What bands are you running with that setup?
Originally Posted by axel1
No sanding needed when installing an NMO mount. The underside bites into the metal when you tighten it down. Anything more than that shouldn't be necessary.
However with it exposed to the elements, you're going to get galvanic corrosion either way.
Personally, that's why I just drilled three NMOs in the roof, but I know not everyone will take that nuclear of an option
