06-16-2020, 08:37 AM
Issues after lifting?
I was wondering if anyone has had any issues with their truck after lifting it?
By issues I don't mean squeaking noises or sag but rather any mechanical failure due to lifting the truck?
Just curious as my 3' kit with UCAs finally got here yesterday and I want to make sure I don't void any warranty on the truck.
On a side note: I got a diff drop kit but I've read mixed opinions about needing one? Should I install it or not? Just want to hear everyone's opinion on it..
Thanks guys !
06-16-2020, 09:49 AM
If you have KDSS: Can't confirm, but I may have worn out the bushings for the sway bar quicker after the lift - a little bit of a geometry change there.
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
06-16-2020, 10:48 AM
I've got 4 years of 2 1/2" to ~2 3/4" of lift. I only drive fast on rotten forestry roads, and everything is great.
As northcoast mentioned, I've replaced my KDSS front swaybar bushings twice in 4 years.... proactively. They definitely wear faster, but they're cheap.
No diff drop. I wouldn't bother with it.
As far as voiding the warranty, I have a great shop that loves my 4runner as much as I do. They are fantastic to deal with. (Patterson Toyota in Woodstock, NB) There are 2 other toyota dealerships that are closer, but not the same kind of service AT ALL. They will throw their hands in the air and blame any issue on anything and everything. The trick is to find that right dealership and stick with them for any toyota work that you plan to do. They are definitely not all equal.
replacing shocks, springs and upper control arms will not void your warranty. But make sure you're going to a place that doesn't make you fight for everything.
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
06-16-2020, 02:02 PM
^^^ I guess I'll buy those bushings in bulk lol.
06-16-2020, 03:08 PM
personally, The biggest issue I have found is a direct correlation between lifting the 4Runner and the size of my visa bill
2018 SR5 Premium - Eibach Pro Truck Lift Kit - TRD Wheels - Falken Wildpeak AT/3 - Tyger Armor Step Bars - Clear Bra - Kenwood DMX706s head unit - PowerBass 6.5" coaxial & 6x9" component speakers (tweeters replaced by JBL 3.5" coax) - Kenwood Excelon 5 Channel Amp - Pioneer 12" Shallow Mount Subwoofer - RAV4 Convex Mirrors - LED Headlights - Lexus LED Fog Lights (clones)
06-16-2020, 05:18 PM
Thank you guys. I have no KDSS ! Yes I agree about what you say regarding the dealers. I used to be a Service Advisor at my local Toyota dealer and we were that kind of dealer that would not want to warranty anything. Managers would get some type of bonus if they fell under a certain warranty bracket so they pretty much wouldn't get anything unless the customer was at the office yelling... Sad but true.
Anyway, I appreciate the input. I was mainly asking if theres anything that typically fails after the lift because that would not be covered under warranty if it did.
06-17-2020, 12:33 PM
If you replace/alter your suspension, those particular parts no longer fall under warranty. Dealerships look for every reason to attribute anything wrong to things that you've done to your truck.
The dealer I bought my 2020 from, they said suspension is covered under warranty if you do a spacer lift up to 3 inches. So, the theory here is that anything up to 3 inches for other parts impacted by suspension should be covered.
Just a thought
06-17-2020, 04:14 PM
Real Name: Old man
Real Name: Old man
I'd like a lift. But seeing how I'm 9hrs from Big Bend and days from Colorado or any place cool West of Texas, I'm staying stock. It's nice being able to cruise at 90. Not that I can't do fun stuff.
2018 T4R TRD Pro Stock - RSG Sliders - Lock'er Down Console Safe - Yaesu 7900 - Cobra 75 - Garmin 55 Dash Cam - Gaia GPS - Garmin InReach Mini - Earthmate - Baja Designs Squad Sport Ditch Lights w/ Cali Raised Low Profile Ditch Light Brackets -Diode Dynamics SS3 Fog Light Kit - LFD Crossbars - BFG K2s - Warn VR EVO 10s - Warn Semi-Hidden Bumper
06-17-2020, 04:55 PM
Real Name: Cono
Real Name: Cono
Thanks guys !
The only issue I've come across with the 3" lift on my truck is my wife *****es about it every time she climbs in. Other than that, no issues.
2018 Black 4Runner TRD OR
06-17-2020, 05:11 PM
Have you tried the poly bushings? I'm debating putting those on next. My KDSS bushings are shot.
2016 Trail + KDSS | Kings 2.5 w. Adj + Ext Travel Front & Rear - JBA High Caster UCA - Icon 3" "Overland" Springs - Proline 4x4 Rear Elite Dual Swingout Bumper - Demello Offroad X-Wing Sliders - SCS Ray 10 - Falken Wildpeak MT01 285/70/17 - Dirty Pants
06-18-2020, 04:26 PM
Poly bushing may make the ride a lil stiffer and less comfortable. I haven’t had any on my 4R but I have built a few Audi’s with full poly bushings and the ride wasn’t as comfortable but did hold up better for mountain carving in Colorado
06-18-2020, 10:58 PM
Real Name: Zach
Real Name: Zach
Any time you change the geometry of your suspension you're creating opportunities for accelerated wear of bearings, bushings, and joints. You happen to be lifting near the upper limit of what 4R folks consider normal. It's likely you're adding bigger tires/aftermarket wheels; more opportunities for accelerated wear. You can address some of this by using adjustable components like UCAs you mentioned.
You'll see lots of varying experiences and many "rules of thumb." In my opinion every build, no matter how nice or expensive, will see failures. If you look at it as an chance to upgrade whatever component, it's like you're doing stages of upgrades over time. Also, if you like turning wrenches, it's a great way to learn about your truck.
06-19-2020, 05:28 PM
I had a 2016 trail with kdss and I had a 2" lift on it for 2 years. During this time I did not experience any issues with mechanical failure. The only issue I came across during the lifting process, which I was aware before doing it, was putting bigger tires on and the rubbing from those bigger tires (obviously doesn't have to do with the lift or suspension itself). Just had to make some alterations to avoid tire rubbing.
As far as long term mechanic issues I cannot comment on that since I only had it for 2 years. There is also a lot of different variables because it depends on the brand of lift/suspension and other components that you may change out at this time and whether or not the person or the place you take the vehicle to knows what they are doing.
06-19-2020, 07:32 PM
Poly bushings are very hard to keep from squeaking. You can lube them and then it's gets cold and they squeak. Relube, then they squeak when its warm. Squeak, Squeak, Squeak.
Granted these were control arm bushings, but something I wouldn't do again.
So if yo don't mind a pack of squirrels living under your hood, poly is for you.
06-19-2020, 10:36 PM
I've recently had a KDSS clunk diagnosed as the front driver hydraulic cylinder. I plan to go my and take a look myself before believing them, but what do you think about change in geometry and that particular part failing? I feel like that part would not be affected to the same degree as the bushing?
