Old 07-06-2020, 01:16 PM #1
keyser_soze's Avatar
keyser_soze keyser_soze is offline
keyser_soze is on a distinguished road
Help with bump stops and rear airbags
I recently bought a small travel trailer and I have decided it is time to upgrade my suspension. I do not rock crawl or do anything crazy. I mostly do overlanding while camping, trails on rivers and beaches, fire roads etc...
My trailer is the NuCamp Tag XL Boondock is about 1450lbs dry, 1700lbs loaded. The tongue weight is probably around 220lbs. It has trailer brakes, and I have a redarc controller.
While parked I get a little sag in the rear which gives me a reverse rake. This also causes my hitch to be a little lower than ideal, which gives my trailer a slight forward rake.
While driving the trailer is very light so it does not give me many issues. I do notice its weigh going up hill. I will sometimes get a front to rear bounce when going over higher speed bumps. No sway
While pulling the trailer the cargo are of my 4Runner typically has nothing in it besides 3 dogs (170lbs total) and a cooler for drinks. I do have Rago cargo window storage, and a raingler attic loaded with a few things, and a 10" sub (probably around 50lbs total)
2015 SR5 4WD no 3rd row, no cargo tray, LFD 3/4 roof rack
CURRENT SETUP
Front:
Bilstein 5100 set to 2.5"
OEM UCAs
OEM springs
OEM bump stops
Rear:
Bilstein 5100
Daystar 1.5" spacer
OEM springs
OEM bump stops
NEW SETUP
Front:
Bilstein 5100 set at 0"
JBA UCAs
Dobinson 2.5" springs
Energy bump stops
Rear:
Bilstein 5100
Dobinson 1.5" springs
Bump Stops ?
Air bags ?
My questions:
With the new rear springs Im hoping there will be less sag in the rear. Which will also keep my trailer more level (less tongue weight). Which I assume would help with the front to rear bounce as well. I assume the slightly stiffer springs would help with the bounce in general as well.
Do I really need airbags or Timbren SES for such a light trailer?
My worry with the Timbrens is that it would limit travel. Im not too worried about airbags, and I already have a compressor under the hood.
My next question would be the rear bumpstops. I saw a few people that used the Lexus / 4th gen air suspension bump stops. These are cheap and seem to suit a 1.5" lift. The other option is Durobumbs but the DBR35 which are for under 2" lifts, but they are more expensive and only available from a few vendors.
What do you think is the best option for the rear?
2015 SR5 Premium Bilstein 5100 | Dobinsons Springs | SCS SR8 | 285 Toyo Open Country AT3 | Trail Rack | TRD Intake | Borla Side Exit Exhaust | TRS LEDs | JBA UCAs | CTH T9 | Pioneer 9605 AMP | Scanspeak tweeters, Kicker 6x9s, Dayton HO 10"
keyser_soze is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 03:23 PM #2
AggieOE's Avatar
AggieOE AggieOE is offline
AggieOE will become famous soon enough
AggieOE's Avatar
I've heard good things about Air Lift and am thinking of giving them a try when towing. Nothing worse than reverse rake and blinding traffic because of towing or loading up the rear for trips.
2015 4Runner SR5 4x4, Bilstein 5100s at 1.75-F with 1.5" Cornfed-R, AirLift 1000 Airbags, 265/70 BFG KO2s, Shrockworks Sliders
2016 Jeep Wrangler Unlimited Rubicon
AggieOE is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 06:26 PM #3
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
Coil rite
I put Firestone coil rite Bags on my t4r and couldn’t be happier. Less than $100. I packed my rig For a trip to Yellowstone. Was super heavy, carry rear drawers full, RTT and a hitch mounted shelf carrier loaded Up. Probably 400 lbs in the back. Bags were at 12psi and I had no issues at all for a trip that went 1300+ miles.
Help with bump stops and rear airbags-a9164718-781e-431d-8a7c-9d3694a0f6b8-jpg
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Jpilot is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 12:21 PM #4
OK I will look further into airbags.
Old 07-07-2020, 10:59 PM #5
timbren-industries's Avatar
timbren-industries timbren-industries is offline
timbren-industries is on a distinguished road
CURRENT SETUP
Front:
OEM UCAs
OEM springs
OEM bump stops
Rear:
Bilstein 5100
Daystar 1.5" spacer
OEM springs
OEM bump stops
NEW SETUP
Front:
JBA UCAs
Energy bump stops
Rear:
Bilstein 5100
Bump Stops ?
Air bags ?
My questions:
You have it right! It totally depends what you are primarily using your rig for, but we have 2 options like you already mentioned, Active Off Road Bumpstops or SES (suspension enhancement system). SES if you want to eliminate sag or go with a stiffer rear coil and run Active Off Road Bumpstops so you can still "offroad" and keep your travel.
Hope this helps, be happy to answer any questions as well! Whatever you decide, good luck and enjoy!
Ps. Nice rig!
timbren-industries is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 11:08 PM #6
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Installed airlift bags on my old bosses c10 so he could carry two dirtbikes. Never heard of an issues arising. Super easy install. Prob not that helpful to you but it's something.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 12:29 PM #7
I think the SES is overkill for my application. I also only pull the trailer a few times a year.
A standard bump stop is probably what I will be looking for, but I think I am looking for something a little cheaper.
I used to use airbags at my old job where we had full size trucks and pulled large trailers. I cant recall ever having any issues.
I just didnt know how airbags affected off road performance, of if they were just not needed for my small trailer.
Old 07-08-2020, 04:55 PM #8
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
To OP: Agreed with others: get the Airlift.
Had it on my 4th gen 4Runner for about 8-9 years- worked great with no issue at all.
Heaviest trailer I towed with it was about 4800 LBS and I can make rear end of the 4Runner higher with the trailer vs. empty by having 27 PSI in the Airlift. All that was on OEM springs and shocks.
If you interconnect airlift bags together and run them a minimum pressure (5 PSI) I do not believe you can quantify any negative impact on off road performance.
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:45 AM #9
I ordered everything. I think this will be good for a budget setup
Air lift 1000 $85
Lexus rear bump stops $85
Energy front bump stops $28
bump , rear , springs , stops , trailer
Energy Suspension 8.9104R rear bump stops in place of front bump stops Akkording 5th gen T4Rs 66 01-16-2024 12:10 AM
rear bump stops Herculean T4R 3rd gen T4Rs 2 01-08-2018 12:20 AM
Rear bump stops raygenjay 4th Gen T4Rs 2 06-19-2017 12:30 PM
Folks Towing/Hauling -- Any input on Airbags vs. Timbren Bump Stops cajone5 4th Gen T4Rs 11 06-26-2016 09:31 PM
Rear bump stops WXman 4th Gen T4Rs 10 10-16-2013 04:59 PM
