Originally Posted by Bumbo
Super stiff... they are not compliant enough off-road. They also feel like crap on-road.
I had the luxury of owning 3 sets of rims and tires for a while, and being able to swap around doing an A,B,C comparison was night and day.
Everything you encounter on or off-road (bumps, chatter, shock) that generally gets absorbed by a softer tire, just ends up getting transferred into your suspension. The end result felt like you actually had less suspension.
The KO2 was the only E load I tried, but after that experience I won't do it again, regardless of the brand. My friend runs the same E load tire on his 2500 HD diesel tow rig with a massive 5th-wheel trailer. Kinda helps put things into perspective about how much load they are actually designed to carry. It's just too much tire for a 4Runner.
haha thats me....i run e rated 315/70/17's on my f250 cause thats what the tire is meant for. not for a minivan.
the ko2's were only available in that rating when i bought them though, i knew what we were getting into. but yep next set will be c rated.
