Originally Posted by Justin.Geer81
The beasts look amazing! But the damn things will hold 80 psi! Have them at about 35 right now ... just wondering if I should be running them higher?
I’ve always run the sidewalk psi ... but 80 just seems so damn high
Thoughts?
285/75/17 size on a 4runner obviously ...
80PSI is the max. No need to go to 80psi...Check the manufacturer's load inflation tables to see if 35psi is good for the amount of weight you're carrying (I have a feeling 35 should be fine).
Toyo's article on determining PSI: https://www.toyotires.com/media/2125...s_20170203.pdf
Thread with some discussion of it: Load Inflation Tables and Correct PSI
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
