Old 06-26-2020, 10:23 PM #1
dclark2171 dclark2171 is offline
dclark2171 is on a distinguished road
Cost for 5th gen limited front struts?
I have just turned over 200,000 mostly highway miles on my 13’ limited 4x4. Has anyone replaced their struts on a 5th gen limited.. if so how much am I looking? Dealer quoted me $1700 for two front struts (parts and labor).
dclark2171 is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 11:27 PM #2
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Remove all the XREAS stuff and put in a pair of Bilstein 5100s for $264 or leave the X stuff alone and use Bilstein 4600 for $176.
Dealers --> $#!^
BobsTrail is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 12:09 AM #3
cutty01 cutty01 is offline
cutty01 will become famous soon enough
^^^^^ Agreed ^^^^
Or you can do Bilstein 6112/5160s. That's what I did and it way better (and much cheaper than XREAS).
Or you can buy my set of XREAS shocks that were taken off my Limited at 31k miles. They were taken off by a qualified mechanic using the Toyota recommended removal procedures. Not one drop of oil lost.
2013 4Runner Limited | OPOR Sliders | BFG KO2 in 275/70R17 on TE Rims |Bilstein 6112/5160s and SAW 1.5" | Some RCI Aluminum Skids | SPOD | Gobi Stealth No-Rise | Aurora 40” and 6” Single Row LED Light Bars
cutty01 is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 12:33 PM #4
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
the dealer quoted you so much because your front left shock is linked to the right rear shock and vice-versa via a hydraulic line.
i'd do what others suggested and replace the entire system. you can get a full dobinsons setup for that price, or a full bilstein 5100 setup for about $1000
either way, you're either repairing the front shocks for $$$$ or replacing the whole system for $$
llDemonll is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 02:44 PM #5
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
My X-REAS failed on my 03 Limited at 138,000 km (or 85,750 miles). There was a leak in the system - in the line behind the Driver’s Side Centre Control Absorber. Leak was likely caused by corrosion of the line due to road salt used up here during our Canadian winters.
Fluid that had dripped onto the driveway was the first indicator of some sort of problem. As more fluid leaked out of the system, the suspension became worse.
I removed the entire X-REAS system (too costly to replace), and installed the standard SR5 suspension (to keep it relatively stock).
In hindsight, I might have sourced a quality aftermarket shock that was less expensive than the OEM Toyota shocks - but I did not have the luxury of having time to "shock shop" due to the nature of the X-REAS system failure.
These links/threads might help:
Toyota 4-Runner X-REAS Shocks - Shockwarehouse.com
Best Replacement Shocks when removing the XREAS? - Toyota 4Runner Forum - Largest 4Runner Forum
Replacing XREAS with regular shocks - Toyota 4Runner Forum - Largest 4Runner Forum
5th Gen Limited X-REAS Leak - Options? - Toyota 4Runner Forum - Largest 4Runner Forum
At least now I'll be better prepared if/when my X-REAS goes on my 2011 Limited.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
5th , front , gen , limited , struts
99 Limited rear springs and front struts Free - Iowa albertschmitz Heartland 0 02-22-2018 02:19 PM
Rear Springs and front struts 99 Limited Iowa albertschmitz For Sale: T4R Items 2 02-22-2018 02:17 PM
Average cost to install shocks/struts on 2006 2WD T4R cgl4au 4th Gen T4Rs 13 05-30-2013 04:48 PM
Cost to replace front struts on 2002 SR5?? swampy_swimmer 3rd gen T4Rs 3 06-23-2012 12:04 PM
FS: Factory front 2000 Limited springs with new oem struts MichaelFuller For Sale: Suspension/Wheels/Tires 0 09-30-2011 11:25 AM
