Old 07-05-2020, 11:54 AM #1
rockwind1 rockwind1 is offline
rockwind1 is on a distinguished road
start engine, suddenly driver hi beam goes out and dome light is flickering
after having been installed back in '16 and working fine for a few years,, just out of the blue,,,,,,with 42k miles, i start up car,, it is just idling, and the high beam flickers for a bit and then just goes out,,,also, the push dome light near the crawl control console,, it is also flickers,,,,also,,, whenever i hit my ditch light switch, the dome light dims,, when i shut off ditch light switch,, the dome light flickers and then goes back to normal brightness.
i assume the hi beams are led's,, i actually am not entirely sure,,, they are called HID,,, all the choices are like H1, h3, h7,h13, and so on. i will find out exactly which ones,,, looks like they are more halogen type than led. oopss..
what the heck,,, any one have experience in this area?
these are expensive aftermarket custom led's from a place called aiden james customs llc. i do have a "website message" thing into them but am trying to figure it out on my own.
on a side note,, what is up with these business that have websites and the only way you can contact them is thru the stupid "message" thing on their website vs an actual email.. am i the only one or does it seem like no one at the business ever answers those?
2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, home made magnetic paint protectors, bunch of recovery gear i never use, a mentally disabled driver, big stupid tires and a million gallon gas tank cause it's a 4runner
rockwind1 is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 12:23 PM #2
euser euser is offline
euser will become famous soon enough euser will become famous soon enough
Did you just install the LEDs or have you had them for a while? The power draw difference between LED and incandescent lights can cause different issues in set ups not designed/modified for them.
euser is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 12:31 PM #3
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
Originally Posted by rockwind1 View Post
so just out of the blue,,, with 42k miles, i start up car,, it is just idling, and the high beam flickers for a bit and then just goes out,,,also, the push dome light near the crawl control console,, it is also flickers,,,,also,,, whenever i hit my ditch light switch, the dome light dims,, when i shut off ditch light switch,, the dome light flickers and then goes back to normal brightness.
and that might be your problem...
When did you install what?
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 02:03 PM #4
kcp1158 kcp1158 is offline
kcp1158 is on a distinguished road
Did you replace the high beam headlights with LEDs? Most LEDs don't work well with Japanese vehicles due to the low current draw with the daylight driving lights. If this is something you did put the regular bulbs back in and see if you still experience the same issues.
kcp1158 is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 02:55 PM #5
cb1111's Avatar
cb1111's Avatar
At this point we don't have enough information to make any kind of suggestions. We know nothing about the car (year, trim etc.) and even less about the mods except that he installed something from Aiden James at some point.
We also know that AJ is living up to their reputation of not responding.
The OP needs to respond with:
Year/Trim
List of mods
When what mods were installed
After we have that information is when we can start to try to help him.
Old 07-05-2020, 02:57 PM #6
Mudhorn's Avatar
Mudhorn Mudhorn is offline
Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough Mudhorn is a jewel in the rough
Mudhorn's Avatar
Definitely sounds like a power draw issue. Not sure why the ditch light would draw power away from the interior light. Unless it is the switch light, which is a very low draw.
Have you replaced any of the other interior bulbs or any of them have the same issue?
I would check the fuse for the hi-beam.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
Mudhorn is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 03:17 PM #7
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Just a suggestion here - when you do mods, document everything and keep in a notebook for future ref and troubleshooting. If wiring is involved, make a diagram and color code and/or label your wires. You might also make a drawing and notes on how they are run. Note where you got your parts, etc. with contact info in case you need something in the future. Save any instructions too. Take pictures of the install and anything else that is important to what is being done. Even if you don't need this for future issues; it makes for a good selling point to the next owner. For electrical mods, take measurements with a meter: continuity checks and resistive measurements, followed by power on voltage checks and then system operational checks. Then you'll have a baseline to go by and a reference for future issues.
Old 07-05-2020, 04:06 PM #8
good point,,, they have been installed for a long time,,, like 3 or 4 years,, 35k-40k miles ago. this is a new development.
Old 07-05-2020, 04:09 PM #9
wouldn't the fuse affect both sides hi beam?
have not had any other probs
Old 07-05-2020, 04:16 PM #10
Year/Trim
List of mods
i actually have just recieved a email back,, on a sunday, so i responded back with more details and am awaiting reply. i would not expect a reply on a sunday so that seems promising.
sorry for not putting in more detail,, thought most of my mods were in my signature line. but it is a 2016 4runner trail KDSS, 3" icon lift w/ uca's, Icon rims, Falkens E rated, 10k smitty winch, heftyfab alum front bumper, heftyfab sliders, frontrunner roof rack, ARQ awning, LED lights everywhere, everything done back in 2016
it is these 2 kits from ajc
AJC HID Kit – Aiden James Customs
2010+ Toyota 4Runner Interior Lighting Kit – Aiden James Customs
no other elec mods other than a small light bar on front bumper, and ditch lights,, and some fancy back up lights
Old 07-05-2020, 04:20 PM #11
i just assumed they were led's,,, but i guess not,,, some sort of HID bulb,,,my bad. i do not have originals
Old 07-05-2020, 04:25 PM #12
excellent suggestion,,,but i bought this rig from the original owner with about 28k miles on it,, down in phoenix. he had already done all this work or had it done within the first 5k-10k miles,, around 2016-2017. i'm 55 and smarter than the average bear and i checked it out pretty good, he was a decent guy,, talented, and did a good job on anything he had done. so anyway, i don't have those original measurments with a multi meter when the work was done sadly.
Old 07-05-2020, 06:14 PM #13
cb1111's Avatar
cb1111's Avatar
So it looks like some mods were done several years ago and then you made some mods.
What are the last two electrical mods you made and when?
Old 07-05-2020, 07:31 PM #14
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Does this happen all the time, when truck is not running, or only when you start it and run it? Is it repeatable every time? Intermittent?
It sounds like an electrical connection that loosened up somewhere and makes an intermittent connection with the vibrations of the vehicle. You’re going to have to trace some wiring to track this down. Start with any circuits that have this problem. They might share a common wire to +12V or Gnd. Suspect any crimp, twisted wire nuts, wire taps, electrical taped junction, wire attached by a screw to chassis ground, or anything looking to be not OEM. Good luck.
Old 07-05-2020, 09:07 PM #15
Mudhorn's Avatar
Mudhorn's Avatar
There is a fuse for each side. Should be 10amps. Engine compartment fuse box. Spot 16 and 17 on my ‘18 ORP
dome , light , message , thing , website
Auxiliary high-beam tap to relay, lights flickering in DRL mode mynameistory 5th gen T4Rs 1 03-03-2020 09:36 PM
Driver door light / dome light problem LRT 5th gen T4Rs 8 01-02-2020 10:25 PM
Dome Light/ Driver front Door switch issue 4wheelin86 3rd gen T4Rs 4 03-19-2019 09:16 PM
Argh! Ready to go, and suddenly won't start! Bmerr98 Classic T4Rs 16 11-27-2017 05:51 PM
No driver controlled Dome light??? Are you Kidding me! JJMAC 5th gen T4Rs 83 01-19-2011 10:27 PM
