Old 06-21-2020, 09:13 AM #1
Fermn's Avatar
Fermn Fermn is offline
Fermn will become famous soon enough
Fermn's Avatar
Tire pressure and rotation on my new 285/70/17
What would be the ideal tire pressure on my new set of tires ? The shop said 35 psi but I think that’s kind of low for the size of the tire.
Curious as to what everyone is running to daily drive their vehicles ?
Also, what’s the recommended way of rotating these tires ?
Fermn is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 11:14 AM #2
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
5k miles is the generally recommended rotation interval. I keep mine at 40. personal preference.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 11:43 AM #3
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I rotate at oil change, around 7-8,000 miles. Spare is stock so it's 4 tire rotation.
I drive to work on Wed, home from work on Sun-Mon.
One way is 4 miles rough dirt roads (20 mph max) & 18 miles highway (65 mph).
Summer reaches +120°f, winter is teens & the roads are mud.
So summer I run 37psi, heats up to 40psi. Winter I run 30psi.
Toyo Open Country A/T 285's
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 12:43 PM #4
Fermn's Avatar
Fermn's Avatar
Do you do regular rotation or cross rotating ?
Old 06-21-2020, 01:09 PM #5
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Everyone is different, so this is just my opinion not a suggestion for what it's worth.
The vehicle, tire size, driving conditions are just parameters. What matters is your intent and preference. What I like or do with my equipment is not the same as anyone else. In the end do what makes sense for you and your situation. Keep it safe and make small changes and see what works for you.
i.e. don't fill your tires to some random pressure based on some random post, from some random dude on the internet and run the Baja 500.
The tire shop gave you the generic pressure that shouldn't cause you to crash too much. If you look inside your driver's door frame a sticker will show the manufacturer's recommendation for each tire. That's with the OEM tires on OEM wheels and again it's the "safe" bet.
Here are a couple of other resources.
How To Choose the Right Air Pressure For Your Tires - The Dirt by 4WP
https://www.tirerack.com/accessories...200621120504:s
Personally I run them a bit higher for everyday driving, but I live in the bay area with what they say are "paved" roads and consistent weather.
itr1275 is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 01:13 PM #6
Fermn's Avatar
Fermn's Avatar
I know it all comes down to personal preference and situation but I just wanted to hear opinions.
Thanks for links
Old 06-21-2020, 03:09 PM #7
No cross
Old 06-21-2020, 03:15 PM #8
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I'm stock size on Toya ATII. I run 2 psi over the sticker on the door panel. 30K and the tire wear pattern looks even. 265/70-17 load range C.
I air down to 20 for trails and 15 for deep sand.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 03:21 PM #9
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
You never stated what load rating they are. E Load, is going to be more than a SL or P rated tire. 32-35psi cold depending on preference and load would be what I run in a SL rated tire. 38-45psi is what I would run in an E load rated tire. Depending on load.
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 04:37 PM #10
Fermn's Avatar
Fermn's Avatar
C load 285/70/17 KO2 and live in south Florida
Old 06-21-2020, 04:39 PM #11
35 is good. I had 285/75-16 C load KO2’s on my 2001 4Runner and kept them there.
Old 06-21-2020, 05:35 PM #12
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
285/70/17 C load Ridge Grapplers-34 PSI
Rotate every 5K.
shrub1 is offline   Reply With QuoteReply With Quote
Old 06-21-2020, 06:26 PM #13
Fermn's Avatar
Fermn's Avatar
Thanks guys !
daily , pressure , running , tire , tires
Tire rotation... EDness 4th Gen T4Rs 17 08-13-2010 10:45 PM
tire rotation? ciaz 5th gen T4Rs 1 01-29-2010 11:15 PM
Tire rotation bgmac 3rd gen T4Rs 10 10-24-2009 09:43 AM
Tire rotation JAC 4th Gen T4Rs 3 07-23-2009 10:58 AM
Tire rotation chunderboy 4th Gen T4Rs 17 05-01-2005 10:50 PM
