Old 06-26-2020, 07:41 AM #1
Tyger255 Tyger255 is offline
Tyger255 is on a distinguished road
brake noise when starting drive
2015 4 runner with about 100k miles. Bone Stock. After driving it for a few weeks we noticed when she backs out the drive way to start her drive in the morning the brakes make this GOD AWFUL squealing sound when she lightly applys the brakes. I thought since it is a used vehicle that it might need pads. checked all 4 wheels and the brakes look good, damn near new. I let it go for a month to see if it worked it self out since the pads looked new and no change. So I put new pads all around, I used Bosch QuitCast ceramic pads. It seem to clear it up for about 3 weeks and started again, just like before. I greased all the pads when installing, so no issue there. I pulled all the brakes to check for any issues or strange wearing and everything looks perfect. Rotors look good, nothing loose. Everything seems ok. I thought about taking the rotors to get resurfaced to see if that helps but haven't done it yet. After the first time you stop and they squeal for about 4-5 seconds it does not do it again till the vehicle has sat for 4 or 5 hours. Brakes work great, stop with no issues, no shaking or vibrations when stopping. Any thoughts?
Only post I found when searching this issue is for 4th gen 4 runner with no real solution other then rebed the pads. I've tired, no change.
Tyger255 is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 07:47 AM #2
Ungardo Ungardo is offline
Ungardo is on a distinguished road
I never had this problem. But at 65k, I had new brakes Put in. And it started. Dealership that did my brakes said it was normal. Clearly it’s not normal. It’s embarrassing to back out of my driveway in the morning.
Ungardo is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 09:02 AM #3
Yes, its horrible. I can literally hear it from 1/2 a mile away. If i'm asleep when my wife leaves it always wakes me up. I've thought about swapping to a drilled rotor and see if there is any change, but I hate throwing money at a problem in the hopes that it "might" fix it.
Old 06-26-2020, 09:21 AM #4
flatspin flatspin is offline
flatspin is on a distinguished road
My new brake squeal too. When I redo my suspension, I'm going to try and do a couple things to help, but I think it's just the pads. I was warned to only go with OEM pads but didn't listen. Aftermarket one, even though they are ceramic, just are terrible.
2014 Grey Limited 4Runner 4x4
Installed: XenonDepot HID (Philips 4300k) LB & LED Pro HB, Weathertech mats, Shrockworks Sliders, SCS Stealth 6 Wheel, 275/70/17 BFG KO2 Tires, Daystar 2.5/1.5 lift, Demello 1 hoop Aluminum front bumper, and full OEM tank skid.
flatspin is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 09:25 AM #5
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Have you tried to duplicate by setting the e-brake? Pick a time when it’s not happening. Try setting it lightly and increase a little at a time. I’m wondering if the e-brake or cable is binding, not fully relaxing. They can act up if not used regularly. Just a thought.
thennen is offline   Reply With QuoteReply With Quote
brakes , drive , issues , pads , vehicle
Squelch/slurp when starting to drive forward AntleredRuin 3rd gen T4Rs 11 01-05-2018 09:12 PM
Drive shaft noise or U joint noise (LEXUS 4/06 TSB page 18) aka Driveshaft thump/bump rorad Problems & Warranty Issues 764 08-16-2016 08:49 AM
a strange kick when starting to drive gsnake 4th Gen T4Rs 14 08-11-2010 02:36 PM
2001 Starting to drive like a Bucket-O-Bolts. What would YOU do? David D 3rd gen T4Rs 7 06-30-2009 09:37 PM
click when starting to drive MnRunr Problems & Warranty Issues 4 05-04-2006 08:44 AM
