Old 06-24-2020, 03:33 AM #1
mluckey's Avatar
mluckey mluckey is offline
Real Name: Mitch
mluckey is on a distinguished road
mluckey's Avatar
Real Name: Mitch
Cruise Control Not Working
Hello all, I have a 2012 SR5 4x4 and ever since I got the truck (~6 months ago) the cruise control has not worked. When I hit the stock to turn on CC the dash light doesn't even illuminate, my first thought was maybe the bulb burned out but even after trying to turn it on and initiate CC as if the light did turn on it still does not work. I checked for fuse diagrams and nothing that i've been able to find says anything about any fuses that have to do with CC. I'm wondering if maybe the stock itself is bad or if it is something else. Everything else on the truck seems to work perfectly fine so it doesnt seem to be linked to another problem.
Would appreciate any insight.
Thanks.
mluckey is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 09:22 AM #2
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
May want to confirm that the cruise control module is actually plugged in (maybe PO was doing some work and needed to unplug it for some reason and forgot to plug it back in).
Would suggest pulling the error codes.
Other possible causes for the cruise control not working are a faulty brake light switch, or issues with the clock spring / spiral cable.
Cruise control not working
Spiral cable and cruise control question
Cruise Control Only Works When Wheel Turned
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 11:56 AM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Fuse 6, interior panel (speed control amplifier) maybe? Ignore red lines.
Cruise Control Not Working-interior-fuse-panel-062420-gif
thennen is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 01:41 PM #4
Shadytype Shadytype is offline
Shadytype is on a distinguished road
Make sure you dont have traction control off. Cruise wont work with it off. Also if you have a broken abs sensor or other peice that setects wheel slip it, the cruise will nit work
Shadytype is offline   Reply With QuoteReply With Quote
control , light , stock , turn , work
2020 TRD PRO - Cruise Control not working deevilla7 5th gen T4Rs 10 04-22-2020 05:28 PM
ECO and Cruise Control not working. Any thoughts? Cam_23 5th gen T4Rs 8 03-16-2015 03:33 PM
Cruise control not working cbielat 5th gen T4Rs 18 01-19-2015 09:33 PM
Cruise Control not working DSpease15 Classic T4Rs 6 09-04-2011 01:07 AM
Cruise control quit working wy4runner 3rd gen T4Rs 4 06-17-2008 03:20 PM
