Old 06-21-2020, 12:45 PM #1
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Air bag info for towing
I’ve seen posts where they say what part number they bought but I need one for a 3”lift coil.
What model would that be?
Also no one ever discusses what they’re using to fill the air bag. I mean they don’t magically inflate so what “kit” is everyone running?
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 11:20 AM #2
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
Air-Lift #60833 is a +2" bladder. #60750 is a +3" bladder. I have the #60833 in my '3in.' lift springs. They work well. I've had it for 10 years and had to replace the bladders @ 7 years due to cracking. In the FJ world some people were using the +3" bladder but had a difficult time stuffing the deflated bags into the spring due to lack of free space.
I have two vehicles with them. One has no gauge or connected compressor. I use a portable compressor and inflate them via the schrader valve. It's only used for load hauling occasionally so the manual air up/down works for this one. I have the Load Controller #25854 on the other vehicle since it hauls very often. It's worth the extra $200ish if used a lot...
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 04:50 PM #3
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Can't answer the first part of your question, but I had Ride-Rite airbags on my 2nd Gen Tacoma and my 2012 F-150 for towing purposes. I just used a bicycle pump to fill them up. You're likely only running 20-50 PSI in them. Took about as long to fill them as a mountain bike tire. Was a lot cheaper than and easier honestly than an electric compressor setup.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 06-22-2020, 06:47 PM #4
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
Either you fill it as you would your tires or add an onboard compressor such as this
Firestone 2158 Air Compressor System - Standrad Duty w/ Single White Gauge | $239.21
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 06:34 PM #5
meltdown meltdown is offline
meltdown will become famous soon enough
I use a small bicycle pump. The kind that mounts to the frame of the bike. Depending on what PSI I’m after, it takes 20-40 strokes to reach my goal, which is normally 18 PSI.
Sent from my iPhone using Tapatalk Pro
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
air , bag , don’t , fill , they’re
Thread w/ Q's & INFO on towing... (Different from others!) pjbrownva 4th Gen T4Rs 45 04-12-2017 08:34 PM
New guy looking for info tracerprix 4th Gen T4Rs 14 07-27-2011 08:16 AM
Towing a 24-27' Boat with the V8 - What are you towing? rmd0311 4th Gen T4Rs 7 09-10-2009 08:36 PM
DRL help, info Mtn.Rush 4th Gen T4Rs 5 01-20-2009 12:07 PM
Buyer Info-2ndGen-22Re. Any info greatly appreciated Joel 4th Gen T4Rs 8 02-12-2005 05:17 AM
