Old 07-04-2020, 12:00 AM #1
bRYANT619 bRYANT619 is offline
bRYANT619 is on a distinguished road
DIY REVESOL Hydro-Dipped Carbon Steering Wheel Install
Just got this steering wheel in yesterday and decided to do a detailed DIY and short review. I know there are other steering wheel removal DIYs but hopefully this one is helpful as well!
Here is the wheel I purchased off eBay
Tools needed for this project:
T30 Socket
19mm Socket
10mm wrench/ratchet
Misc ratchet extensions
Pliers
Steering wheel puller tool
Philips screw driver
Flat head pocket screw driver
Ratchet
Cordless impact (Optional)
Painters tape (Options)
Step 1: Make sure the steering wheel is centered as best as possible. Then disconnect battery and wait approx 10-15 mins for residual power to completely drain before proceeding to step 2. I also flipped the window switches and door locks a few times.
Step 2: Removal small trim caps on both sides of steering wheel to reveal Torx screws. I found a small flat head pocket screw driver worked best for this.
Step 3: Using a T30 socket, remove the Torx screw on both sides of steering wheel. Using my cordless impact made quick work of this. The torx screw wont fall out, so don't worry.
Step 4: At this point, you should be able to wiggle the airbag towards you. Be careful not to pull hard, as the cables behind are still connected.
Step 5: At the back of the air bag, you will find 3 cables. One ground, one orange and one black SRS connector. I began by disconnect the ground, then proceeded to the SRS connectors. You will need to pry under and up on the SRS connectors to release them. A pick works best for this.
Step 6: Once airbag is completely removed, place off to the side and move onto disconnecting the 2 white connectors at the top center of the wheel.
Step 7
: Using a 19mm socket, remove the center nut for the steering wheel. Cordless impact works best if working alone. Otherwise, I'd recommend a 2nd set of hands to hold the steering wheel while using a ratchet to remove the nut.
Step 8: Using a steering wheel puller/pulley puller, remove the steering wheel from its post. I used a harbor freight kit that I purchased for approx $13 using the 20% off coupon. Image of kit posted above. The kit uses 2 bolts that thread into the existing holes on your steering wheel + 1 center bolt that helps release the steering wheel as you turn it.
Step 9: Optional step, but I taped the clock spring/roll connector/spiral cable to ensure it stayed centered.
Step 10: Now its time to remove the controls and shroud to swap over to the new steering wheel. Remove the 8 philips head screws. At that point, everything the steering wheel controls and cruise control switch can be removed fairly easily. The back shroud is also easily removed by applying slight pressure at the top and bottom of the plastic cover (not pictured)
bRYANT619 is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 12:01 AM #2
Step 11: Swap everything over to the new wheel and assemble in reverse order as when removed from the OEM wheel. Make sure all 8 Philips head screws are tight.
Step 12: Reinstall wheel in reverse order used to remove the wheel. Make sure the center nut is tight. My impact is rated at 150ft/lbs but I also went over it with my ratchet to ensure it was tight. The last part of this step should be reconnecting the battery. If everything was done correctly, you should not have any SRS lights on and horn functions normally. I did reinstall my wheel a little off-centered, so I will have to go back and adjust that sometime soon.
Overall review: In my opinion it's a nice upgrade for the price. The steering wheel is thicker and I like the feel and ergos a lot better. I come from a long background of imports/tuner cars, so this steering wheel feels and looks a bit more natural too me as well.
Old 07-04-2020, 09:37 AM #3
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Great write up and nice looking mod.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 10:58 AM #4
SnowYeti's Avatar
SnowYeti SnowYeti is offline
SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough SnowYeti is a jewel in the rough
SnowYeti's Avatar
Great write up! The only thing you might want to add is to be very careful not to pull the clock spring off.
Looks great. I get having that style wheel. Every time I drive my 4R back to back with my sports car I wish my Runner wheel felt as good.
Might have to bite the bullet.
2019 ORP, 6112/5160, Eibach load leveling springs #250, Cornfed 1/2 in front spacers, JBA UCA, RCI alum skids, TRD Pro skid, TRD Pro grill, TRD Pro valances, Baja S8 30”, 3x Baja LP4 and Baja fogs, Rays 10, Toyo AT3 185/55, Canvasback, tinted windows, clear mask, UpTop Alpha rack w/ custom fairing, Borla, AFE CAI, URD MAF, Switch Pros, Power Trays, single ARB, rod vault, iKamper X-Cover, 23Zero 270 awning, Baja scene lights, Baja S2 rear fog/camp lights, RSG KDSS skid and sliders, Coco Mats, Ellis shift knobs, C4 ladder, Kenwood DNX696S/iData link, Morimoto XB Gen2, Morimoto Tails, custom 80/20 platform with slider, RokBlokz XL, WeBoost, C4 Low Pro w/ high clearance, Warn VR10 with Factor55, etc
SnowYeti is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 11:16 PM #5
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
I replaced the clock spring on my girlfriends 2nd gen Tacoma and steps are pretty much the same to remove the steering wheel. Although I didn't need to use a steering wheel puller to get it off.
A few things I'd suggest
- I would remove the steering wheel nut and make match marks on the steering wheel and the steering spindle. That way when you put the steering wheel back on you know where it's centered. Each spline is about 10-degrees difference so if you get it off by 1 or 2 splines it's quite noticeably off centered. Once you make the marks you can put the nut back on if you're going to use a steering wheel puller.
- Torque the steering wheel nut back to spec. It's 37 ft-lbs. Torque specs are the same for both 2nd gen Taco and 5th gen 4R.
- Be careful not to turn the clock spring or you may lose or get where it's centered.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 12:28 AM #6
Cisco Kid's Avatar
Cisco Kid Cisco Kid is offline
Real Name: Jeff
Cisco Kid will become famous soon enough
Cisco Kid's Avatar
Real Name: Jeff
After seeing some posts elsewhere on this forum, I pulled the trigger on the all leather version of this wheel. It looks good right out of the box but the square shape of the grip is not comfortable. It’s almost as if someone cut out some plywood circles, rounded the edges a bit, and then wrapped it. For now, I’m sticking with the oem wheel.
DIY REVESOL Hydro-Dipped Carbon Steering Wheel Install-e136bd93-a78d-4c16-a3a2-3b12f9b5acbd-jpeg
2015 Limited, bone stock for now
Cisco Kid is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 12:17 PM #7
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
Pm sent.
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 10:18 PM #8
energie energie is offline
energie is on a distinguished road
can someone post the ebay link to this, i can't find it. thank you.
2017 4Runner TRD Pro - Cement Grey
energie is offline   Reply With QuoteReply With Quote
Old 07-26-2020, 10:23 PM #9
Cisco Kid's Avatar
Real Name: Jeff
Cisco Kid's Avatar
Real Name: Jeff
It looks like they are sold out again. Check eBay in a couple weeks and they will likely have more.
remove , screw , steering , step , wheel
Revesol/CarTrimHome/eBay (Faux)Carbon Steering Wheel Replacement jaemz 5th gen T4Rs 1 05-16-2020 03:16 AM
XUJI leather steering wheel cover install. Goodbye plastic steering wheel. OEM? Kelbad 5th gen T4Rs 24 05-19-2019 03:51 AM
Show me your hydro dipped parts! TejasRunner01 3rd gen T4Rs 10 09-18-2017 08:22 AM
Steering wheel wobble after new suspension install Jon148 4th Gen T4Rs 7 03-23-2013 11:48 PM
HU/steering wheel cntl. install question Bluedevil Engines / Suspension / Wheels / Tires / Audio / Accessories 29 04-16-2007 11:51 PM
