Old 06-25-2020, 07:06 PM #1
Thenextlevel Thenextlevel is offline
Thenextlevel is on a distinguished road
Help with lift and tires rubbing
I bought this 2011 4Runner a month or so ago. When I bought the truck it had 285/70/17 tires on it. They rub every time I back up while turning. The previous owner had already cut the fender liners. It needed new tires so I ordered some new Falcon Wildpeaks in the same tire size thinking I would just get a 3” body lift to cure the rubbing problem.
So I took the truck to the shop to get lifted and they called me back and said that it already had a 3” body lift on it. I asked him what I could do to solve the tire rubbing issue as I couldn’t exactly return the tires I just bought. He suggested wheel spacers. From what I’ve read on here that doesn’t help with rubbing. I’ve been looking into a bilstein suspension lift. The 5100 or 6000 something people on here are doing
My question is with my current approx 3” body lift will I gain any additional height by swapping out the springs? Is there an easier way for me to get enough additional clearance so my tires will stop rubbing?
Thenextlevel is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 07:09 PM #2
ryguytheman's Avatar
ryguytheman ryguytheman is offline
ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice ryguytheman is just really nice
When you say "body lift", do you just mean lift via suspension or spacers? A body lift is not the same thing. I may be off base here, but I've never heard of someone doing a 3" body lift on these.
Anyway, lifting isn't going to help you fit those tires. You probably need to chop the body mount, that's my guess. But if you can't tell us where it's rubbing, it will be hard to help. Body mount is on the rear of the tire.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | UpTop Bravo Rack | RCI Skids
ryguytheman is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 07:11 PM #3
It’s spacers. What do you mean by chopping the body mounts. I’m new to all this. It’s rubbing on the front tires when turning. I guess I don’t know exactly where on the tire.
Old 06-25-2020, 07:14 PM #4
Search "Body Mount Chop" in the search bar of the forum and do some digging.
There are a few standard items that people often run into when running that size tire.
  • Fender Liner adjustment
  • Body Mount Chop
  • Trimming of bumper cover
  • Caster adjustment
Searching any of those things should bring up relevant results. There are a million threads here about this exact problem you have. But the first thing you should do is find out exactly where you are rubbing, so you know what you have to adjust.
Build Thread
Old 06-25-2020, 07:21 PM #5
spartacus's Avatar
spartacus's Avatar
An option could be to go with Spc, tc or icon upper control arms, will give you more camber caster pushing the wheel forward resulting in better clearance.
Old 06-25-2020, 07:34 PM #6
Thanks guys. I’ll dig deeper and do a search
Old 06-25-2020, 07:34 PM #7
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Going Bigger - 5th Gen Tire Fitment Guide
https://www.toyota-4runner.org/5th-g...-consider.html
285s rubbing BMC or alignment fix?
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 08:25 PM #8
I doubt you get told this enough, but thank you for your service.
Build Thread
body , bought , lift , tire , tires
3rd Gen Running 33" Tires with No Lift Grimarine 3rd gen T4Rs 33 04-21-2020 10:53 AM
Anyone running lift with 285/75/16 or 255/85/16 tires with no fender flares? Road Bull 3rd gen T4Rs 13 04-09-2015 06:09 PM
FS: 4th gen wheels, tires, running boards, daystar 2.5 front spacer lift. mesa AZ ddnww For Sale: Suspension/Wheels/Tires 5 03-30-2014 11:08 PM
Who is running 265/70/18 tires? patrickd72 4th Gen T4Rs 2 05-23-2011 12:23 PM
