Thread Tools Rating: Thread Rating: 8 votes, 2.13 average. Display Modes
Old 04-25-2017, 08:58 PM #1
Angelo's Avatar
Angelo Angelo is offline
Angelo will become famous soon enough
Angelo's Avatar
TRD Pro - Front Coils Measurements
Hi all -
Looking for a little help here from anyone who has pulled off the TRD Pro front COs or may have access to a set off their rig. I need unweighted / non-loaded measurements on the length of the front springs. Bonus points for anyone finding a verifiable OEM spec listing (i.e. spring rate, etc.), which I'm not sure even exists but seems like it should.
I know there are a few Toyota techs in the house... can anyone direct me?
Thanks.
Eibach - Dobinsons - Falken - Rigid
Consolidated Lighting Info Thread
Angelo is offline   Reply With QuoteReply With Quote
Old 04-25-2017, 10:13 PM #2
HTXpro HTXpro is offline
HTXpro is on a distinguished road
I'll know tomorrow when I pull mine off. If you haven't gotten an answer by then I'll measure and post up.
HTXpro is offline   Reply With QuoteReply With Quote
Old 04-25-2017, 10:43 PM #3
weeeee's Avatar
weeeee weeeee is offline
weeeee will become famous soon enough
weeeee's Avatar
I have measurements. 3" ID, 13" length. Should be 550# springs IIRC. If you're looking to boost the weight capacity and get a slightly higher lift, King 3x14" 650# springs should do the trick.
I'll add pics of measurements later when I find them, looked into doing something similar when I first got the truck.
IG @go.xplre
weeeee is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 02:20 PM #4
Angelo's Avatar
Angelo's Avatar
Thank you both. LMK what you find.
Old 04-26-2017, 05:40 PM #5
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
We are looking at making 1" and 2" lift replacements over those same coils, to give people some more options, and not have to lose those struts.
We haven't yet been able to verify if we have any existing coils that will do the job. If anyone has a set of those coils that they don't need or are willing to sell, please let me know.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 06:03 PM #6
p0r0y p0r0y is offline
Real Name: Chris
p0r0y will become famous soon enough
Real Name: Chris
Following.
p0r0y is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 06:23 PM #7
weeeee's Avatar
weeeee's Avatar
Sorry this took a little digging. I took these measurements a while back when I wanted to get a small lift out of the TRDP and up the load rating on the coils. As mentioned, closest off the shelf coil you'll find is a 3x14 spring commonly found by King.
Originally Posted by p0r0y View Post
Following.
The stock TRDP front shocks are nearly identical to the Bilstein 6112. The difference is that the two higher spring perches are omitted from the TRD shocks.
Toytec makes a 1 and 2" spacer which is does essentially the same as a higher spring perch and should give a 1-2" lift. You'll gain a little more preload translating to a slightly stiffer ride, and get a little less uptravel.
Plenty of people running them here in this thread:
Trd pro lift question
IG @go.xplre
Old 04-26-2017, 07:34 PM #8
greatape's Avatar
greatape greatape is offline
greatape is on a distinguished road
greatape's Avatar
This is good info (spring measurement and comparable)for that thread, I'd venture to say a lot of those in PRO threads don't dig to deep in others
greatape is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 09:15 PM #9
Kashoggio's Avatar
Kashoggio Kashoggio is offline
Real Name: The guy in the van down by the river
Kashoggio is on a distinguished road
Kashoggio's Avatar
Following.
Yes yes
"Some desire is necessary to keep life in motion"
2016 TRD Pro build
Kashoggio is offline   Reply With QuoteReply With Quote
Old 04-26-2017, 09:28 PM #10
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Maybe not following here, but my 6112's have 5 Circlip grooves, not 4.
Also, from what I was told by the Bilstein tech, the valving is different (and are not digressive) in the 6112 vs the TRDP shocks. Plus the springs are 600# made by Eibach for Bilstein, .
Correct me if I misread @weeeee !
Best Regards,
Saker
Old 04-26-2017, 09:52 PM #11
Yeah that's correct. The newer design of the 6112 has 7 circlip settings though.
Old 04-26-2017, 10:49 PM #12
weeeee's Avatar
weeeee's Avatar
You are correct, sorry. My 6112 had 5 circlip settings, TRDP shocks had only 2.
6112 came with Eibach 600# springs, 3" ID, 14" length.
TRDP came with TRD 550-600# springs, 3" ID, 13" length.
Not sure about the valving, both felt the same to me. When I compared the two visually at least side by side they were near identical.
IG @go.xplre
Old 04-27-2017, 10:55 AM #13
quicksandTRDPRO's Avatar
quicksandTRDPRO quicksandTRDPRO is offline
Real Name: Trent
quicksandTRDPRO is on a distinguished road
Real Name: Trent
This is what I've been looking for. I have no complaints with the stock Bilsteins for my needs. But I would like to get a mild lift without going the spacer route. So having some different coil options to swap out with stock is perfect for me. Thanks @weeeee , @Dobinsons Mike and others for your input.
2016 Quicksand TRD PRO
quicksandTRDPRO is offline   Reply With QuoteReply With Quote
Old 04-27-2017, 04:32 PM #14
Angelo's Avatar
Angelo's Avatar
My thinking was that if it's being accomplished with spacers, it should be doable with springs too, but I'm new to this.
I guess the other part of my question is for those here that have experience with this sort of thing, is there any reason why this could be a bad idea? Is it reasonable thinking to try this? I'm not necessarily looking to add weight anywhere at the moment, just more lift while keeping the TRD Bilsteins.
Old 05-13-2017, 12:51 AM #15
mAtTyGlaz's Avatar
mAtTyGlaz mAtTyGlaz is offline
mAtTyGlaz is on a distinguished road
mAtTyGlaz's Avatar
Any updates on this? Interested. Currently have the Toytec Pro lift (front is just spacers). Looking at adding a bumper/winch soon. Not crazy about spacers but don't wanna shell out $ for new coilovers. Swapping coils would be a great option if it worked.
mAtTyGlaz is offline   Reply With QuoteReply With Quote
2010-2013 Trail front bumper measurements Lmteel 5th gen T4Rs 0 07-15-2016 08:16 AM
OME 884 front Measurements J-BlickPhoto 5th gen T4Rs 7 10-14-2013 07:12 PM
Need detailed Front spring measurements UnderFire 3rd gen T4Rs 0 01-11-2013 10:52 PM
Front lift measurements (no flares) cj80cruiser 3rd gen T4Rs 4 11-13-2012 03:39 AM
Lift: Front vs Rear Measurements Will733 5th gen T4Rs 6 05-16-2011 09:52 PM
