07-16-2020, 12:13 PM
#46
Order placed. Excellent product and thanks for saving us $$$.
Any intention to built bracket for awning ?
07-16-2020, 02:05 PM
#47
Real Name: BLACK TRD PRO
Any update on a fairing that would work up to 80mph unloaded?
07-17-2020, 01:05 PM
#48
Banned
Real Name: Mark
Banned
Real Name: Mark
Originally Posted by zalanreilly
I agree though, a windfairing option Nox Vidmate VLC would be nice but I think you can probably get one from LFD that would fit.
From what I understand, the wind faring is in the testing phase. I’m thinking there are a few designs he’s evaluating and I bet it will cost less than LFD’s.
07-17-2020, 01:41 PM
#49
What do you need and what does it need to look like, bolt pattern size etc. If we can figure on a good design, we can do it.
07-17-2020, 01:43 PM
#50
This is correct. I’m working out the prototype now. Once I’m satisfied a few folks will get them to test. Once I get their feedback I’ll list them for sale.
07-20-2020, 12:26 PM
#51
Definitely on the to buy list!!! Will order once you get the wind fairing up and running!!!
07-23-2020, 12:37 AM
#52
Real Name: Joe
Real Name: Joe
The rack is on! All I can say is, it is awesome. Fitment and design are right on. Rooftop tent will be going on next, and I am sure it will hold. This thing is solid. Only issue I had was one of the holes on the beam from TNutz was not drilled far enough in. Just need a shorter bolt for that one.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
07-23-2020, 04:31 AM
#53
Banned
Real Name: Mark
Banned
Real Name: Mark
Good job on the installation.
For that short hole in the crossbar, maybe it’s plugged with some aluminum shavings from the TNutz drill/tap process. One of mine came that way also, but I was able to clean it out with a thin probe. You could try cleaning up the threads with a 1/4 - 20 Tap. If the hole is actually not drilled deep enough you would need to first drill it deeper before tapping it. I believe the drill bit to use is a 13/64 inch.
@ Eitek1
will know for sure what to do.
07-23-2020, 09:59 AM
#54
So glad you like it. As I’ve said, I worked on this a while to ensure everything was right before I shipped anything. It’s hard to describe just how solid this thing is without seeing one in person.
Sorry about the short threaded hole on the crossbar. The threads are a 1/4-20 pitch. The holes already exist in the crossbars Tnutz just threads them. Chances are they didn’t run the tap deep enough.
If you pick up a 1/4-20 tap and some WD-40 you can run the tap in and you won’t even have to remove it from the roof. You’re also fine with a shorter bolt. You probably don’t lose much strength.
07-24-2020, 11:03 AM
#55
@ Jpilot
out of curiosity, how long did the install take you?
07-24-2020, 01:32 PM
#56
I installed last weekend. Took 30-45 minutes and I took my time.
07-24-2020, 01:39 PM
#57
Real Name: Joe
Real Name: Joe
Originally Posted by Eitek1
@ Jpilot
I did it mostly by myself, took my time and shot a bunch of pictures along the way. That said, less than an hour.
Straightforward and easy.
07-27-2020, 12:04 PM
#58
Real Name: Joe
Real Name: Joe
Tent on. Fits perfectly. Tent rails sit about 3 inches from the sides, so zero flex on the crossbeams.
07-27-2020, 12:10 PM
#59
Real Name: Joe
Real Name: Joe
Got some nice pics here too
07-27-2020, 05:02 PM
#60
Banned
Real Name: Mark
Banned
Real Name: Mark
Could you describe the mounting setup?
And some pics? Thx.
