Originally Posted by 1jzgte
Are you garaged? Is your garage cooler than outside temp as you pull out?
Yes but that’s not it. Today for example I ran an errand and the car sat, windows up in 92 degrees for about 30 min. I get back, start it and see the temp at about 90. Then as soon as the AC gets going good it drops to usually about 72. It’s kind of puzzling and not a big deal by any means, been doing this since 2012. Just thought I’d put it out there. Now that I think about it in winter it works fine even when I’m running heat inside doesn’t affect it. So it’s probably something cold touching the sensor. Freon line perhaps. I’ll take another closer look later.
