Old 06-27-2020, 08:51 AM #1
Fermn's Avatar
Fermn Fermn is offline
Fermn will become famous soon enough
Fermn's Avatar
Does your 4runner pull ?
I got my 4runner lifted about a week ago and have taken it twice to check the alignment. It keeps pulling to the right and every time I take it, the say they have corrected the alignment. I got UCAs to make sure to get the closed specs to factory as possible.
I’m not sure if there is supposed to be slight pull after the lift or if I should take it back a third time?
Fermn is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 08:55 AM #2
outlier outlier is offline
outlier is on a distinguished road
Not sure who “they” are, but maybe take it somewhere else to check alignment?
outlier is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 09:24 AM #3
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
No there’s not suppose to be any difference in the ability of the truck to drive in a straight line. Take it somewhere competent for an alignment.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 09:28 AM #4
Fermn's Avatar
Fermn's Avatar
Angry
Well, I don’t want to be paying twice for alignment. I guess I’ll keep bothering until it drives straight
Old 06-27-2020, 09:48 AM #5
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Ive 33 in tires and track dead straight down flat road but will pull right on aggressive crowned road such a small country 2 lane. Test on perfectly flat road or try in the middle of empty road do rule out slope of the crown following since big tires tend to do that. G.L.
<<<< is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 10:23 AM #6
Fermn's Avatar
Fermn's Avatar
I thought about this, not sure where I can find a perfectly straight road here in south Florida but I have tested in different streets and highways and I’m still getting the pull.
I ended up bringing back the 4runner to the shop. 3rd time is the charm !
Old 06-27-2020, 10:34 AM #7
factory specs aren't necessarily the best specs. more castor isn't bad. they can adjust toe? to compensate for road crown, thats pretty standard.
it should drive perfectly straight with no twitchiness since you have uppers.
Old 06-27-2020, 10:34 AM #8
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout will become famous soon enough
4R4Trout's Avatar
It pulls Jeeps
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
4R4Trout is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 01:14 PM #9
Fermn's Avatar
Fermn's Avatar
Update: have gone on 3 separate test drives and still pulling. The guys say the don’t know why it’s giving them such a hard time. Truck is basically on its 6th attempt to align it lol
Old 06-27-2020, 01:37 PM #10
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Maybe if you can post a shot of your alignment numbers someone might see an area of concern or correction.
Old 06-27-2020, 01:42 PM #11
Did you get new tires at the same time as the lift? Maybe it's a tire issue. Try swapping fronts from side to side or even swapping rear to front. It's not unheard of for some tires to cause this issue if the alignment is right.
Gone
Old 06-27-2020, 01:52 PM #12
KarrotJuice KarrotJuice is offline
KarrotJuice is on a distinguished road
Had a set of Toyo OC M/T on a Tundra I had that would constantly pull right.
Replaced with BFG KO2s and it never did it again. Straight as string.
KarrotJuice is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 01:55 PM #13
I had similar on my Tundra with Cooper S/T Maxx.
Gone
Old 06-27-2020, 02:16 PM #14
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
Mine pulled till I found two problems that weren't bad enough to cause significant problems on their own, but were a problem.
Brake calipers were dragging. The calipers on these rigs are crap. All of them. I only use new raybestos calipers now and they have lasted longer than any of the others.
I also had a dragging parking brake cable. This eventually got bad enough to tell me there was a problem.
Just a thought. Good luck
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 06-27-2020, 02:19 PM #15
Fermn's Avatar
Fermn's Avatar
My tires are KO2s and yes it was all out together at the same time... they didn’t give me an alignment sheet. The checked tire pressures, rotated tires, and put the car back on the rack about 5 times. They said it might the machine and that someone is coming to do maintenance on it next week. They told me to come back Thursday... if it does not work they will credit me back for the alignment. Not happy with the outcome, but I can tell they are trying to get it right.
4runner , alignment , i’m , pull , time
How Not to Pull Out of a Parking Space in Your 4Runner RichinRidgewood General Discussions 14 03-23-2020 05:56 AM
So, a Sequoia, 4Runner and Jeep pull a bus... swampdodo Off Topic 2 01-28-2019 07:37 PM
Can my 4runner pull this screeves 5th gen T4Rs 10 07-01-2013 10:24 PM
Single mom trying to pull trigger on 1st 4runner someday139 4th Gen T4Rs 71 05-25-2012 11:39 AM
Have a chance to pull parts off 99-01 4runner masphx 3rd gen T4Rs 15 03-14-2012 10:32 AM
