Originally Posted by 17Jetta
I definitely have OCD. Do they lean on the stock suspension setup? I'll have to take some measurements...
Possibly, but it’s generally imperceivable at stock height from what I’ve read here.
They’re slightly more expensive, but I’m eventually upgrading my Bilstein 5100s (Aka Eibach) to 6112s because they have 7 height settings instead of 3 which allow for finer adjustments and therefore mitigate this very issue
Most set the driver side 1 notch above the passenger, although I’ve seen posts lamenting not setting the drivers side 2 notches higher instead.
When I get mine, I’ll likely set them at (6) driver and (5) passenger and adjust from there depending on what measurements I get.
Buy once cry once. While I love the 5100s, the moment I read about this issue and then went outside and looked at mine again I died a little inside. OCD is a hell of a drug.
