Old 06-17-2020, 01:06 AM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
NEWBIE question: Engine breaking?
I tend to coast where possible, but ever since I've moved to the west coast my travels take me on steep roads where even without any gas the car picks up speed. Obviously I don't want want to be riding the brake...
I've never tried engine breaking but have read about it, but am also afraid of potentially causing damage/issues.
Let's just say I've started a downhill - I can switch from D or S... but then WHEN can I switch to a lower gear? From my very limited understanding of manual transmissions you have to switch gears at a specific speed/RPM?
On top of this, I would think that automatic driving is the most smooth transition, but will it be jerky if I manually downshift? I will be pulling a trailer in my near future (For the first time!) and obviously don't want to cause sudden jerks...
Sorry for the extremely basic question but I want to fully understand it and even moreso don't want to cause any damage!
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 01:35 AM #2
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
I believe if you are too fast the trans will not shift to a lower gear. Not 100% on that though so to be sure.
I live in CO and have had no issues going down mountain roads in 4th or even 3rd at 70mph. I even descended from Pikes Peak in 1st @ 4000+rpm on the steepest bits....
When towing I always try to downshift near the top, IMO it is easier on the transmission that way and you'll use less brake. I also tend to blip the throttle like you would with a manual which helps match rpm when engine braking.
You could always practice downshifting around town without a trailer first....
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 02:40 AM #3
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Yes, engine brake. It will default to 4th gear, I think. It's not really going to do anything but limit the top gear, so don't expect an auto down shift.
itr1275 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 02:41 AM #4
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
My commute to/from work involves a 12 mile 6% grade.
My cruise holds 65 mph just fine (both ways).
Two miles from the bottom it drops to 55 mph, I shift from Drive to Manual (4th gear). It gently brings me down to the speed limit.
One mile farther it drops to 45 mph, I downshift to 3rd until I'm about 45 (everyone else is still going 65, some getting pulled over).
Once I'm at 45 I pop it back to Drive as the speed limit is 45 all the way through town.
At no time does the engine get close to redline.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 03:08 AM #5
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Shifting over to "S" just limits the max gear and is not really a shifter. So default for S is 4. Lower it to 3, then 3rd gear is your max. That being said, the transmission wont shift down even when you select a lower a gear if the car is moving too fast. Makes a few beeps if you try. I normally use 3rd gear when trying to slow down from 55-65ish to around 35-45ish going downhill. If I want to go lower than that, Ill drop into 2nd which I normally do when driving down steep switchbacks like the 198 in Sequoia National Park.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 09:27 AM #6
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
Pretty much sounds like you would be moving the gear selector to the left only and keeping the trans in 4th gear for your downhill excursions even with a trailer, there is a decent amount of engine breaking at higher than cruise RPM in my humble opinion and the front brakes on these trucks are large, more than adequate to scrub off your speed on the downhill straight you don't have to ride them constantly, even application - come back to the speed you desire or slightly lower and continue on, dragging them isn't the best idea of course - give them a chance to cool back down but you'd really have to use them hard to heat these up and cause concern, once again they are big rotors and calipers built for strong applications, don't worry.
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 10:04 AM #7
northcoast's Avatar
northcoast northcoast is offline
northcoast will become famous soon enough
northcoast's Avatar
What color was the cat.? lol
I actually threw a check engine light doing something similar in a different truck a few years ago.
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
northcoast is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 11:33 AM #8
Whippersnapper02's Avatar
I engine brake daily. No issues. The ECU won't let you do anything that's going to harm the drivetrain.
Old 06-17-2020, 11:39 AM #9
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
I used to engine break daily. Until I took my 4Runner in at 50k and the mechanic said the trans oil was dark. He said that engine breaking and running in 4WH on steep roads (recommends using 4WL) is hard on the transmission. Using the break on hills should be ok but I used to use the engine to slow down before a light.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 06-17-2020, 11:57 AM #10
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
If you live in the mountains you engine brake.
Not really sure how it would damage the transmission when it's the engine doing the work.
Not really sure how it's damaging the engine, for that matter.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 12:50 PM #11
themaestro's Avatar
themaestro themaestro is offline
themaestro will become famous soon enough
themaestro's Avatar
I used to do the same, downshifted to slow down all the time. Then I started doing my own maintenance and realized how cheap and easy brakes are to replace than a transmission.
themaestro is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 02:37 PM #12
mteolus's Avatar
mteolus's Avatar
A long time Toyota mechanic that now only works on 4x4s told me that. He has a great reputation in the Dallas area.
He did a 2 quart swap on mine and asked me to come back at 75k to do it again. He said I should be good for a while after that. He showed me the oil, it was dark.
Old 06-17-2020, 05:05 PM #13
Hunt1284's Avatar
Hunt1284 Hunt1284 is offline
Hunt1284 is on a distinguished road
Hunt1284's Avatar
I live in a hilly area and engine brake on a daily basis with 2013 SR5. No issues so far. The trans won’t let you shift into 1st if you’re going to fast. It will make an audible beeping if you try. Save your brake pads and engine brake.
2013 SR5 - Silver - Spidertraxx 1.25
Hunt1284 is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 05:23 PM #14
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Brake. Brake. Brake.
NOT break.
What would you rather service - your *brakes* or your trans?
08TxRunner is offline   Reply With QuoteReply With Quote
Old 06-17-2020, 05:29 PM #15
Real Name: Sparky
Real Name: Sparky
My guy also seems to think that the color of the ATF has something to do with how bad the AT is doing.
I dunno. In CO you could cook your brakes and die on the way to work if you lived in the mountains. Not a real issue in the Bay Area.
Old and (c)rusty.
breaking , coast , engine , question , switch
03 4Runner engine breaking mistake oktoday General Discussions 4 05-31-2015 11:30 PM
Newbie engine vibration Rnakas 4th Gen T4Rs 2 01-06-2013 06:20 AM
93 4Runner Engine -- Newbie! BellMobile Classic T4Rs 5 03-24-2012 04:08 PM
Engine breaking - Is it a computer-controlled function? bergs 4th Gen T4Rs 4 12-13-2011 12:36 AM
Newbie with Engine Swap question halo32c 3rd gen T4Rs 8 11-18-2010 10:05 PM
