Old 06-28-2020, 06:07 PM #31
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Originally Posted by northcoast View Post
I don't power wash with fluid film applied. I just wash without pressure, because, yeah, I think enough times doing that will take it off. I would think the fluid film plus regular rinsing would be a much easier path. How would you power wash with a week of January temps well below freezing? Not only that, you're going to be stressing out about washing it after every run in the slat/ice/snow.
What I've done is drain the hose completely after every below freezing wash, before the water in the hose can freeze again.
It's absolutely a pain, and the main motivating factor in my wanting to move someplace where snow, salt, and corrosion, and going to the extreme trouble to prevent it, is a bad memory.
02SE is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 06:11 PM #32
northcoast's Avatar
northcoast northcoast is offline
northcoast will become famous soon enough
northcoast's Avatar
Makes me wonder... do people have trouble with the frame rust in tropical coastal locations where salt hangs in the air?
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
northcoast is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 06:17 PM #33
I've seen plenty of rusted out vehicles from warmer coastal regions too, if they drive through salt water. If they don't drive through salt water, and it's just the salt in the air, corrosion takes longer, but corrosion will eventually happen if the vehicle is never or rarely washed.
Old 07-28-2020, 08:57 AM #34
Johnate0's Avatar
Johnate0 Johnate0 is offline
Real Name: John
Johnate0 is on a distinguished road
Johnate0's Avatar
Real Name: John
Originally Posted by thejuice View Post
Nice striper in your prof pic! I used to fish at OBX and assateague, and hit my fair share of tidal pools (different vehicle) going a little too fast.
Do you have a shop apply the por15 or fluid film, or do you just do that yourself?
I run an auto body shop. Yes I did it all myself. ;)
Johnate0 is offline   Reply With QuoteReply With Quote
Old 07-28-2020, 10:42 AM #35
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Keep it as a beater for winter driving only. Anything you get will succumb to the road salt. I had the same issues when I lived in PA. Road salt corroded the brake lines out on my bronco and accord. Might even consider leasing if it's that bad up there with corrosion.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 03:06 PM #36
thejuice thejuice is offline
thejuice is on a distinguished road
Thanks for all the responses, everyone. I wanted to share an update on the rust issue.
I took the 4R to a shop which banged on the frame rails and convinced me it was worth salvaging. I replaced the rusted out skid plate and engine undercover sub assembly with new ones that I painted with several layers of rustoleum. I had to drill out and retap a few bolts on the underside. I reinforced a couple heat shields with washers, but ripped out the muffler heat shield since the mount points were beyond salvaging, and I didn't want to deal with riveting new posts. I didn't notice hot floors or other issues driving around this summer without the heat shield, so I feel safe leaving it off.
I had a local shop strip the remaining rust and spray the underside, rockers, and inside the frame with fluid film. The treatment cost about $350 and they applied about 2 gallons.
I'm keeping my fingers crossed that I can drive the 4R for a few more years, and hopefully without a big repair, like AC or xreas.
Advice Needed - Rust, considering ditching 4R-img_7138_copy-jpg
thejuice is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 06:31 PM #37
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Heat by itself is not an issue even in the summer if you don't use heat shield the condensation under carpet and potential mold in the winter is a concern if you have shield off under rear passenger area. You can get Rivet Bolts and proper tool on Amazon and install these from underside:
<<<< is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 10:16 PM #38
Makes sense. I looked into something like those rivets, but it’s a tight area to get into with the muffler in the way, and there’s no dropping the muffler with the amount of rust on the flange. Maybe a project for next spring..
Old 10-09-2020, 03:10 PM #39
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
Wow!
In my neck of the woods they spray calcium chloride solution rather than using road salt. This stuff is brutal, all our bridges and lamp posts are rotting away and there are a litany lawsuits outstanding.
My '12 with 180k km (~111k mi) and no undercoating or rust treatment of any kind barely had surface rust on the welds even, but I wash it weekly through the winter.
An ounce of prevention is worth a pound of cure.
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
repair , rust , rusted , shield , time
IS THIS TOO MUCH RUST ? Opinions needed jreask 3rd gen T4Rs 35 07-05-2021 04:54 PM
Opinions needed- 3rd gen rust HunterG425 3rd gen T4Rs 12 05-19-2020 04:27 PM
Looking at a Used 5th Gen - Rust Opinions Needed! altreezy 5th gen T4Rs 7 12-13-2018 05:59 PM
My Rust Plan - feedback needed Fezzik 3rd gen T4Rs 29 12-15-2017 10:41 AM
Ditching the Center Caps okay? Land_Shark 5th gen T4Rs 8 05-10-2016 08:14 PM
