Old 11-09-2020, 12:36 PM #16
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Originally Posted by Doza615 View Post
I’m looking to get this same set up. Do you have any photos of the truck from the side? Does it sit pretty level or is there any rake? How about with a a full trunk any sag?
Thanks In advance!
Here are some pictures. It sits pretty much level, maybe a tad higher in the rear when the truck is unloaded. I am still very happy with the setup, I went wheeling and camping this weekend with the truck all loaded up and had a roof top tent on (last few pics were from this weekend).
Here it is with the TRD Pro wheels and 265/70 Wildpeaks
Then here it is with the SCS F5s and 285/70 Wildpeaks
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 04:38 PM #17
mifarris mifarris is offline
mifarris is on a distinguished road
Does anyone know is there are limits on which Dobinsons coils can be run on 5100s? I will be adding about 190 lbs of winch and bumper so was looking at 352s which are 700+ spring rate.
I currently have the ome 885 on the 5100s but concerned if that will be enough to maintain a decent lift height or not. Have also heard of OMEs sagging over time...
mifarris is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 05:01 PM #18
tm965 tm965 is offline
tm965 is a jewel in the rough tm965 is a jewel in the rough tm965 is a jewel in the rough
i think thats too much spring for that much weight, would aim for 650 prob
tm965 is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 05:32 PM #19
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
I've seen guys run all different Dobinsons coils on the 5100's, but always at the lowest clip height. I think that's the main thing, you don't want to add preload to them. I've also seen the bases snap on them if too heavy of a coil is added. You won't break the coils, but you could end up ruining the struts.
And as an FYI, Bilstein only recommends stock/OE coils on their struts, or coils they provide, otherwise they don't provide any warranty with them from what I've seen in their documentation.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 05:46 PM #20
Thanks for the feedback guys. I understand the warranty issues for 5100s. What are some other options for coils other than OME or Dobinsons? I didn’t see any 650 lb lift coils for those brands
Old 11-30-2020, 09:03 PM #21
Nickademus78 Nickademus78 is offline
Nickademus78 is on a distinguished road
With the intention of only swapping the rear coils, my lower left bushing seized up on the 5100. Finally broke it loose with an air chisel. Changed the coils from 505 to 327s. Reinstalled the 5100s and went home and ordered the IMS shocks front and rear. Installed the rears and it has an amazing ride. Eventually I’ll get to the fronts. Had the 5100 and coils installed since March of 2018 and still performed well for me on the quick off ramps and at the beach. I feel the IMS is an upgrade in ride quality. Hope so for the sake of the price and size!
Dobinson springs and 5100s vs Dobinson springs and  shocks-e65e2854-8b70-47a0-9266-db73b9c503d2-jpg
Nickademus78 is offline   Reply With QuoteReply With Quote
Old 12-13-2020, 11:06 PM #22
Hey mike, I found your post from a few years back with all the good info on Dobinsons. Thanks for that! I have a quick question.
Is this C59-302 a typo? It has a shorter coil with the same spring rate as 314 but says it handles more weight?
Dobinson springs and 5100s vs Dobinson springs and  shocks-4277502e-bed7-4212-93bc-c0bbbca793d8-jpg
Old 12-14-2020, 12:03 PM #23
Crikeymike's Avatar
Crikeymike's Avatar
Nope.
With more weight on it, the lift height is reduced. 2.5" with no weight, 2" with 110LBS on it
Old 03-04-2023, 01:49 PM #24
osugsxr osugsxr is offline
how have you like the dobinson shocks? I'm looking to replace the bilstein 5160s in the rear with the 701 shock and keep the 6112 set up in front till i need to replace it.
5100s , dobinson , setup , springs , trails
FS: 4th/5th Gen Dobinson Rear Springs - Bay Area, CA - $125 t-rex grrr For Sale: Suspension/Wheels/Tires 14 03-23-2021 01:11 AM
FS: Brand New 5th Gen Dobinson Rear Springs, $180 - Houston, TX HoustonT4R For Sale: Suspension/Wheels/Tires 5 03-10-2020 03:16 PM
***SOLD*** Dobinson C59-505 rear springs (used) in KY KYMike For Sale: Suspension/Wheels/Tires 2 03-02-2020 09:59 PM
FS: Dobinson C59-675V rear coil springs 4th or 5th gen, Indiana blackoutt For Sale: Suspension/Wheels/Tires 1 10-07-2017 01:29 PM
