Old 07-01-2020, 09:34 AM #1
ultimatt ultimatt is offline
ultimatt is on a distinguished road
Valve cover bolts loctite??
Getting ready for a valve cover gasket job. One thing I have noticed it that for the majority of guys they note that the valve cover bolts have worked loose over time, and by that I mean that when people check their bolts for the 1st time after the factory put them in the generally find some if not all are loose.
So, I wondering if it would be a good idea to put a drop of blue loctite on the bolts when reinstalling them after a gasket replacement?
Thoughts?
Thanks
ultimatt is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 08:19 PM #2
spartacus's Avatar
spartacus's Avatar
Thoughts?
Thanks
The valve covers are held in place with the rubber gasket and the sparkplug tube grommets plus the rubber washers on the bolts the torque value on the bolts is 53 inch pounds so the blue loctite may hold them in place but will make it tougher to remove. if you torque it in the right pattern you should be fine. Mine have only leaked one time in 20 years.
Old 07-01-2020, 09:47 PM #3
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
not sure if i would put blue loctite on those bolts. If the cover is torqued to spec so that the rubber is compressed and the cover bottoms onto the head, then the bolts shouldn't loosen.
and you can't re-torque a bolt with loctite since it will break the thread seal. To do it you would have to remove, clean existing loctite and reinstall
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
bolts , cover , put , time , valve
Valve Cover Bolts 4runnerWiniarski23 3rd gen T4Rs 31 02-24-2022 03:53 PM
Broken Valve cover bolts B.E. Coyote 4th Gen T4Rs 14 04-08-2020 02:47 PM
To Loctite or Not to Loctite (Ball joint bolts to spindle)? M22 5th gen T4Rs 11 05-22-2019 12:59 PM
Torque on valve cover bolts? This may be a stupid question... OldRigNewParts Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-22-2018 06:52 PM
Valve cover bolts really do back out thatgreentruck 3rd gen T4Rs 8 04-14-2012 01:13 AM
