Old 07-06-2020, 02:35 PM #1
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
A/C Refresher??
I typically do the general maintenance on my vehicles, but the 4R is still under factory warranty and I've got 2 more free oil changes (these guys actually do a good job with that)..
Anyway, while waiting today for my 15K service, I get a message about recommended services. With a full inspection report, along with pictures (fancy)I'm sure it's common now, but it's the first time I'd ever seen it when going in for service..
The list had the normal things, alignment, cabin filter, air filter, rear wiper replacement (not sure why I never use it) and finally A/C refresher...
I declined everything except for the alignment, I can get both factory filters online for less that the price of the engine filter replacement.
What I was curious about was the A/C refersher..My A/C is working fine, trust me I'm in Florida, I'd know if there were any problems..So what gives on the A/C refresher service?? I mean if they have to add refrigerant it's leaking and then that would mean there was a problem with the system in general that should be covered under the warranty..Thoughts??
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:36 PM #2
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Mine blows ice cold at over 7 years.
Unless it gets physically damaged, there's no reason to top it off or mess with it at 2 years.
I'd add that they shouldn't be ****ing with the AC refrigerant for any reason since you can vent off some of it if you want to check the pressure in the system.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:43 PM #3
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
do it yourself for 15 dollars
Amazon.com: Lubegard 96030 Kool-It Evaporator and Heater Foam Cleaner: Automotive
1jzgte is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 02:59 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
In a word ... Upsell
The Service Department is trying to create work (and generate money) for itself.
Both cabin and air filters can easily be changed by the DIYer. The rear wiper blade can also be switched out DIY (although it is a little tricky). Source the filters/blades from your preferred vendor and install yourself to save the labor charges.
I have not heard of the A/C Refresher "upsell" before, perhaps that is a warm-weather Florida thing ;)
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 03:12 PM #5
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
I also have never heard of an "A/C refresher" service--they are just looking for $$$ As LandCruiser stated the service dept. should not be touching your A/C system unless you are having a problem. These systems will run for many years without needing anything. You stated your system works fine so I would leave it alone.
Dealers in my area want to do an "evap cleaning" every year which you can do yourself with a product like 1jzgte mentioned. The charge for that at dealer here (AZ) is $125. Crazy.
TOYO74 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 03:27 PM #6
Whippersnapper02's Avatar
They're just trying to get money. Car AC systems are sealed and don't need regular service minus condenser cleaning which can be done by a hose and cabin air filter changing if equipped. There is oil in them but it's more trouble than it's worth to change it. Also it doesn't get dirty like in an internal combustion engine.
Old 07-06-2020, 03:31 PM #7
Blue 4ever Runner's Avatar
Blue 4ever Runner Blue 4ever Runner is offline
Real Name: Jim
Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light Blue 4ever Runner is a glorious beacon of light
Real Name: Jim
This^
2019 Nautical Blue SR5. Mostly stock but a few mods: Borla muffler, blacked out badges, removed the running boards, painted the silver roof rails with bed liner, painted the wheels gloss black, Weather Tech window deflectors. AFE replacement air filter in stock air box & removed the charcoal after filter, DC Sports exhaust tip. H11 to H9 headlight bulb swap. 265/70/17 Falken Wildpeak AT3W tires, Sprint Booster, 1" Cornfed leveling lift.
Blue 4ever Runner is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 04:36 PM #8
VincentGsrq's Avatar
VincentGsrq VincentGsrq is offline
Real Name: Vince
VincentGsrq is on a distinguished road
Real Name: Vince
My guess is a new cabin air filter and wipe out (sanitize) your ducts by the evaporate or whatever then can easily access, they may even pull your glove box and not just swing it done
VincentGsrq is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 04:55 PM #9
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
with all the above replies. Service writer on commission? Your T4 is too new for all that.
It's not freon, that was an old trade name by Dupont for R12. We use R134 refrigerant now.
I checked my old 2013 A/C system last year and the high and low pressure were all where they should be after 60K and 6 years.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 05:05 PM #10
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
I agree with everyone else. My experience over many Toyotas has been that they cool great beyond 10 years. My 2019 is already at 45k and my dealership hasn't upsold me one thing.
thennen is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 06:33 PM #11
judami judami is offline
judami is on a distinguished road
The service writer did their job. Every time you show up for your "free" maintenance is an opportunity to sell you something at a very high margin.
judami is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 10:32 PM #12
cb1111's Avatar
cb1111 cb1111 is offline
cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold cb1111 is a splendid one to behold
cb1111's Avatar
This is my canned response to the dealership.
"Thank you for pointing out these maintenance items. I'll be glad to do the filters and the wiper myself later.
Gee, it is unfortunate that the AC has a low charge. This means that there is a manufacturer's defect that needs to be resolved under warranty. Do you mind if I use your phone to call Toyota customer service and get that repair authorized under warranty, because I'm sure that you wouldn't be trying to sell me an unnecessary service?"
When in trouble - obfuscate
cb1111 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 11:38 PM #13
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Pretty pricy - I guess they really like their stuff. $50 plus for a wiper and cabin air filter - really? Make the price high enough and you'll never have to do the work.
Old 07-07-2020, 12:07 AM #14
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
It gets sprayed into the vents with the A/C on, it’s suppose to clean out the evaporator and give it a nice fresh scent. I doubt they would charge so little to evacuate and recharge the system. You won’t get any benefit out of it.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 12:10 AM #15
He needs that service ASAP or else the A/C could stop working while he’s on a trip and we wouldn’t that to happen.
a/c , filter , general , refresher , service
