Old 07-06-2020, 04:02 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Air Compressor Hose and Fittings
Currently running a Viair 400P air compressor. This is the regular model, not the automatic version. The coil hose that it comes with sucks and is too stiff and gets tangled easily. The air chuck is also a clamp on style and is hard to keep on the valve stems and requires me to hold it tightly sometimes.
Is there a way to put together a different hose and quick connect chuck? I tried Google and came across a thread on another forum with people replacing their Viair hose with a 1/4" Flexzilla hose and adding an open flow "clip-on" chuck. That forum thread is over 5 years old and didn't include specifics on how to piece the parts together.
I attached a picture of what mine currently looks like.
Air Compressor Hose and Fittings-viair-400p-jpg
Chilow is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 07:04 PM #2
choochoo choochoo is offline
choochoo will become famous soon enough choochoo will become famous soon enough
Quick connect to compressor
Milton (S-716) 1/4" Male NPT M Style (Industrial) Air fitting Quick Connect Coupler - Garage And Shop Products - Amazon.com
Wrap with plumber tape and connect to female barb
Anderson Metals Brass Hose Fitting, Connector, 1/4" Barb x 1/4" Female Pipe: Amazon.com: Industrial & Scientific
Connect female barb to 1/4” air hose (take your pick)
Amazon.com: Flexzilla HFZ1450YW2 1/4" (inches) x 50' (feet) Air Hose, 50 ft, MNPT Fittings, Heavy Duty, Lightweight, Hybrid, ZillaGreen-HFZ1450YW2, 1/4" (inches) x 50' (feet): Automotive
Secure hose to barb with worm gear clamp (forgot size)
Amazon.com: LOKMAN Hose Clamp, 60 Pieces Stainless Steel Adjustable 6-38mm Range Worm Gear Hose Clamp, Fuel Line Clamp for Plumbing, Automotive and Mechanical Applications: Garden & Outdoor
Cut hose to length and secure a male barb... thread on quick connect with plumbers tape
Anderson Metals 57001-0404 Brass Hose Fitting, Adapter, 1/4" Barb x 1/4" NPT Male Pipe: Garden Hose Parts: Amazon.com: Industrial & Scientific
https://www.amazon.com/dp/B01938M8MW..._E8pbFbNJDH2DX
I personally use a 4-way inflator https://www.sheldonchuphotography.co...flatordeflator
choochoo is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 07:27 PM #3
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
Head to Harbor Freight and find all the stuff you want. If you don't need hose length, you might look at a 3'-5' whip hose.
3/8 in. x 5 Ft. Swivel Whip Air Hose
3/8 in. x 3 ft. Air Hose Lead
Add quick disconnects to everything that way you're not limited to one option and you can quickly switch parts that go bad or connect to something else, like a tank.
These things make is easy to move around to when airing up tires.
1/4 in. Male Industrial Swivel Plug
Note that there are different types of disconnects. HF and Lowes both have Industrial or Universal. Supposedly the Universal will fit in the Industrial, but I haven't tried that. It doesn't matter which one, just get the same type. Make sure you know which ones fit when you need replacement parts.
itr1275 is offline   Reply With QuoteReply With Quote
air , chuck , hose , thread , viair
V8 Radiator Hose - Silicone hose replacement? t-rex grrr 4th Gen T4Rs 3 10-16-2015 12:14 AM
Problem - Missing Hose and Loose Hose Splashsky Classic T4Rs 2 04-07-2014 06:06 PM
03 Zerk Fittings moreland01 Maintenance/Detailing 2 12-02-2008 07:10 PM
Which water pump? Hose or no hose? Daveed Classic T4Rs 3 10-16-2006 01:15 PM
Grease Fittings on '05 4x4 Jeff Kleb 4th Gen T4Rs 6 03-05-2006 07:26 PM
