Old 06-17-2020, 11:31 AM #16
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
34's are better offroading than 33's. But 35's are better than 34's so why not put 35's on? Get my point? Unfortunately 4Runner's were never built for large tires like Jeeps. A 4Runner will never be able to do what a Jeep can do off-road. It is what it is. I think a lot of people put 34's on their 4Runners and that should be fine if you re-gear, but to me if you want big giant tires and rock crawling ability, get a Jeep JL. I think you can put 35" tires on it without any modifications. I am sure also many are running 34's without re-gearing, but I wonder what it will do in the long term to the transmission.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 06-17-2020, 11:50 AM #17
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Originally Posted by SpeedyKevin View Post
Hmm you may lose some acceleration with the 34s but some folks here have had no issues with that. For offroading, the 34 would be nicer off road. I believe Jetboy used a 33 on his first Rubicon trip and then 34s on the second. He found the 34s to provide a much better experience.
Yep. I've run both sizes. On a trail like the Rubicon or similar - something around a 6 out of 10 on the difficulty ratings, the larger tire starts to make a meaningful difference on some obstacles. A little extra lift height also helps in that situation.
There is a noticeable difference in net gearing each time you jump up in tire size. The 34" tire is roughly the same jump in size as compared to a 32.8" tire as the 32.8" tire is from the OEM 31.6" tire. I have not found any issues with gear hunting being worse on the 34" tire than either of the others. If anything it may actually be better because it doesn't down shift as often.
What I did find was that 4.56 gears ended up being significantly worse in terms of highway mpg to the point that I removed them. I had a few issues with ARB front locker so that was also a side issue with the gearing swap frustrations. My last highway trip towing my small teardrop camper with 4.56 I got 11.7mpg IIRC. That was worse than I got with OEM 3.73 diffs by a significant margin. Two weeks ago I towed the same camper on a similar trip and I got 14.5mpg. That means I'm burning about 25% less fuel per mile. That's a significant difference in terms of engine load and efficiency. The reason is that 4.56 gears are not deep enough to stay in 5th gear in either situation and 4th gear works either way.
Unloaded on my last road trip with 33.0" tires (275/60/20) I got a dash reading of 18.7mpg over 300 miles in the mountains at highway speeds. From Salt Lake City Utah to Garden City Utah. I drive that trip frequently. With the 4.56 gears and no trailer I was getting 15mpg or less. Again - significant reduction in engine load/efficiency with the OEM gears.
My logic was that if I'm going to get 14-15mpg - I'm just going to swap platforms to something that should get 14mpg (an LC200 or LX570) or even a Tundra and at least have 400hp to go with my 14mpg. I really wish we had the 6AT and then you could run 4.88 or so diffs and still have good highway cruising rpm range.
Of course stock tires were the best by far in every scenario except offroad ground clearance. For highway driving - stock tire size is the way to go. It's not really even close. The next set of highway tires I buy will probably be a downsize to something around stock height. I keep two sets of wheels/tires and swap them around depending on what I'm doing. I have a large garage, so storage is no problem and it takes about 10 minutes to swap them over. If I could swap diffs in 15 minutes - I'd probably swap the 4.56 in for offroad trips. There's just not a great solution that's ideal for everything. So we have to find some sort of balance that works.
back , debating , taking , tire , tires
FS:TOYO open county 295-70-R17 tires/Trail edition wheels w/general 265 tires 97supratt For Sale: Suspension/Wheels/Tires 17 01-07-2020 03:09 PM
Tires tires tires Maxxis Trepador VS Goodyear MTR KaliKid General Discussions 3 11-18-2015 11:44 AM
2015 Trail edition 18"tires and Cooper Tires rubbing xtreme-24 5th gen T4Rs 5 11-29-2014 11:11 AM
Suggestions on snow tires or all terrain tires for a 2002 2WD 4Runner Limited? sienna221 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 11-14-2014 03:39 PM
Upgrade Tires, CV Boots are now leaking after upgrading tires and need advice. AZ4runner08 4th Gen T4Rs 20 02-16-2014 06:21 PM
