Old 06-22-2020, 08:13 PM #1
MikeMikeMikeT4R MikeMikeMikeT4R is offline
Real Name: MIKE
MikeMikeMikeT4R is on a distinguished road
Real Name: MIKE
4.56 vs 4.88
What are you guys running and what do you like about the new gearing?
Acceleration? Mpg?
MikeMikeMikeT4R is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 12:08 AM #2
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Smile
Acceleration? Mpg?
Waiting for someone to yell at you to use search function
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 12:22 AM #3
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
And then someone else yelling about reviving and old thread.
Mine is stock.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 09:12 AM #4
TheWraith's Avatar
TheWraith TheWraith is offline
Real Name: Justin
TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light TheWraith is a glorious beacon of light
TheWraith's Avatar
Real Name: Justin
4.88's and no matter what gas mileage sux ... Can't wait to supercharge it and see the difference.
My Build Thread
My kids call it ROCKY
2014 Raptor Liner White TEP w/ some mods.
TheWraith is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 10:30 AM #5
mikey's2010SR5's Avatar
mikey's2010SR5 mikey's2010SR5 is offline
mikey's2010SR5 will become famous soon enough mikey's2010SR5 will become famous soon enough
Went 4.56 and very happy. Running a 34" tire and all the added weight and does very well, feels like stock.
If you go 35" or bigger I would probably go 4.88.
just an opinion.
mikey's2010SR5 is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 10:37 AM #6
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Your best bet is as said to search for re-gearing info. There's tons of info/discussions out there that couldn't possibly be re created here.
Bottom line though, considering the cost of a re-gear there's really no immediate cost savings on fuel and once there is it's negligible. I can only speak for 4:56 gears but performance wise all the gains are at lower speeds and off road. Results will vary significantly based on your setup,tire size and type,vehicle weight, other performance mods etc.
All that being said still happy with my 4:56 gears after three years.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 04:59 PM #7
Havik's Avatar
Havik Havik is offline
Real Name: Derrick
Havik will become famous soon enough
Havik's Avatar
Real Name: Derrick
I went with 4.88's when I installed the 35" tires. That was before my supercharger. I think if I had the blower before I did the gears, I might have gone with 4.56's just to drop the RPM at freeway speeds.
Without a blower, if you are going with tires bigger than 33's, I wouldn't hesitate on 4.88's, they really helped with acceleration, climbing etc. considering the taller tires and all the added weight (armor, winch, etc.). If a supercharger is in your future, then you might want to consider 4.56's instead as you won't need as much help for climbing, etc.
2015 Toyota 4Runner Trail Edition
Havik's Build Thread
Havik is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 05:03 PM #8
spartacus's Avatar
spartacus's Avatar
Call these guys and talk to them they are extremely helpful
East Coast Gear Supply
Old 06-23-2020, 05:46 PM #9
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Trust me MPG doesn't get better with a S/C. gets worse since your foot seems to gain 10lbs.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 06:08 PM #10
Brandon H's Avatar
Brandon H Brandon H is offline
Brandon H will become famous soon enough
Brandon H's Avatar
I am running 35s with the 4.88s. Like everyone is saying, the mileage doesn't get better with the gears. Im getting about 13MPG on the highway..... Then again, its not my Daily Driver (Thank God). Mine is way over 7000 lbs
'17 T4R TRD OR Premium w/KDSS. Icon Stage 7,Nitro 4.88 Gears, Volk TE-37 XT-M SPec wheels, Toyo Open Country RT Trail 35/12.50/17 Tires, RCI Aluminum Skids, CBI Front/Rear Bumpers, Alu-Cab load bars, Alu-Cab 3.1 Roof Top Tent, OEM Audio Plus Reference 450Q, Baja designs S8 30", Baja Designs Squadron Pros, Baja Designs Squadron Sports (Rear bumper), Baja Designs LP6 (Roof)
IG: @Expo_T4R
Brandon H is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 06:12 PM #11
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
And there is additional parasitic drag.
delloro is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 10:43 PM #12
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
Man I just need the supercharger because Im planning on pulling a 24ft trailer.
Right now I'm at 13mpg.
My Build Thread
Old 06-23-2020, 11:15 PM #13
What are your RPMs at 75 mph with 4.88s? I might order 4.56 gears depending on how the SC changes things.
Old 06-24-2020, 12:43 AM #14
TheWraith's Avatar
Real Name: Justin
TheWraith's Avatar
Real Name: Justin
I'm running 35's ... So I'm at roughly 2500rpm
My Build Thread
Old 06-24-2020, 02:29 AM #15
Nothing worth crying over
acceleration , gearing , guys , mpg , running
