Old 06-30-2020, 12:01 AM #16
acidrane acidrane is offline
acidrane will become famous soon enough
Engine mods on an n/a motor typically don't really make sense in terms of cost to power ratio. iirc, there was a user on here that did a dyno run before and after installing a TRD CAI. Per the dyno results, there was a 5hp/19tq gain in the upper rpm ranges.
like borfoo3 said, you need the tune, exhaust, intake and what not to really feel the difference.
2020 TRD Off-Road Premium w/KDSS | Nautical Blue | TRD Cold-Air Intake | MagnaFlow Exhaust | LASfit LED Lights | TRD Pro Grille | FNWheels Countersteer Type X | BFGoodrich K02 275/70 | Bilstein 6112/5160 w/Eibach 1" Springs | Dobinsons UCA | WeatherTech Window Deflectors | C4Fab Sliders | C4Fab Ladder | Sherpa Crestone | Ironman 4x4 Awning
acidrane is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 01:21 AM #17
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
Uhhh... no. Even aside from the typically inflated gains people report from CAIs and such, a gain of 5 hp and 19 lb-ft in the upper RPM ranges is not mathematically possible. HP = torque x RPM ÷ 5,252. At 5,252 RPM, torque and HP are equal, and a 5 hp increase would equal a 5 lb-ft increase.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 01:43 AM #18
I'm just the messenger here..the guy (TheWraith) has the dyno charts.
https://www.toyota-4runner.org/1931633-post105.html
Old 06-30-2020, 02:26 AM #19
TEujunga's Avatar
TEujunga's Avatar
Ah, I see. The 19 lb-ft torque gain occurs at 4,000 RPM while the 5 HP gain occurs at 5,500. That makes more sense.
Old 06-30-2020, 09:31 AM #20
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Originally Posted by SnowYeti View Post
Same, but I also added a URD MAF which really helped the other two reach their potential. It is not a 0-60 thing for me at all. But what I really notice was a stronger pull on the highway with less shifting. With and without a trailer.
Though I must say when I have to punch it to get on the highway it really gets up and goes more than I would have thought.
IDK, maybe living at altitude it makes a bigger impact for me. Heck I would like more air as well sometimes!
Same, I have the URD MAF as well, but I noticed an immediate bump in pep even without it. I was chirping tire after installing the intake and exhaust lol
Old 06-30-2020, 10:20 AM #21
Wolfman’s Brother Wolfman’s Brother is offline
Wolfman’s Brother will become famous soon enough Wolfman’s Brother will become famous soon enough
Who needs before and after dyno charts with all this pep.
Pep city in this b.
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
Wolfman’s Brother is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 03:13 PM #22
TRDshadow TRDshadow is offline
TRDshadow is on a distinguished road
I spent weeks researching this exact question. I looked and found dyno charts for every item i installed. I have a spectre cold air intake with an afe throttle body spacer(the thicker one), mbrp 2.5" exhaust and the sprint booster. I installed everything at different times to compare. here is my thoughts.
sprint booster, i wouldnt drive without it, it made it more fun to drive and lively.
the cold air intake and spacer were put on at the same time and the very next morning i noticed i was pulling the same hills in 5 converter locked that i was downshifting on before. It also comes to life around 3900 rpm and sounds like godzilla having an orgasm
the last piece was the exhaust, i got a great deal on the mbrp 2.5". It has a good sound, very quiet at idle but due to having a turn down over the axle for clearance and it resonating off the ground it is very bareable. it gives it a deep tone but when passing it gives you that v6 tone... but when passing all you can hear is the godzilla anyway
All in all every chart i found and all the research i did. top end power did not increase but maybe 2/3 hp. but i can tell you for a fact that lower and mid range this this has a bunch more torque and this things are made for that not high rpm. I also am running the stock tires still and averaging 19.5/20.5(combined) every fill up running 89. once my lift and 33s are put on i am of course expecting it to drop a couple points of course.
conclusion, do what makes you happy. I cant tell you i have wheeled with guys that had different exhausts than me and mine has sounded the best. i wheeled with a guy running a magnuson and it screamed more than whined... but i would not change my engine mods and have been happy with the performance.
