Old 06-26-2020, 01:45 PM #1
Lynch9 Lynch9 is offline
Real Name: Jim
Lynch9 is on a distinguished road
Real Name: Jim
2013 4runner hard to shift, starter won't engage.
hey all,
so i just replaced the battery in my 2013 sr5 at 140k miles because it was finally time. the battery was fully dead but if it would start right up.
replaced with an ever start AGM battery, 4runner fired right up but was out of gas so died. I added some gas, the car started right up, I tried to switch to drive. When shifting out of drive the selector feels as if its gummed up and very resistant to go into gears and will not go into drive.
I tried turning the car off then on again and now when you turn the key to ignition the point where you'd usually hear the starter kick in, now nothing.
We are planning to move from New York to Kentucky this weekend and this is really giving me a headache.
Any ideas or guidance would be greatly appreciated!
I have disconnected the battery and reconnected to no avail.
Lynch9 is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 06:51 PM #2
mike5 mike5 is offline
mike5 is on a distinguished road
Selector feel has zero to do with battery. In my 2013, after having the battery disconnected, when starting for the first time there’s a 50% chance of it turning off. It feels like the ECU or TB is learning.
I’d suggest getting a volt meter and checking your new battery’s voltage. Make sure battery has over 12V first. Preferably closer to 12.3 as a minimum. Assuming it does, then it should crank. But prior to first start put key in ON position and wait about 30 seconds. You’ll hear the TB opening and closing.
Let us know the voltage.
Also once it starts check voltage again and make sure the alternator is charging.
2013 T4R TE
My Adventures
mike5 is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 07:01 PM #3
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is offline
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
Running the old battery as long as you did could have put undue stress on the alternator and it decided to quit. Alternator is not designed to keep charging a failing battery, just to maintain the system. Agree with making sure the new battery is fully charged. Check your connections again as well. Every time I have disconnected my battery the system starts and shuts right back down. It's the ECU going through it's diagnostic checks. As far as the gear selector, my 12' is getting stiff and probably needs some cleaning and synthetic grease. Might be the same problem with yours. But it should be an unrelated problem to the battery issue.
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 08:45 PM #4
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
tell us if you have anything aftermarket installed
lights? stereo? you've got a short somewhere
1jzgte is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 10:04 PM #5
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I had the shifter basically lock up in an 05 tacoma I had a while back when it sat unused for a few months in a dirt driveway. Some penetrating oil on the cable at the ends got it moving a bit and then lots of moving it back and forth got it free. If the range selector switch doesn't think it's in park or neutral it's not going to start either so check and see if that's gummed up too.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
4runner , battery , drive , gas , start
hard shift on downshift ...HELP!!! tenro1 3rd gen T4Rs 6 04-16-2014 10:58 AM
Hard shift from 2nd to 3rd CShaver1025 3rd gen T4Rs 16 03-20-2014 11:36 AM
hard to start after starter repair i dig booers Problems & Warranty Issues 1 12-19-2011 10:58 PM
another hard starter WebWalker Classic T4Rs 3 03-13-2009 10:47 PM
