Old 07-02-2020, 10:47 PM #16
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Originally Posted by Jeff_DML View Post
if you disconnect the stock one I guess it moves around and can destroy your CV boots.
There has been some specially made endlinks that all you to disconnect on the fly but I guess they are noisy when disconnected so they are not that popular.
this post claims that disconnecting the swaybar for IFS doesnt do much anyhow
https://www.toyota-4runner.org/1358631-post15.html
Correct. You do not want your sway bar flopping around. There are some really slick sliding ones, bu they are require manual intervention which can be a PITA.
Also correct on the IFS. It will add limited travel, but it will also let it travel easier. I'm really thinking the rear is the place to spend the time. The IFS will never be a solid axle.
My 2K Tacoma has no rear sway bar and flexes pretty good. The front IFS doesn't flex at all. Theoretically the 4runner rear could be pretty good as well. Ace the panhard rod and sway bar. Extend the swing arms and longer coils.
itr1275 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 01:51 AM #17
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
Just add a 'Disengage KDSS' button that remains off at higher speeds and this thread is solved to me.
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
bar , heat , motor , splines , sway
Front sway bar - disconnecting one side? thezentree 3rd gen T4Rs 0 08-06-2019 07:39 PM
What do you do with sway bar after disconnecting end link? mtbtim 3rd gen T4Rs 13 02-09-2017 11:57 AM
4th Gen Disconnecting Sway Bar Set-Up BlackWorksInc 4th Gen T4Rs 45 03-26-2016 12:43 AM
Disconnecting sway bars Lewis&Clark 4th Gen T4Rs 14 04-09-2015 01:13 PM
