Originally Posted by Seattle206
@ Captain Planet
Thanks for those links. I just made an order. The solderless connector looks like a simply install.
Just know, with the thick mount, you may have to shim the mount a little with a big flat washer. lowes/hd will have them.
I had to do it to clear the hood on the bottom side.
Has no issues with function, and the washer is just the diameter of the antenna base, so you don't even know it's there.
Connector is easy, squish the prongs down just enough the get the threaded ring on and tighten from there.
