06-28-2020, 04:49 PM
Removing a KDSS From a TRD Pro, Why?
This is a curiosity question. I heard of some people removing a KDSS from a TRD Pro. I was told that if you’re a hard core off raoder your better off without it. What are the pros and cons of the KDSS?
Thanks
06-28-2020, 04:52 PM
Thanks
You mean orp? Pro doesn't have kdss.
Tradeoffs of kdss are (slow speed offroading) lift limits, cant sas it, cant long travel it, added complexity, and still not the same as a disconnect.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
06-28-2020, 05:12 PM
No KDSS allows you to set the truck up to wheel hard which I do not do. But KDSS plus a modest lift gives you some still very nice off road capability and some great on-road manners as well.
2016 Nautical Blue T4R TEP w/KDSS, Oil Filter canister upgrade, Eibach Pro Truck lift 2.75/1.0, JBA UCAs, XD Machete 17X9 Wheels, Falken Wildpeak 275/70/17.
06-28-2020, 05:26 PM
Ok so KDSS allows for better handling and rides on rough dirt roads and dry river beds for example but limits rock crawling capabilities because it limits wheel travel. Removal allows more extreme rock crawling but sacrifices a smoother ride a bit and reduced cornering on roads. Did I get that right?
Thanks
06-28-2020, 05:34 PM
Oh ffs
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
06-28-2020, 05:44 PM
KDSS is a big fat swaybar with a hydraulic piston on one end that is unlocked below 12mph and locked above it. it's essentially equivalent to a swaybar disconnect.
anything below 12mph is essentially a disconnected swaybar
anything above 12mph will be better road manners when cornering
06-28-2020, 05:56 PM
Mortal Kombat for Sega Genesis is the best video game ever.
This thread is for lunchroom conversation right?
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
06-28-2020, 06:26 PM
Thanks
Not really!
KDSS improves greatly handling on an otherwise stock vehicle, but the price you pay is comfort above 12 mph over choppy terrain. As others said, it is a monster sway bar that disengages at low speeds.
So the other benefit is in rock crawling a stock vehicle where you get extra wheel travel. This is a very real benefit but because most folks here lift for the looks or because they think they need a lift for a moderate trail, they don't appreciate the difference that a little bit of extra travel makes in off-camber and/or low traction situations.
The problem off-pavement is that while non-KDSS stock non-Pro 4R has mediocre to poor handling at speeds and also bottoming out problems, KDSS only addresses the former problem and at the a substantial price premium. By contrast, a decent aftermarket setup can solve both issues for less money (as mine).
So, it will depend on setup and use.
(6112s/650lb at 1.25"-1.5" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
06-28-2020, 06:46 PM
Originally Posted by nb rob
Oh ffs
Don't worry, Bossman will arrive soon with a post full of KDSS links for this person!
06-28-2020, 06:50 PM
Originally Posted by MAST4R
Not really!
What he said^
Also, you could improve the handling of the 4runner by getting aftermarket shocks with alittle more low speed (1-3in/sec) compression dampening. May not have the same flex as KDSS but still feels pretty good.
06-28-2020, 10:15 PM
it limits travel at speeds above 12mph, that is what was said
06-28-2020, 10:26 PM
Yeah I misread that, I need to go to bed.
@offRoadxp | 2019 4Runner TRDO ⁌ RSG Rock Sliders ⁌ RCI Skid Plates ⁌ ICON Stage 2 Extended Travel w/ SPC UCAs ⁌ ICON Rebound Wheels ⁌ 285/75/17 Yokohama Geolandar G003s ⁌ Prinsu Full Roof Rack ⁌ FSR Evolution RTT ⁌ SSO Offroad Bumper w/ Smittybilt 12k Winch
06-29-2020, 04:13 AM
Thanks for some of the good info. Much appreciated. The previous owner of my 4Runner removed the KDSS. The vehicle drives fine as it is but can still handle corners pretty well. I was trying to decide if it was worth putting the KDSS back in or go with a aftermarket shock like King shocks. Still exploring options.
Thanks
06-29-2020, 04:15 AM
Thanks
I'd suggest going with an aftermarket shock instead of putting KDSS back in. The system is a $1750 option plus the labor so thats quite expensive. Don't get me wrong, I really like the system on my 4runner but when it finally gives out, I'm likely dumping the system and going with some sort of currie antirock system (if that ever happens lol).
06-29-2020, 12:14 PM
Thanks
If you still have a TRD Pro like your post suggests (and past posts suggest) your car never had KDSS, nor was it ever an option on TRD Pros. If you have a Pro and someone told you it used to have KDSS they lied to you.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
