Old 06-24-2020, 03:43 PM #1
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
Need insight on tire rubbing 265/70x17
I bought these Wildpeaks when they were on sale. I have had the similar size tires before, but in different brands (just took off cooper AT3s).Never rubbed the body mount before. New tires are Wildpeaks 265/70x17 on stock wheels. They are a lot larger than the coopers were.
I have a 2" lift and SPC UCAs. I cannot find the last alignment printout, but It's now rubbing the body mounts when I turn sharp Especially when I back up.
From doing some searches around here, it seems the SPCs are a PITA to adjust for alignment people. These arms were on here when I bought this hoopty years ago.
I do remember the alignment guy telling me this was the most caster he could get, but from what I'm reading, Max caster isn't the answer. It's more of a process to find the correct formula?
I guess I'm wondering if anyone has any info that might help me figure this out.
I'll be taking it to a more "off road" oriented shop in the next couple weeks (they are booked). Aside from bringing a copy of the SPC instructions, can you guys give me some tips?
Thanks
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 03:57 PM #2
Deimos Deimos is offline
Deimos will become famous soon enough
  1. Do fender liner mod
  2. trim bumper
  3. get a bmc
  4. go to a different alignment shop and be sure to take a picture of your alignment specs for record keeping in the future
Congrats you're rub free!
Deimos is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 04:05 PM #3
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Thanks
Could be the caster. Still running the OE wheels?
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 04:35 PM #4
I am running stock wheels with spacers.
The entire reason for staying with 265s was to avoid rubbing issues. But these are still pretty large tires.
Need insight on tire rubbing 265/70x17-ff7f66bc-e85c-4b0c-a285-5fe0bd489d3e-jpeg  Need insight on tire rubbing 265/70x17-aa02c1a0-f0ef-4a67-b37c-bd5ded292069-jpeg
Old 06-24-2020, 04:39 PM #5
Ahh could be a mix of the wheel spacers and caster. I had wildpeaks in 265 e load on stock wheels with 1.8 caster and had no rubbing issues.
Old 06-24-2020, 05:15 PM #6
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
The spacers definitely contribute. Since they push the wheel out away from the car, when you turn the wheels left or right they also push the wheels forward or backwards causing more risk of rubbing.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 09:35 PM #7
I guess I'll find out in a couple weeks after the alignment. I know there are a bazillion tire threads, just thought it was odd having a tire this size rubbing the body mount with UCAs.
Ultimately, I need to grab some wider wheels with better offset and ditch these spacers.
Thanks
Old 06-24-2020, 10:12 PM #8
83Mule's Avatar
83Mule 83Mule is offline
83Mule is just really nice 83Mule is just really nice 83Mule is just really nice 83Mule is just really nice
83Mule's Avatar
spacers for sure....are they 1.25''? you may eliminate the rub with 4.0 caster.
83Mule is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 12:07 AM #9
AZ Craig AZ Craig is offline
AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough AZ Craig is a jewel in the rough
Just as a frame of reference, when I ran SCS wheels (8 inches wide and I believe pretty significant backspace), I did rub with LT265/70R17 Falken Wildpeak AT3Ws, but not on the body mount. Needed to scrap my mud flaps and do the fender liner mod, but was able to get it under control.
From what I can tell, the road to hell is paved with wheel spacers .
2016 Black Trail Premium KDSS - Traded
2020 Army Green TRD Pro: 265/70R17 Goodyear Duratrac RT, Eibach TRD Pro Lift-Kit Springs, Victory 4x4 Blitz Al Sliders, RCI TRD Pro Integration Al Skid Plate Set, RCI Gas Tank Al Skid Plate, Front Runner 3/4 Slimline Roof Rack (w/1.4m Easy-Out Awning and Quick Release Kit), Morimoto XB Taillights, Canvasback Cargo Liner, more to come...
2023 Yacht Blue Kia EV6 GT
AZ Craig is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 12:24 AM #10
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
The 265 70 17 Wildpeak, at least the SL version, is 9" wide, it is basically a 285 when it comes to width (not height).
Using stock wheels, my driver one rubbed a little on the front fender, as with AZ Craig. I removed the mud flaps immediately anyway so no recollection on that. For the rest, as mentioned already, it has to be the lift plus alignment specs.
Old 06-25-2020, 01:38 AM #11
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
I ran 265/70r17 falken wildpeaks with trd pro wheels and 1.25” spacers and just needed to do some trimming on front bumper, move fender liner forward, and remove mud flaps. This was with cornfed 1” front level.
I ended up putting on 2.5/1.5 lift. Then shortly after did 17x8.5 -10 scs wheels with 285/70 wildpeaks, (no spacers) and still don’t rub body mount.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 03:08 AM #12
jtgrinsell's Avatar
jtgrinsell jtgrinsell is offline
jtgrinsell will become famous soon enough jtgrinsell will become famous soon enough
jtgrinsell's Avatar
I recently added 5100s set at 1.75” lift in the front and added the 265/70/17 Wildpeaks and mine was rubbing on the driver side front fender liner at full lock while backing up. I had to take it back to the alignment shop twice and they adjusted the caster to 3.0, I believe, I can check tomorrow and updated but I no longer have the wheel run issue.
2020 ORP - Dobinson's 302/505, JBA UCAs, 5100s, Cooper AT3 Discoverer XLT 285/70/17
4Runners and Dobermans - https://www.instagram.com/derpydobies
jtgrinsell is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 04:47 PM #13
Well I ordered some FN wheels last night and will be ditching the spacers. I'll update when I get it all mounted.
Old 06-15-2021, 11:09 PM #14
FJMcCabe FJMcCabe is offline
FJMcCabe is on a distinguished road
I have a 2017 4Runner Limited. I had cornfed leveling kit installed and 265/70/17 Nitto Terra Grappler Installed with Venomrex 602 17x9 wheels. The Venomrex 602s have a -12 offset. Is that what's causing my rubbing? (usually when in reverse and tire turned sharp). I see the TRD Pros run 265/70/17 from factory and I'm pretty sure they don't rub. Is that because the TRD wheels have a +4 offset? Is that my issue? Do I need to get a different set of wheels? I just bought a 2008 lifted Tacoma so I can put the Venomrex on it but don't want to necessarily if the offset isn't causing the rubbing on the 4runner.
FJMcCabe is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 05:44 AM #15
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Why the spacers? They are creating the rub problem, and give you a positive scrub radius.
Old Tanker is offline   Reply With QuoteReply With Quote
alignment , body , caster , find , spc
FS: ONE Duratrac $200 SF Bay Area All years!!! 285/70x17 mikey's2010SR5 For Sale: Suspension/Wheels/Tires 4 03-27-2015 05:37 PM
How Bad is Tire Rubbing? ventura726 5th gen T4Rs 4 03-01-2015 12:14 PM
Tire rubbing sneakers9 4th Gen T4Rs 5 10-17-2012 05:24 AM
295/70x17 mikey's2010SR5 5th gen T4Rs 13 09-09-2012 11:09 AM
What Causes Tire Rubbing? 4runit 3rd gen T4Rs 11 10-26-2010 01:11 PM
