Old 06-29-2020, 07:19 PM #1
canadian bum canadian bum is offline
canadian bum will become famous soon enough
3/8" Wheel Spacer Install
I installed some Bora 3/8" wheel spacers from Motorsport Tech with the factory trail rims. It now clears the upper control arm and I still don't need to do a BMC however I am rubbing the plastic mudflap on the driver side which doesn't bother me. I'm running 295/70R17 Cooper STT Pro tires.
I got some factory Toyota wheel studs to swap into the rear, part number 90942-02078. These longer studs can be installed by just removing the rear rotor and moving to shoes off to one side. The longer stud is roughly 3/8" longer than the factory rear stud. I used all the studs from the rear in the front of my 4Runner, they are a little longer than the fronts as pictured. I get at least 8 threads for the lug nuts.
Here is the Rear Studs.
Half installed, can see the difference in stud length.
All studs installed. One without the spacer, and one with.
Front stud compared to the rear factory stud of the 4runner.
Front Spacer installed, didn't have to bend the backing plate or anything to install the rear studs into the front. Just remove brakes and remove studs and install the rear ones into the front.
Front upper A-arm clearance, I no longer rub on the arm at all and at full lock have about 1/8" minimum of clearance.
2016 ORP, OME 3" lift with 1/2" coil spacer, Modified Metal-Tech Bumper, 295/70R17 STT Pro, and a bunch of other stuff.
2005 Tacoma DCLB that is a bit ridiculous Build Thread
78 FJ45 and 79 BJ40 Land Cruiser never ending projects
IG @schultzy507
canadian bum is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 07:22 PM #2
Will be installing some All-pro upper control arms soon. Getting EMF to build some ball joints for them to get rid of the uniballs.
IG @schultzy507
Old 07-02-2020, 10:16 AM #3
UH-1H UH-1H is offline
UH-1H is on a distinguished road
Sent from my SM-G892A using Tapatalk
UH-1H is offline   Reply With QuoteReply With Quote
front , installed , rear , stud , studs
1.5 inch wheel spacer install video chipsahoy 3rd gen T4Rs 4 05-02-2017 06:10 PM
FS spacer 6 Lug 6x5.5 Aluminum Wheel Spacer 1.25" Thick Hub Centric, $100 Las Vegas Jeremy_A For Sale: Suspension/Wheels/Tires 0 11-20-2016 11:14 PM
Wheel Spacer Install w/ bf&after Pictures. Not What I Expected! ar1five 3rd gen T4Rs 22 05-08-2012 05:53 PM
1.5" raer spacer install? Jon 3rd gen T4Rs 5 11-07-2010 03:20 PM
Wheel spacer install question imdav2u 4th Gen T4Rs 3 10-09-2010 08:04 PM
