Old 03-25-2021, 10:19 AM #1
Stephencovar Stephencovar is offline
Stephencovar will become famous soon enough
Question Need some guidance between E load and SL
Hello everyone! Recently I let go of my 2019 TRD ORP that had KO2s and got a 2021 TRD Pro which I absolutely love! Anyways, I want to upgrade my tires. I’ve pretty much made up my mind and am going to go with the Toyo Open Country AT3 in 265/70/17. I am absolutely confused on wether I should go with the E1 or SL version. Here’s a bit of what I do:
•Daily driver. 90-95% on paved LA streets
•5-10% off road trails in the desert (Joshua Tree, Death Valley, etc…
•I’d be going on easy to moderate trails. I won’t be doing any rock crawling or Rubicon type trails.
•Will go camping but not really overlanding.
Any guidance would be greatly appreciated. Also, I’m going crossed eyed on how much PSI I should but in either SL or E. From my understanding if I go with the SL I should just put whatever PSI is on the doorjam but if I go with E I should go higher, is that correct? If so, how much higher?
Thanks ahead of time for the help and guidance.
Stephencovar is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 10:49 AM #2
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
No C-load in those tires? That would probably be optimal for you. SL should be ok, although I personally would be a little nervous in the desert. Rocks are usually a lot sharper. E is overkill but would still work. Your ride in town will be rougher and the added weight will affect gas mileage some. I run E-load (Hankook Dynapro) and I like them but I occasionally do some really rough trails. But in the city they are fine, just a little more feel when going over bumps. You get used to it though.
Regarding tire pressure, I have E-load and my tire pressure is just a tad more than recommended on the door. I can put more in them though if I tow.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 03-25-2021, 10:52 AM #3
Muff Muff's Avatar
Muff Muff Muff Muff is offline
Muff Muff will become famous soon enough
Muff Muff's Avatar
I have E-load Open Country AT3's, and do mostly city driving with occasional off-roading. They do have some mild road noise, but it's nothing compared to other AT tires. Just a tad louder than stock. I mainly got the E-load for peace of mind when off-roading, that I'd have a stiffer sidewall to protect from punctures. I took my 4Runner, with stock tires at the time, on a moderate trail (it was actually a foot trail that I managed to fit in) in the Ouachita National Forest last year and did incur some sidewall damage. That's what spurred me to get the E-loads instead of SL, and I can't imagine SL AT3's would be much better. All in all, I think the mathematical/physical detractions in vehicle performance from running a heavier tire (E-load) are outweighed by the benefits of having a stiffer sidewall when off-roading. My butt dyno hasn't noticed anything negative, in other words.
I run anywhere from 36 -- 40psi in them while on road, still trying to get the sweet spot figured out. Discount Tire always sets them at 36, which visibly looks too low, but rides comfortably. 40psi visibly looks properly inflated, but rides rather harshly. You could always do a chalk test to find the correct pressure to run.
Muff Muff is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 10:53 AM #4
Unfortunately Toyo doesn’t make the AT3 in C load. The KO2s in the 2019 were C load and I felt like it was the perfect compromise. But with these Toyo’s, I’m so torn. Maybe I should look into something else…
Old 03-25-2021, 11:02 AM #5
mteolus's Avatar
mteolus's Avatar
My buddy has the Toyo Open Country SL on his Jeep Wrangler Rubicon. He's never had any problems, but doesn't do anything more than just driving up Jeep trails to get to 14er trailheads in Colorado.
My Hankook Dynapro AT2 RF11's E-load are very smooth on the road (quieter than the K02s), you just feel the bumps a little more than the C-load K02's I used to run (K02s got loud as they aged and I only got 39k out of them). The snow and wet traction is fantastic (the RF11's were new in 2020). 60k warranty as well. Only negative, made in China.
Old 03-25-2021, 11:18 AM #6
Thank you for sharing your experience. How has your MPG been affected with the E load (not that we get this rigs for stellar gas mileage lol).
Old 03-25-2021, 11:29 AM #7
Muff Muff's Avatar
Muff Muff's Avatar
In the city it's exactly the same as stock tires. On my trip last year (stock tires,) I think I got 22mpg round trip, from south Texas to south-central Arkansas. I haven't been on a lengthy road trip since getting the Toyos, but I wouldn't be surprised if there is at most a 1 -- 2mpg difference.
Old 03-25-2021, 11:44 AM #8
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
This website is pretty helpful: Tire Pressure Calculator
OEM Size (P265/70R17 SL): 32 psi.
New Size (LT265/70R17 E): 44 psi.
This will just get you in the ballpark. The best way to dial it in for your particular truck is by doing a chalk test.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 11:46 AM #9
Wow! Thank you so much for sharing this link! It’s extremely helpful!
Old 03-25-2021, 12:11 PM #10
Tuco S.'s Avatar
Tuco S.'s Avatar
No problem! Another handy tip is if you plan on chalking your tires, get the big sidewalk chalk if you can find it. The thin stuff can be difficult to handle if you have big fat fingers. I found the big ones at Hobby Lobby.
Old 03-25-2021, 12:33 PM #11
#protip lol. Good call. I’m a big dude so this is helpful.
Old 03-25-2021, 01:19 PM #12
How has everyone’s overall ride quality been with these tires?
Old 03-25-2021, 01:30 PM #13
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Ride quality is highly subjective as people have different expectations and different tolerances for NVH and general noises and 'feel' when they drive.
Do you notice every new sound your rig makes? Do interior squeaks and rattles drive you crazy? If so, E load might not be for you unless you really need the durability in the sticks and don't drive much in town. Then again, you might not even notice much of a change or be OK with it.
Even on my former 2016 crew half ton the E loads rode noticeably stiffer, and its a larger vehicle than the 4runner. I prefer load C, which is a good compromise - adds durability over P rated but is not excessively heavy/stiff like a load E.
EDIT: keep in mind that load Es have to be run at higher pressures, which exacerbates the stiffness and ride issues. Load E has stifer sidewalls and they aren't designed to flex as much as P and C ratings. Thus, lower pressure will cause more sidewall deflection and thus more heat. Too much heat is not good, so that's why the pressures have to be higher.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 04:27 PM #14
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Pretty spot on - I did the chalk test a few days ago just to recheck the pressures. I set mine at 38. Turns out that the site recommends 38 psi too!
New Size (LT285/70R17 C): 38 psi
perf0rmance is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 05:21 PM #15
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Another pro tip: Do two chalk tests. One for your everyday driving and one for when the truck is fully loaded down for road trips. Then you know the PSI for both and can adjust in between for any variations in load. In all likelihood it won't be that big of a difference, but thousands of miles at a non-ideal tire pressure will net you some improper tire wear.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
absolutely , guidance , psi , trails , trd
bfg ko2 load c vs load e (discount put on wrong tire) 4by4runr 4th Gen T4Rs 27 06-02-2021 01:13 PM
Daily driving: 285/70/17 C-load vs 255/80/17 E-load? str8flexed General Discussions 5 01-04-2019 12:09 AM
Got to really test both the E load and C load BFG KO2's az4runner02 4th Gen T4Rs 26 11-27-2018 02:11 AM
V6 vs V8 guidance newbian 4th Gen T4Rs 68 01-24-2015 11:40 AM
