07-09-2020, 07:56 AM
#31
Originally Posted by Hungster44
With these instructions it will give us everything we need for 1 bar correct? It is not a set? So if we wanted say 4 bars we would need to increase the quantity? Also what is the load strength on these bars? I would look to add a 180lb RTT plus people in it of course. Thanks!
Electroboy is correct. You will need to order 4 individual bars when you make an order to Tnutz.
As far as the loading, in a static condition the bars and brackets will hold in excess of 1000 pounds. I'm a pretty large guy and I mounted up the brackets on a bar put it on the ground and lightly shifted my weight on it. The bar will flex a bit but no issues. I weight about 280.
The bolts have a yield strength of 65k PSI. At this point the weakest part will be the rails. As Electroboy stated the listed rating is around 150 pounds with the factory rails. Once installed the rack setup is remarkably solid. I think that actually knowing the weight it would hold would require destructive testing and I'm not ready to offer my wife's 4Runner up to the gods of knowledge just yet.
If I had to take a guess, I'd say it would hold a rooftop tent and occupants. The failure mode would have to be a deformation of the rail itself. Between the rail and the mounting point I think it's the weaker link but I think it will carry a significant amount of weight before that happens.
07-09-2020, 03:19 PM
#32
Real Name: Joe
Real Name: Joe
Order?
I am ordering today, but want to make sure I get this right. I order 4 crossbars, to the specs given in the previous post, easy enough. Then I order a set of 4 brackets? Or 2 sets of 4 brackets?
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
07-09-2020, 04:34 PM
#33
One set of 4 brackets. That’s all the brackets you’ll need for 4 bars.
07-10-2020, 01:35 AM
#34
Real Name: Joe
Real Name: Joe
Ordered
Just ordered. I look forward to getting this put on, looks awesome so far...
07-11-2020, 09:52 PM
#35
Now my curiosity is getting the better of me. I want to do some destructive testing just to see what it will take to fail my rack system.
Anyone know where I can get a 5th gen pull off rack? I figure I could build a jig pretty easy and I have access to a tote tank. I could just fill it with water until it failed.
It would be an awesome experiment.
07-12-2020, 01:16 PM
#36
Interesting. In theory I could source a set of the “standard” factory roof rails, buy these brackets and extrusions and end up way cheaper than buying a $1000 aftermarket rack to replace my pro rack.
The issue I have with the pro rack is that it’s limiting me from lifting the vehicle, even by using larger tires, due to its excessive height off the roof that already hits the parking garage at work.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
07-12-2020, 06:09 PM
#38
Originally Posted by Eitek1
Honestly my first response was "yeah, I'm not messing with that". I do like a challenge though so give me a few days to think on it.
On second thought, what is the diameter of the bar? I think I might have an idea....
I just checked mine. The pro rack round bars are 1 3/4” OD.
07-13-2020, 03:55 AM
#39
NiseRack vs. Toyota's CrossBar
I'm thinking to buy a roof tent, Roofnest Sparrow that has a spect of 134lbs, for my 2016 T4R SR5, 5th Gen.
I think somewhere I read the 2 Toyota Cross Bars would give you the support for 130lbs.
Would these NiserRack give you more support/more weight they can handle with the 4 bars?
Trying to see if there's any +/advantage of going with these NiserRack, instead of the Toyota's.
Welcome your thought on this, & thanks in advance.
07-13-2020, 04:46 AM
#40
Banned
Real Name: Mark
Banned
Real Name: Mark
I don’t believe anyone uses the Toyota crossbars to mount a rooftop tent. They’re bowed and they flex. Their load rating isn’t great enough. But a lot of folks use aftermarket crossbars like Thule, LFD, or Yakima on the OEM side rails.
You can search for threads on the subject. Here’s one:
Final word on RTT on stock roof rails.
Load distribution over the four crossbars in a NiseRack configuration would be a better setup.
07-14-2020, 10:35 AM
#41
Real Name: Carlo
Real Name: Carlo
Originally Posted by ElectroBoy
I got an extra set of roof rails / caps if anyone needs them.
07-14-2020, 05:33 PM
#42
Let's do some destructive testing WOOOHOOO!
I'll send you an IM and we can arrange how to get them shipped here.
07-14-2020, 07:01 PM
#43
I've only had LFD Off Rack cross bars on stock rails And then switched to an entire LFD roof rack, so I can't really compare. But due to the design of these aluminum cross bars, do they retain water? If so, would there be any unforeseen issues? Perhaps I'm overthinking it.
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
07-14-2020, 07:56 PM
#44
I had a Prinsu rack and K9 rack for a while. Both uses aluminum T-slot. They retain a little bit of water afterwards but it dries up pretty quickly on a warm sunny day. I wouldn't worry about it. Plus you're still using OEM side rails so there won't be any water intrusion.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
07-14-2020, 08:45 PM
#45
What SN_85 said is correct. They may retain a little water but it shouldn't cause any issues. If the water was to seep out at the end of the bar it would just run down the face of the bracket and drop harmlessly on your roof. It wouldn't even have access to the inner part of your roof rail (which is open to the weather anyway).
If corrosion was an issue I understand. The only part that could possibly rust is zinc phosphate coated and is made for this type of application. Everything else won't rust or corrode due to the properties of the material.
What was your concern specifically? Maybe I can answer that better.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
