Old 11-23-2020, 01:18 AM #16
UpDog UpDog is offline
UpDog is on a distinguished road
I gave it another shot and did get the comet bracket to fit around a cross bar. It is an extremely tight fit that required loosening and tightening until it finally stuck in place.
I ran it up and down the mountain and the bracket stayed on for the entire ride. That said, I can see why it's had mixed reviews. I had the antenna in an upright position and had to stop a couple of times to retighten the bolt holding it in place. After the third time, I gave up and left it in its more aerodynamic position, flush with the roof.
So long as it's only being used while stationary, the comet mount seems to work well.
UpDog is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 06:56 AM #17
jaredhouck jaredhouck is online now
jaredhouck is on a distinguished road
All - how effective is the weboost in the horizontal position or like a ham antenna mount on the rear fender but below roof line? Know it's not ideal, but curious if you still get a little improvement.
jaredhouck is online now   Reply With QuoteReply With Quote
Old 11-24-2020, 01:36 PM #18
BlackCloud's Avatar
BlackCloud BlackCloud is offline
BlackCloud has a spectacular aura about BlackCloud has a spectacular aura about
BlackCloud's Avatar
Does not appear to work when on roof in horizontal position.
BlackCloud is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 01:37 PM #19
BlackCloud's Avatar
BlackCloud's Avatar
Originally Posted by ????? View Post
Set up looks slick. Which mount did you go with?
This is the Comet that I recommended earlier in the thread.
Old 11-24-2020, 01:40 PM #20
BlackCloud's Avatar
BlackCloud's Avatar
The bolt can't seem to hold the antenna upright above 60mph so it leans back about 10 degrees where the bottom nut strikes the crossbar. Got to figure something out with that.
Old 12-02-2020, 04:26 PM #21
utctscanr75's Avatar
utctscanr75 utctscanr75 is offline
Real Name: Bird Dog Overland
utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light utctscanr75 is a glorious beacon of light
Just curious, but how did you all run your cables from the roof through the cab to the box?
I'm assuming most run it through the hatch and under the trim?
utctscanr75 is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 02:51 PM #22
BlackCloud's Avatar
BlackCloud's Avatar
Through the hatch? My wire is tight to the roof rack, then dips a u-turn into the rear pax corner and under the plastic post and then the plastic around the rear window and then down the B post under the front pax seat to the interior antenna.
Old 12-04-2020, 06:15 PM #23
Hatch, lift gate, rear door, what ever you feel like calling it. LOL
Any pictures? I was thinking the drivers side, but I haven't considered the passenger side.
Old 12-06-2020, 03:36 PM #24
BlackCloud's Avatar
BlackCloud's Avatar
Placement of booster on wheel well.
Weboost mounted with Ram Mount (updated)-img_0026-jpg  Weboost mounted with Ram Mount (updated)-img_0027-jpg
Old 02-18-2021, 12:16 PM #25
I just got the Victory 4x4 rear bumper installed with two rear swing outs. There are holes in the top of each swing out, so I'll probably try to mount it there first. if that doesn't seem to work, I'll try the roof rack.
Old 03-03-2021, 05:14 PM #26
dcguy dcguy is offline
dcguy is on a distinguished road
Hello, have you had any water ingress after this type of installation? I see in your pictures that the cable rests on top / in between the rubber gasket and the rear hatch gate, which I assume does not allow the rubber/gate to have a perfect seal while closed.
Also I assume you connected the weboost to the rear power outlet socket, is that correct? Any issues so far?
dcguy is offline   Reply With QuoteReply With Quote
Old 03-06-2021, 07:06 PM #27
BlackCloud's Avatar
BlackCloud's Avatar
No water leakage to date. Not plugged into rear power socket but wired to the starter. It shuts off w/ vehicle electronics.
Old 03-24-2021, 12:19 AM #28
sicnarfone's Avatar
sicnarfone sicnarfone is offline
sicnarfone will become famous soon enough
sicnarfone's Avatar
What is the thread size for the ram mount ball to thread?
2020 TRD Off Road Premium
Icon Stage 2 Suspension - BFGoodrich KO2's (285/70R17) - Xenon Depot LED Low/High Beams - Diode Dynamics SS3 Fog Pods
sicnarfone is offline   Reply With QuoteReply With Quote
Old 09-04-2021, 11:32 AM #29
Jiehl Jiehl is offline
Jiehl is on a distinguished road
Originally Posted by SnowYeti View Post
Ram makes a B size swivel mount with a ball socket on the other end. They also make a ball I can attach to the end of the antenna. This would make it pretty clean and easy to fold down.
How did you attach the spring to the ram mount ball. Both are male….
Jiehl is offline   Reply With QuoteReply With Quote
Old 09-06-2021, 09:03 AM #30
billiamwu's Avatar
billiamwu billiamwu is offline
billiamwu will become famous soon enough
billiamwu's Avatar
I've been trying to find a better solution to my WeBoost mounting, so hopefully this helps.
I did something similar, but found the spring to be the one part that wasn't compatible. I switched to a spring with two female ends:
SS3M2F - Firestik Medium Antenna Spring With Two Female Ends
These are the parts I used:
RAM(R) Square Post Clamp Base for Posts up to 2.5" Wide
RAM(R) Double Socket Arm with Metal Knob
RAM(R) Tough-Ball™ with 3/8"-24 X .375" Threaded Stud
billiamwu is offline   Reply With QuoteReply With Quote
antenna , make , mount , ram , weboost
Weboost Antenna Install help..and done. shrub1 5th gen T4Rs 10 07-08-2020 08:12 PM
Mounting WeBoost Antenna on Gobi Stealth? moshie 5th gen T4Rs 2 07-05-2020 10:03 AM
weBoost Drive 4G-M Flyinmonkey For Sale: Non-T4R Items 0 04-15-2020 12:31 PM
How to mount rear mounted light bar Rushingman 4th Gen T4Rs 7 04-21-2017 07:28 PM
