Old 06-13-2020, 08:49 PM #1
DreamsOfDirt's Avatar
DreamsOfDirt DreamsOfDirt is offline
DreamsOfDirt will become famous soon enough DreamsOfDirt will become famous soon enough
Need input: Torque for Seat Bolts and Sound Dampening
I'm working on sound dampening the floor of the truck and I need some help on logic for layout of the dampening and torque on the bolts when I reinstall seats and seat belts.
Logic for dampening:
I'm in the process of laying out the CDL and have that covered. My question is around MLV. Through various threads I've seen several people comment that the Luxury Liner Pro MLV (the product I'm using) is very thick and can make getting the carpet and panels on tricky. Additionally, it's also my understanding that the goal is 100% coverage on MLV. I'm contemplating doing nearly 100% but cutting out gaps that match the carpet. In other words, cutting gaps in circles around the places where the seats bolt to the floor and I'll probably also not go quite all the way to the edges to allow side panels in the cargo area to go on more easily. When the carpet was still in I marked the openings and also the edge of the styrofoam base in the cargo area. See pics below. Does anyone who has installed sound dampening, especially this product, have thoughts on this approach.
Torque:
I have found conflicting information on the proper torque for the bolts that hold the seats to the floor and the seatbelts to the pillars. One post was 27 ft/lb and another was 31 ft/lb. Does anyone have the detail specifically for a 5th Gen?
Loctite:
Can anyone confirm that the seat bolts and seat belt bolts use loctite blue? I see residue on the bolts after pulling them and assume that's what it is.
Thanks!
P.S. Full project write up will be posted when I'm all done.
Need input: Torque for Seat Bolts and Sound Dampening-img_7469-jpg  Need input: Torque for Seat Bolts and Sound Dampening-img_7470-jpg  Need input: Torque for Seat Bolts and Sound Dampening-img_7478-jpg
2018 TRDORP w/KDSS, Cooper AT/3s, Rago cross bars, TRDP Black wheels, front grille, black valances, Kenwood Excelon DNX996, working on the rest...
DreamsOfDirt is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 08:23 AM #2
Does anyone happen to know the proper torque for the bolts that hold the seats to the floor and the seat belts to the pillars. I found conflicting information on the forum. One post was 27 ft/lb and another was 31 ft/lb. Does anyone have the detail specifically for a 5th Gen?
Also, can anyone confirm that the seat bolts and seat belt bolts use Loctite blue? I see residue on the bolts after pulling them and assume that's what it is.
The sounds dampening is in and front / large carpet piece is installed. Hopefully the rear cargo panels go back on tonight without a massive amount of rework.
I'll likely be installing the seats tomorrow night.
Old 06-16-2020, 11:12 AM #3
rheosibal rheosibal is offline
rheosibal is on a distinguished road
I haven't found specific details, but after my installation, I torque'd the bolts to about 25ft/lb.
As for thread locker, I don't know what Toyota has OEM, but Loctite Blue has been fine for anything bolted into the body.
You'll be fine with reinstallation. I used Dynamat, which I believe is thicker than your CDL and everything reinstalled without hassle.
rheosibal is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 12:02 PM #4
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
personally i'd cut things like that so the seats still sat against the chassis. you're never going to notice that small section of MLV missing in a few areas
llDemonll is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 01:46 PM #5
Yes, I agree - that's the route I ended up taking. The carpet fits back into all the clips. I'm working on reattaching the rear cargo panels now. The only questions left are torque for bolts and how it sounds. Hopefully the remaining panels that need to go on behave.
Old 06-16-2020, 11:48 PM #6
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
I concur with rheosibal, 35 seems a bit high.
They use torque spec's for assembly to make sure that people don't over or under tighten them. The last thing you want to do is damage those bolt holes. They aren't a critical rod bearing with specific clearance or high vibration components.
Probably don't even need the thread locker, but it's easy so why not.
If your seat gets that much vibration you might want to figure out why. I don't know that I've ever had a loose seat.
Don't over think this.
Me personally, I would just tighten it to close the gap (snug), make sure the seat doesn't move. Then give it a touch more, like an 32nd of a turn.
itr1275 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:01 AM #7
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Hmm I believe they were 27lb-ft. Thats what I used when I reinstalled the bolts when installing my fire extinguisher mount. Ill see if I Can find the source
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 10:50 AM #8
gsla72 gsla72 is offline
gsla72 will become famous soon enough
That's the torque value that was provided with the seat jackers I installed last weekend. They recommend 27 - 30ft/lbs on the bolts to the floor.
2017 Super White TRDOR: Bilstein 6112/5160, SSO Roof Rack, RSG Sliders, C4 Hatch Ladder, TRDP Skid Plate, Falken Wildpeak AT3W's, Scanguage II, ARB Diff Breather, SDHQ ABS Skids, Apex Overland Recovery Points, Outgear Solutions LCA Skids, AJT Design Knobs, Weathertechs, TRD Heritage Grille, Black TRDP F/R Valences, Black Emblems, Console Vault, Full RCI Underbelly, FJToyman Shock Skids
gsla72 is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 06:37 PM #9
FoRunnuh FoRunnuh is offline
FoRunnuh is on a distinguished road
I just finished doing this. I found the same info researching as mentioned...27 for seat bolts, and 31 for the seat belt bolts.
I'm super happy with the results. My family noticed the difference as well. One thing I had to do was to shave off 1/4th" around the perimeter of the rear seat mount covers due to the thickness of the CCF and MLV. If I were to do it over, I'd use 1/16" CCF instead.
I'd also budget more for MLV tape. That stuff is awesome. I used it in the hard areas in the end. It was so much nicer than the HH-66 vinyl cement. It is faster and pliable, and not toxic like the cement. The downside is it goes fast and is expensive.
It was a lot if work, but very worth it in the end.
Now I need a new set of rear hatch struts, due to the added weight, I'm estimating at around 20lbs for the CDL, CCF, MLV, and new speakers.
Sent from my SM-G960U using Tapatalk
FoRunnuh is offline   Reply With QuoteReply With Quote
bolts , carpet , dampening , seat , torque
What is the torque for the hood bolts? jross20 3rd gen T4Rs 17 12-11-2019 01:11 PM
Final Torque on LBJ bolts AntleredRuin 3rd gen T4Rs 20 10-13-2016 04:34 PM
Torque for hitch bolts? traffic626 5th gen T4Rs 2 05-22-2011 07:55 PM
Torque for seat bolts? seh750 4th Gen T4Rs 2 01-04-2007 10:29 PM
2005 Headliner Removal + Sound Dampening Miscue Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-12-2005 03:10 PM
