Old 07-03-2020, 07:00 PM #1
Shabang's Avatar
Shabang Shabang is offline
Shabang is on a distinguished road
Shabang's Avatar
Need some electrical help
Hey y'all
I'm not too savvy with electronics, much less solar panels and batteries. Here's my scenario. I have this 200W power bank from FlashFish, second link at the bottom, very nice little product. I want to be able to charge it off of a solar panel mounted to my rack. The company only offers those portable ones, and that's just not the route i wanna go. So I got this 28 Watt Mono 18V panel, its the first link at the bottom. My dumbass thought I could just run the same 14AWG wire down to a DC connector and it would work, not surprisingly it didn't. So I need some help getting power to run from the solar panel to a DC connector to be plugged into the power bank. Any help or advice would be appreciated, like I said, electronics aren't my strongest field. Thank you!
Amazon.com : 28 Watt Mono 18V Solar Panel 20W 25W 30W RV Van Solar Car Battery Charger Portable Solar Panel Trickle Charger 12 Volt Batteries Motorcycle RV Boat Marine UTV, ATV, Solar Generator (Zamp Solar) : Garden & Outdoor
Amazon.com : 200W Portable Power Station, FlashFish 40800mAh Solar Generator with 110V AC Outlet/2 DC Ports/3 USB Ports, Backup Battery Pack Power Supply for CPAP Outdoor Advanture Load Trip Camping Emergency. : Garden & Outdoor
Shabang is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 10:14 PM #2
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
I was interested in the solar panel you linked to so I looked at the comments on the product. I noticed that a couple of people just connected the supplied wires to a round dc plug to connect to the device they wanted to charge and it worked. Sounds like what you tried. However, I also noticed that a few people said the solar panel did not produce current and was defective.
Maybe you did nothing wrong and it is the panel that is not working. If you have a multi-meter you could put your panel in the sun and check for function by connecting your multi-meter to the bare wires from the panel to check for current output. Just a thought.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 10:56 PM #3
Shabang's Avatar
Shabang's Avatar
Interesting, definitely will try that out tomorrow. Thanks!
Old 07-04-2020, 02:42 AM #4
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
A few things.
All basic solar panel (an array of solar cells) like yours just provides voltage and current. Wire them in series for more voltage and in parallel for more current. Just like batteries.
A 12V solar panels typically have an open voltage of ~20V DC (18V is close enough). Meaning open circuit with no current draw. So if you test it with a volt meter with nothing connected you should see ~15-20V.
Once you put a load (FlashFish) on there, the voltage will droop to something much less. You need to be at about 13.5V to charge a 12V lead acid battery. The charge controller should take care of that and I would assume the FlashFish has a charge controller in there it should be able to connect it directly.
I would
  1. Check the polarity (+/-) of your connector. There is no standard and it could be positive or negative polartiy .
    The polarity of the plug should be in the documentation that came with the FlashFish. If it's not in there contact them and ask them.
  2. Make sure the the Solar panel is perpendicular to the sun with sufficient sunlight.
  3. Check the voltage at the panel. It should be 15-20V with no load and about 13.5-14V when plugged in.
It will take forever to charge with that solar panel. FlashFish shows the input as 15V @ 2.5A. This is vague, is that min/nominal/max rating? Not that you need to answer. Lets assume it's max 15V max input and it will draw a max of 2.5A? So if you are providing 1.5A max and they say it's 7-12 hrs (assuming 2.5A) it could be 20 hrs or more to fully charge it from the solar panel.
If you have doubts, I would ask FlashFish how to connect the solar panel.
itr1275 is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 04:34 PM #5
Shabang's Avatar
Shabang's Avatar
So what I had done before was I took the cables running from the solar panel, wired them to a 14AWG wire extension and then connected that to the DC cord, which is also 14AWG. That didnt work. But today I hooked the cables from the solar panel directly to the DC connector and it worked. Can't figure out why the first attempt didnt work, they were the same wire only extended
bottom , connector , panel , power , solar
I just don't get electrical... help! itsjaredj 5th gen T4Rs 3 03-09-2019 06:07 PM
Electrical HELP for 96 T4R Please? Vxc961 3rd gen T4Rs 3 03-21-2015 02:17 PM
Electrical short?? Random electrical issues? Fanman47 4th Gen T4Rs 5 06-09-2014 03:12 PM
Electrical help please!! Antman 5th gen T4Rs 16 06-11-2013 11:22 AM
Electrical help jrkentucky 3rd gen T4Rs 1 02-28-2006 08:30 AM
