Old 06-18-2020, 12:05 PM #1
Seattle206's Avatar
Seattle206 Seattle206 is offline
Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice Seattle206 is just really nice
Seattle206's Avatar
NMO Antenna Hood Mounts?
I have the Midland MicroMobile MXT275 GMRS Radio and I am having difficulty finding a hood NMO mount for my Midland 3db Ghost Antenna. Midland phased out production of their 5th Gen hood mount for some reason. Anyone know of a company that makes an NMO mount that utilizes the hood hinges?
MicroMobile(R)MXTA20 Toyota 4Runner Bracket Mount | Midland Radio
I looked into the Rago HAM Radio hood mount but the material is too thick for the NMO adapter.
2010-2019 5th Gen Toyota 4Runner Ham Radio Hood Mount – Rago Fabrication
I am currently using a TRAM universal lip mount which works but due to the curves of the T4R hood it doesn't sit flush and rather angled.
Amazon.com: New Tram Browning Black 1246-B Trunk Antenna Mount NMO With PL-259 connector and 17Ft of RG-58 Coax Cable: Home Audio & Theater
Seattle206 is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 12:38 PM #2
Captain Planet's Avatar
Captain Planet Captain Planet is offline
Captain Planet will become famous soon enough
You can get a thicker NMO mount for the Rago, that's what I did. They sell them on amazon, they work fine.
I'm pretty sure those midland antennas need a ground plane, so keep that in mind.
I went with a Laird that doesn't require one.
Captain Planet is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 01:02 PM #3
Seattle206's Avatar
Seattle206's Avatar
Do you know of any companies that sell a complete thick NMO with cable and connector installed? I'm finding the NMO mounts but requires soldering either the cable or connector.
Old 06-18-2020, 01:06 PM #4
Whippersnapper02's Avatar
This type of NMO mount should work: You are being redirected...
Old 06-18-2020, 01:55 PM #5
Ascole Ascole is offline
Ascole will become famous soon enough
I have the same radio and mount, went with the Midland NMO mount and it worked. Though I ended up ditching the hood mount and going to the roof.
MicroMobile(R) MXTA24 Low Profile Antenna Cable | Midland Radio
Ascole is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 02:10 PM #6
Seattle206's Avatar
Seattle206's Avatar
Did you use the Midland 4Runner hood mount or the Rago hood mount? Interested in selling it?
Old 06-18-2020, 02:34 PM #7
Amazon.com: Larsen - Thick Hard Mount Antenna Kit with 17' RG58A/U Cable, No Connector: MP3 Players & Accessories
And
Amazon.com: Shakespeare PL-259-CP-G Marine Center Pin Connector: Automotive
No soldering required. Cut cable to length.
Old 06-18-2020, 04:29 PM #8
Seattle206's Avatar
Seattle206's Avatar
@Captain Planet
Thanks for those links. I just made an order. The solderless connector looks like a simply install.
Old 06-18-2020, 04:38 PM #9
@Captain Planet
Just know, with the thick mount, you may have to shim the mount a little with a big flat washer. lowes/hd will have them.
I had to do it to clear the hood on the bottom side.
Has no issues with function, and the washer is just the diameter of the antenna base, so you don't even know it's there.
Connector is easy, squish the prongs down just enough the get the threaded ring on and tighten from there.
Old 06-18-2020, 05:37 PM #10
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
Where is your Tram mounted? Mine is on the back edge of the hood and while not a perfect fit to hood contour it's good enough, especially for $20. Bend the antenna slightly so it is perfectly vertical and I think it looks just fine.
Shown without antenna with rain cap in place.
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 06-18-2020, 08:22 PM #11
Seattle206's Avatar
Seattle206's Avatar
My TRAM mount is in the same location as MeefZah
Curious, by getting a good ground from the Rago mount so you sand the mounting area to bare metal? Won't that induce corrosion which is just as bad for a proper ground?
Old 06-19-2020, 04:17 PM #12
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
No sanding needed when installing an NMO mount. The underside bites into the metal when you tighten it down. Anything more than that shouldn't be necessary.
However with it exposed to the elements, you're going to get galvanic corrosion either way.
Personally, that's why I just drilled three NMOs in the roof, but I know not everyone will take that nuclear of an option
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 06-19-2020, 07:21 PM #13
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Did you check Midland? It looks like it's still legit there and I was able to add it to the cart, get shipping, and get to the customer info.
itr1275 is offline   Reply With QuoteReply With Quote
Old 06-20-2020, 02:22 AM #14
Seattle206's Avatar
Seattle206's Avatar
I called and spoke with their sales rep who informed me the item is back-ordered indefinitely, whatever that means. They have no ETA when it will show back up again. The rep thinks it might be discontinued because normally they can provide an ETA on when the next shipment might be coming in. The 4Runner mount, nada in their system.
I ended up ordering the Rago mount.
Old 06-20-2020, 10:45 AM #15
Half of the reviews on their website are about how it doesn't fit properly. They likely just pulled it.
hood , midland , mount , nmo , radio
CB or HAM Radio and Antenna Mounts on 5th Gen rasber3140 5th gen T4Rs 15 05-21-2021 11:42 PM
WTB//Antenna Mounts...... Ronin1082 For Sale: T4R Items 3 01-03-2015 07:18 AM
CB antenna mounts???? Supertrooper4 3rd gen T4Rs 14 04-18-2013 06:12 PM
CB antenna mounts.. Specifically hood mounts. michaelreed 4th Gen T4Rs 2 03-16-2012 03:15 PM
CB Antenna mounts etc. MARSHALLMAY 3rd gen T4Rs 24 11-08-2005 05:40 PM
