Old 07-07-2020, 05:14 AM #1
Doc_Fry's Avatar
Doc_Fry Doc_Fry is offline
Real Name: Steve Fry
Doc_Fry is on a distinguished road
Doc_Fry's Avatar
Rear Hatch Window Woes
When it rains it pours. Not only did I crack my front windshield, having radio gremlins, SRS light is on, need to replace front shocks and figure out the shaky steering wheel issue. Seems as if this past weekend while out at the lake my rear window quit working. It would not roll all the way up and would roll back down automatically. I was able to force the window up manually after removing the panel and disconnecting the switch for now. But would like to get this foxed. Luckily I do have an extended warranty that was free with vehicle purchase. But the dealers are over an hour from me. Any thread/videos/tips on how to troubleshoot and repair this issue? Not something I am very familiar with. Not to mention there is not not much area to work with here and would rather not bust the glass. thanks.
15 TRD Pro Build Thread - OIF 09-10 - Combat Disabled Army Veteran - Purple Heart - Combat Medical Badge
Note: Dont get all butthurt because my grammar is terrible. See above and consider this before you stick your foot in your mouth. Also, I do post from an i-Device so words tend to get garbled and misspelled. I cant believe I have to out this here.
Doc_Fry is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 06:34 AM #2
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
Check to see if something is blocking the window frame if debris clogs the flow it will reverse down It might be for child safety
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 07:42 AM #3
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Only thread I could find with a similar issue in a 5th Gen:
Rear window help!
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 07:57 AM #4
nb rob's Avatar
nb rob nb rob is offline
nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice nb rob is just really nice
nb rob's Avatar
from the manual; "when the power back window does not close properly":
...initialize the function by performing the following procedure:
1. hold the power back window switch in the one-touch closing position. Continue holding the switch for a further 6 seconds after the window has closed.
2. hold the power back window switch in the one-touch opening position. Continue holding the switch for a further 2 seconds after the window has opened.
3. hold the power back window switch in the one-touch closing position once again. Continue holding the switch for a further 2 seconds after the window has closed.
if you release the switch while the window is moving, start again from the beginning.
if the window continues to close but then reopen slightly after performing the above procedure correctly, have the vehicle inspected by your toyota dealer
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 10:37 AM #5
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
with the extended warranty, I'm curious, how many things need to be wrong before you take it to the dealer?
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 07-07-2020, 10:44 PM #6
Doc_Fry's Avatar
Doc_Fry's Avatar
Difficult when your not only a disabled veteran, retired, only vehicle and the dealer is over an hour each way. Not really can I leave the vehicle overnight or even afford a rental vehicle. So I do most if not all that I can myself. If I cannot fond a simple solution then indeed I would have to take it in. Other issues where nothing I really would ave noticed except a crash and non deployment of the drivers airbag. With the rear window inop it is more than an inconvenience when I drive around with my service animal in the back. But to ask such a question is weirdly funny to me. As everyone has their own circumstances. it may be quite an easy thing for you to just go to the dealer. But at least in mine it become more than a chore and it only compounds from there. Seeing the forest theough the trees.
Anyways thanks for the responses Ill go through the other thread and see if anythings there. Ill double check to see if I can see anything in the tracks I did look and honestly felt as of the window came off track a bit.. dunno for sure In the end the dealer maybe my only choice. Worst thing is that I have been wanting to move to a new vehicle platform within the next year or so. Payed off and like being able to save up extra for mods on next vehicle. I just hope I have the patience to just go through the motions and get it back to normal and have time to follow the path I want.. not to give in and say f it and just go buy a new truck,
Old 07-08-2020, 01:16 AM #7
krunkula krunkula is offline
krunkula is on a distinguished road
Your dealer should give you a loaner or courtesy car. You shouldn’t need to pay for a rental car.
krunkula is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 05:33 AM #8
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
My dealer is also 1.5 hours away. Nearest stop light is 40 miles away. That is one of the joys of living in the sticks.
I'd get an early appointment = 9am with the dealer (use their website to setup the appointment) and sit and wait for them to fix it.
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 08:02 AM #9
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I know how you feel. My Toyota dealer is a bit over an hour away, but they have a Ford dealership closer.
Their Ford dealership is 20 minutes away, at the closest signal lights.
Fortunately we have several vehicles as backup for situations like this.
I really hope OP gets it working.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 09:58 AM #10
mbm112 mbm112 is online now
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
Many extended warranties have provisions allowing you to take the vehicle to any certified shop if it is not practical to go to the dealer. Check into that.
Sent from my Pixel 4 XL using Tapatalk
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is online now   Reply With QuoteReply With Quote
Old 07-08-2020, 01:09 PM #11
Heavy_GD's Avatar
Real Name: GD
Heavy_GD's Avatar
Real Name: GD
Originally Posted by Doc_Fry View Post
Difficult when your not only a disabled veteran, retired, only vehicle and the dealer is over an hour each way. Not really can I leave the vehicle overnight or even afford a rental vehicle. So I do most if not all that I can myself. If I cannot fond a simple solution then indeed I would have to take it in. Other issues where nothing I really would ave noticed except a crash and non deployment of the drivers airbag. With the rear window inop it is more than an inconvenience when I drive around with my service animal in the back. But to ask such a question is weirdly funny to me. As everyone has their own circumstances. it may be quite an easy thing for you to just go to the dealer. But at least in mine it become more than a chore and it only compounds from there. Seeing the forest through the trees.
Funny how a simple question has to be so dramatic.
I guess every retired, disabled, low on cash, country living, MOS handles situations differently.
and in case no one said it today, we all thank you for your service.
'16 SR5 Premium
Old 07-08-2020, 08:37 PM #12
Doc_Fry's Avatar
Doc_Fry's Avatar
Okie dokey if you say so. Weird but have a good day. Poster who is supposedly better than others. Oh no thank you for your service. Guess you must have your shit together and I dont? So funny how our perspectives are much different on things.
Pretell Why would one drive 2hours cash strapped nothing to do with it. In only vehicle if one can fix it in the comfort of their driveway?
Old 07-08-2020, 08:39 PM #13
Doc_Fry's Avatar
Doc_Fry's Avatar
this would be a good thing if they did. Never have been offered by dealer. But if I have to end up taking it in.I may push this and find a dealer willing to do so
Old 07-08-2020, 08:42 PM #14
Doc_Fry's Avatar
Doc_Fry's Avatar
An option for sure. Again get compounded. Have service dog will travel. Not something easy to sit around for. Another poster mentioned that I should push the loaner vehicle. If this cant be done in driveway and I have to go to the dealer Ill try this route instead.
Old 07-08-2020, 09:15 PM #15
4Runner&Airstream 4Runner&Airstream is offline
4Runner&Airstream is on a distinguished road
Smile
Earlier someone said that the manual said...
Is there an online set of manuals somewhere?
2013 Toyota 4Runner SR5
4Runner&Airstream is offline   Reply With QuoteReply With Quote
front , issue , rear , roll , window
Rear window woes GearJunkie88 5th gen T4Rs 12 10-04-2018 08:22 PM
Rear Hatch Woes... sharpe97 3rd gen T4Rs 2 10-07-2014 10:48 AM
92 hilux (4 runner) rear window woes SmirnofSoldier Classic T4Rs 5 09-30-2013 01:25 PM
Rear window wiring woes TrueNorthist Classic T4Rs 7 08-15-2013 10:01 PM
Rear Window Woes Swimmerboy2112 3rd gen T4Rs 7 07-22-2013 05:48 PM
