3apingcha0s 5th gen T4Rs 32 03-26-2021 12:09 AM
Ironman 4x4 lift Gstick 5th gen T4Rs 8 08-15-2020 08:54 AM
FS: ironman 2" nitro gas suspension kit for 4g T4R and GX470 BNIB Atlanta, GA Bar4x4 For Sale: Suspension/Wheels/Tires 3 03-14-2020 07:39 PM
Ironman 4x4 lift MandAtaco 4th Gen T4Rs 2 07-13-2013 11:35 AM
Ironman lift and DDM hi/low kit for sale cj80cruiser 3rd gen T4Rs 6 02-02-2011 12:15 AM