TRDshadow is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 04:35 PM #23
Tcivan Tcivan is offline
Tcivan is on a distinguished road
Hey,
Sorry to Zombie this thread, but it says the Spectre intake and spacer is illegal in California. Is it a noise issue? Emmisions?
I'm looking to slightly boost the low end torque on my 4R specifically so it stops down shifting from 5 to 4 on slight inclines. If you realllllllly granny drive it, you can get decent mileage, but thats the side benefit of a bit more power. The engine doesn't have to shift down. And when you need some grunt, its there. Especially if you boost the power naturally aspirated. I know the limitations of a 5700lb truck, but its sort of a hobby of mine to squeeze mileage out of cars that shouldn't get it.
how has it been since you made this upgrade? Reliability? Engine note? Filter issues etc.
Thanks.
Tcivan is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 04:40 PM #24
Whippersnapper02's Avatar
Originally Posted by Tcivan View Post
Hey,
The 1GR has a charcoal filter just after the panel filter. The purpose is to stop any gas fumes from leaving the intake manifold and escaping into the atmosphere. Generally all aftermarket intakes delete it which is deleting an emissions part making it illegal.
Old 08-30-2021, 04:59 PM #25
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
I installed an AFE filter and removed the charcoal after filter. (I know I'm a bad boy). I didn't notice any difference in power. I installed a Borla muffler and it made a definite difference. Maybe it allowed the AFE to move more air in because more exhaust was getting out? I dunno but getting on the parkway and passing there is a definite increase in power and smoothness in acceleration. It's more than a "butt dyno" effect. My wife can feel it too. After installing a Sprint Booster the drivability of the 4Runner is so much more pleasant now. Is it a race car? Of course not but that's not what these vehicles are for. It now has decent passing power and the throttle response is like it should be, kinda like there's a cable to the throttle body and it actually responds right away.
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 05:24 PM #26
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
Hey,
Thanks.
Last i checked 5th gen 4runners are ~4400-4800 lbs curb weight. You could however be carrying an extra 1000 lbs or so and be within GVWR.
There isn't a lot of performance, tuning, dyno, et cetera information for 4Runners relative to certain other vehicles or Off-Road/Suspension/OV.
At the end of the day, and very much over simplified, with breathing mods if you can move more air mass in and out of the engine and alter the fuel and timing to make use of that air, you can make more power.
So, with proper tuning, breathing mods will change your engine's power curve. How much, and where, is dependent on tuning and characteristics of the mods.
If your 4runner is 2020+, tuning isn't yet an option.
As always, aftermarket parts always carry some amount and type of risk simply from not being the same part that the OE spent millions of dollars and thousands of hours validating. Additionally, by changing said part, you have changed the system, sub-system, assembly, etc.. and therefore potentially the interaction between parts or systems. However, in some cases, the aftermarket part proves to be a solution or even more robust than factory.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 08-30-2021, 09:37 PM #27
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
There’s tons of things you can do that SUPPORT making more power, without actually making more power.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 08-31-2021, 11:13 AM #28
Real Name: Chris
Real Name: Chris
Installing my Borla was a noticeable improvement as well, I actually chirped tire a few times after the install because I wasn't expecting the truck to be so responsive. Definitely not a racecar, but my Borla cat back was definitely one of my favorite and most satisfying mods that I've installed
Old 08-31-2021, 11:21 AM #29
BorotHex BorotHex is offline
BorotHex has a spectacular aura about BorotHex has a spectacular aura about
Which setup did you get, and does it drone?
BorotHex is offline   Reply With QuoteReply With Quote
Old 08-31-2021, 06:34 PM #30
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
I have the Borla touring on mine and an AFE intake. Both were noticeable gains but not earth shattering. Very very slight mileage improvement. The Borla does drone a little after 2500 RPM or so. A long highway trip retrieving parts for my Mustang project going 85-90 for six hours had me kinda wishing I had kept the stock exhaust. But that was the only time. Probably should have just slowed down!
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
care , exhaust , gains , ready , system
Will trade my Magnaflow exhaust for a stock Toyota exhaust vpritchina Classifieds - buy & sell (no commercial ads please) 31 07-19-2008 01:31 AM
TRD single cat-back exhaust for 05-07 V6 4Runners..anyone else looked into this??? kickinasphalt Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-10-2007 01:49 AM
