Old 06-27-2020, 02:33 PM #16
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
It could also be a tire(s). Sometimes tires can cause a 'Radial Pull'. Try swapping the front tires side to side and see if the 'pull' reverses.
02SE is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 03:55 PM #17
MyanRagahis's Avatar
MyanRagahis MyanRagahis is offline
MyanRagahis will become famous soon enough MyanRagahis will become famous soon enough
My thought process here is to just give it more caster on the passenger side vs the driver.
I've had toyota give me their factory specs on a 2.5" lift and it pulled to the right.
In the past I had ST Maxx's that would cause me to pull to the right pretty significantly even with the desired 4+ caster on passenger vs driver.
I actually got an alignment a few days ago. New shop I decided to try out. It does pull to the right but it's not painfully annoying. If I one hand drive with my left hand, it goes nice and straight with minimal corrections. I guess due to the position I'm in.
But what I've also noticed is that in some parts of my area, the vehicle would go nice and straight on the flat spots that I can notice then once I visibly hit the crowns again, I'm back to holding it to the left just a bit.
They never gave me a printout but this shop probably gave me around a 3+ degrees of caster and possibly a little less on the passenger side. I've had 4+ degrees of caster before and it feels significantly heavier to turn the wheel.Also to take into account, if you have that difference in caster, and you pass by a perfectly flat area, you're going to pull to which ever side has more negative caster.
First time paying $60 for an alignment so I won't complain. Pretty stable on the highway and easy to turn the wheel. I'd like to make them my regular shop for when I need one again and add suggestions.
I've spent $140 on alignments around here only to still have a slight pull or an un-centered steering wheel.
YouTube
MyanRagahis is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 06:38 PM #18
Fermn's Avatar
Fermn Fermn is offline
Fermn will become famous soon enough
Fermn's Avatar
Anyone got an alignment spec sheet that I can go of off when I take it in next week ?
Fermn is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 12:15 AM #19
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
mine
Mine also pulls to the right and it has been like this for a few years. I tried getting aligned again but what they did never changed anything.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 08:02 AM #20
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Rotating side to side just once while still new tire and not broken in isn't bad idea to see if pulls the other way and you'll know that it is a tire and not alignment issue
<<<< is offline   Reply With QuoteReply With Quote
Old 06-28-2020, 08:14 AM #21
Dabigono Dabigono is offline
Dabigono is on a distinguished road
keep us posted... hope it works out for you and they get it handled!
Dabigono is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 08:42 AM #22
Fermn's Avatar
Fermn's Avatar
Update on the situation:
Could not wait until Thursday for the shop to call me. I work at a dealer and I had my front end guy do an alignment and balance all 4 tires again. He said alignment was slightly out but not too bad.
When he balanced the tires 1 tire was missing 50g, another 100g and another 165g. Drove the 4runner home yesterday and its riding the same (pulling to the right) but now is vibrating even more. He's going to check road force today, and possibly swap the tires to see if its a tire pull.
Attached is the alignment sheet from yesterdays alignment.
Hopefully this gets sort out soon
Does your 4runner pull ?-alignment-jpg
Old 06-30-2020, 09:53 AM #23
Jsch222 Jsch222 is offline
Jsch222 is on a distinguished road
my 2020 limited pulls as well. I have 3900 miles on it and had it back in at 2500 - was told it was within spec. I constantly have to put slight pressure on the steering wheel to the right side. They claim it's the crown in the roads. I plan to have mine checked again when i take it in for the 5000 mile service.
Jsch222 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 10:17 AM #24
Fermn's Avatar
Fermn's Avatar
Get it checked as Toyota only offers 1yr/12K mile warranty on alignment. After that, you have pay out of pocket
Old 06-30-2020, 10:52 AM #25
MeefZah's Avatar
MeefZah MeefZah is offline
MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold MeefZah is a splendid one to behold
MeefZah's Avatar
Originally Posted by Fermn View Post
I thought about this, not sure where I can find a perfectly straight road here in south Florida but I have tested in different streets and highways and I’m still getting the pull.
I ended up bringing back the 4runner to the shop. 3rd time is the charm !
Yeah, south Florida is known for its curvy roads! LOL
"How rare that we can point ourselves inevitably west and go, go, go. Run out the highway and the hills. Slide our fingertips over the creases and the valleys of the impossibility that is America. You can’t grasp its vastness from a plane. It’s diversity from a map. You have to put your feet on the ground. Your hands in the dirt." - Zach Bowman
Photos, mods & trip reports
MeefZah is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 11:05 AM #26
euser euser is offline
euser will become famous soon enough euser will become famous soon enough
It’s the crown in the road, that’s why everyone here has a vehicle that pulls right. Living in an area with uneven terrain, I also get the joy of it pulling whichever way the terrain slopes. You can’t change physics.
euser is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 11:30 AM #27
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy's Avatar
What I see missing is cross caster. For areas with more crown in the road, you want more caster on the RIGHT hand side than the LEFT hand side by about 0.2-0.3 degrees. That will cause a slight pull to the left that will offset the tendency to drift right on crowned roads. Have them set the right hand side caster to around 3.2 and the left to 3.0. I think it'll go a long way to helping resolve your issue.
good luck
Jetboy is online now   Reply With QuoteReply With Quote
Old 06-30-2020, 02:04 PM #28
Originally Posted by Jetboy View Post
What I see missing is cross caster. For areas with more crown in the road, you want more caster on the left hand side than the right hand side by about 0.2-0.3 degrees. That will cause a slight pull to the left that will offset the tendency to drift right on crowned roads. Have them set the right hand side caster to around 3 and the left to 3.2-3.3. I think it'll go a long way to helping resolve your issue.
good luck
Wait. Unless I'm reading this wrong, he would need more positive caster on the passenger side to fight the road crown compared to the driver. That's always been my understanding of it anyhow.
YouTube
Old 06-30-2020, 03:25 PM #29
Jetboy's Avatar
Jetboy's Avatar
Yep. You're right. I had it backwards. More caster on the passenger side. Glad you caught that.
Old 07-03-2020, 11:40 AM #30
deepsouthnewfie deepsouthnewfie is offline
deepsouthnewfie is on a distinguished road
I have same issue. I did the lift in October, let it settle fore a few weeks short trips to grocery store around the corner type of driving then took it in for an alignment. No pull prior or at least not to the right. Here are my numbers: 5th Gen Alignment After Lift Pulls Right : 4Runner
Alignment done at a local North Atlanta Toyota dealership, was thinking of going to my local 4wheelparts shop thinking they deal with lifted vehicles and will do a better job.
Any feedback based upon my numbers would be appreciated.
deepsouthnewfie is offline   Reply With QuoteReply With Quote
4runner , alignment , i’m , pull , time
How Not to Pull Out of a Parking Space in Your 4Runner RichinRidgewood General Discussions 14 03-23-2020 05:56 AM
So, a Sequoia, 4Runner and Jeep pull a bus... swampdodo Off Topic 2 01-28-2019 07:37 PM
Can my 4runner pull this screeves 5th gen T4Rs 10 07-01-2013 10:24 PM
Single mom trying to pull trigger on 1st 4runner someday139 4th Gen T4Rs 71 05-25-2012 11:39 AM
Have a chance to pull parts off 99-01 4runner masphx 3rd gen T4Rs 15 03-14-2012 10:32 AM
