Old 06-15-2020, 07:57 PM #1
CentcomPete CentcomPete is offline
CentcomPete is on a distinguished road
Roof rack install dilemma
I have an Artec Industries roof rack that I initially struggled with to install. Nothing crazy, just tried first by myself and realized I needed some help to completely install. End result was the stock roof rack bolt sleeves that the bolts screw in to have dropped into the small void under the roof in two of the corners. I inquired previously and know that this area can be accessed via the headliner but I'm just not able to handle accessing this area and don't want to go down that road on my own. Paying for someone else to access the area and re-seat the bolt sleeves and mount the rack seems ridiculous and I don't even know who would do such work. Maybe I just need to start calling around, I live in Tampa.
I don't think Rivnuts will work on such thin metal in this application.
Is welding an option for the two corners to mount the rack or is that a bad idea?
Of course, of ultimate concern, is leaking.
The Artec roof rack was only about $500. I have no rack on now and need to fix this. I wouldn't be surprised if more of the bolt sleeves "fall down" and become inaccessible during the next install attempt! I feel really stuck.
All opinions Welcome - Thank you!
2023 TRD ORP 4WD Lunar Rock
2013 SR5 4WD Mag Grey (Totaled in 2022)
CentcomPete is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 08:12 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is online now
flyrv9's Avatar
Can you fish those sleeves up with a magnet to where you can grab them with some pliers? You could then secure them (so they don't fall back in) and then epoxy them in hopes they stay until you can get your rack bolts in. It seems the OEM racks were installed before the headliners went in. Pretty thin metal for welding; and no place for heat with the headliner in.
flyrv9 is online now   Reply With QuoteReply With Quote
Old 06-15-2020, 09:03 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
i believe your looking for this bracket. unfortunately, this retainer bracket falls onto the headliner if the bolts holding aren't taken off at the same time. good thing is you can reach in the headliner and re-install the retainer bracket.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-15-2020, 10:53 PM #4
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Probably doesn't matter too much now, or I'm just confused but I thought that rack attached to the stock rails?
Why do you need to unbolt the factory rack?
itr1275 is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 12:48 AM #5
Good point :-)
Old 06-16-2020, 12:52 AM #6
YouTube
Old 06-16-2020, 01:30 AM #7
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
Find an offroad shop that does rack installs near you in Florida. They can probably sort everything out with a few hours of labor.
It all comes down to how much you value your time. Otherwise, Youtube is definitely a good resource at this point to try to see if you can figure everything out. You're probably pulling your headliner no matter what.
I had a disaster when moving my Front Runner from my 2016 to my 2020 (yup; I was fishing parts of from my headliner also). Ended up needing to pull in a shop I've used for install work to clean it all up for a few hundred bucks since I honestly didn't have the time or energy to try to sort it out on my own.
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 06-16-2020, 09:18 AM #8
It was too tight of a fit with the side rails mounted. I loosened them first to allow some wiggle room to slide in the cross rails but it just wasn't enough and I was by myself. They have a decent install video on their website but it just didn't go that way for me!
Thanks for all the replies - looks like I am headed to a local shop as soon as I find one.
area , install , rack , roof , sleeves
Front Runner full length roof rack. First production run rack install. Apex Overland 5th gen T4Rs 61 04-29-2023 01:46 PM
Prinsu roof rack install climone 4th Gen T4Rs 12 11-25-2020 10:00 AM
Roof rack install issue CentcomPete 5th gen T4Rs 3 11-24-2019 08:08 PM
OEM SE Roof Rack Install Question T4R1GR 4th Gen T4Rs 2 09-06-2014 09:20 AM
Yakima Roof Rack install - but no tracks on roof! icdawg Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-20-2011 04:56 AM
