Originally Posted by Friggin Idiot
Makes me wonder if you could fit a folded Kel-Tec Sub2000 in there with extra mags...... Surely a Henry AR7 should fit right?
I also wonder if a vinyl wrap would match the body molding a little better....
A Ruger 10/22 Takedown with the Magpul X-22 stock will fit (I just checked), but it has to lean outward because the buttstock is a bit bigger than the front part of the opening. But with the cover like you OP made, it would close and be fully concealed.
If you run iron sights with a tapered barrel, it might fit with the buttstock to the rear, but mine is a lite with an inexpensive red dot on it.
