Old 10-06-2016, 08:52 PM #1
Haydenatx's Avatar
Haydenatx Haydenatx is offline
Haydenatx is on a distinguished road
Haydenatx's Avatar
'15 headlights won't shut off
Recently my '15 trail headlights started acting up. I have the TRS HID kit.
When I shut off the truck and lock it the headlights remain on. They used to shut off in like 30 seconds or when double clicking the lock button.
I'm afraid the HID kit may be the root of it. Anyone else have this issue? I couldn't find any other threads about it.
2015 Super White Trail "The Yeti" | ARB 2000 awning | BFG T/A KO2 285s | Bilstein 5100 +Toytec coilovers @ 3" + SAW 1.5" rear coils | Gobi Ladder | Baja Flat Utility Rack | Tepui Atauna Sky RTT | Shrockworks sliders | TRS HID | Wilco Hitchgate solo Austin, Texas
Instagram
Haydenatx is offline   Reply With QuoteReply With Quote
Old 10-06-2016, 09:20 PM #2
Lexusbstrdchild's Avatar
Lexusbstrdchild Lexusbstrdchild is offline
Lexusbstrdchild is on a distinguished road
If you can't get them to shut off at all no matter what, my guess would be the relay in your kit is bad. If the coil on the relay isn't getting voltage, and the lights are on, then that is the problem.
2014 Mag. Grey TEP, 265/70/17 Duratracs, TRD wheels, Interior LEDs, Xenon Depot 4300k HIDs, Bilstein 5100 lift, OPOR sliders, Aurora 20" LED light bar.
Lexusbstrdchild is offline   Reply With QuoteReply With Quote
Old 10-06-2016, 10:00 PM #3
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
Sounds like the control circuit for the TRS HID kit is malfunctioning. It should be getting a signal from the headlight circuit, which would tell it "Turn off after 30 seconds, or when you Press Lock Twice" since a lot of those kits tap into the headlight switch circuit to activate the lights.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 10-06-2016, 10:25 PM #4
Haydenatx's Avatar
Haydenatx's Avatar
They'll shut off if I turn the switch in the truck to off. They just don't automatically shut off anymore. Thanks for the info! Sounds like I need to contact TRS.
Instagram
Old 10-06-2016, 10:28 PM #5
Haydenatx's Avatar
Haydenatx's Avatar
Thanks for the reply! Probably time to reach out to TRS customer service
Instagram
Old 10-07-2016, 12:00 AM #6
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Please be sure to post what you find.
Best Regards,
Saker
Old 10-07-2016, 12:34 AM #7
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Hi Haydenatx,
Make sure that the stalk selector switch is in the AUTO position; and not in the manual ON/OFF mode! If that checks out okay, disconnect the NEG battery cable for a minimum of four hrs... doing this will MASTER RESET the main body ECU compu network, and forcing it to function in it's default (factory) protocol parameters! Just like your windows OS every now-and-then, the computer needs an opportunity to delete it's temporary files and history logs stored in it's registry (Cashes); your ECU CANbus system stores temp files/hist-logs too! ...More than likely that's what is causing the problem, Please let us know!
rig, Cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 10-07-2016, 07:46 AM #8
SR5Bart SR5Bart is offline
Real Name: Bart
SR5Bart has a spectacular aura about SR5Bart has a spectacular aura about
Real Name: Bart
Originally Posted by rigtec View Post
Hi Haydenatx,
rig, Cheers!
No auto on/off lights on mine. I sometimes leave mine in the on position and the lights will go off like 30 seconds after I lock the car or right away if I press lock twice and I got an HID kit on mine as well. There has to be something wrong with his relays on the HID kit.
18 Trail. Cookie cutter built (SOLD)
14 SR5P (SOLD)
SR5Bart is offline   Reply With QuoteReply With Quote
Old 10-07-2016, 07:53 AM #9
Bikemedic Bikemedic is offline
Bikemedic is on a distinguished road
Do the parking lights stay on also? If so I would lean toward it being a problem on the 4runner programing side. If the parking lights go off, I would say its an HID kit issue..
Bikemedic is offline   Reply With QuoteReply With Quote
Old 10-07-2016, 10:35 AM #10
Haydenatx's Avatar
Haydenatx's Avatar
Ah! The parking lights do stay on (I just noticed that on the video above). Maybe I should unplug the neg terminal and let the ECU reset?
Instagram
Old 10-07-2016, 10:38 AM #11
invisible4Runner's Avatar
invisible4Runner invisible4Runner is offline
invisible4Runner is on a distinguished road
This has happened to me a few times, randomly. In each case I just had to start the truck up and shut it off again, and then they turned off as normal when I locked it.
It has not happened enough to bother me, and it's possible it's happened more than I realized - but maybe eventually shut off, as my battery has never died as a result.
2015 Barcelona Red
invisible4Runner is offline   Reply With QuoteReply With Quote
Old 10-07-2016, 11:22 AM #12
I would look at the program of the delay (instructions in owners manual) and make sure it is set correctly. If it is I would do an ECU reset.
Old 10-07-2016, 11:33 AM #13
Haydenatx's Avatar
Haydenatx's Avatar
Negative terminal has been unplugged. Now I wait... Will post update when finished. Thanks everyone for the input
Instagram
Old 10-07-2016, 04:56 PM #14
Haydenatx's Avatar
Haydenatx's Avatar
Alright, resetting the ECU by unplugging negative terminal for 4 hours worked!
It sputtered on the first start up and died. But on the second go it started up and remained running. Flipped the lights on, shut down the engine and everything was back to normal.
Thanks again for everyone's help!
Instagram
Old 10-10-2016, 01:55 PM #15
Haydenatx's Avatar
Haydenatx's Avatar
Welllll it happened again unfortuntely. I shut the truck off this morning and walked away. Double clicked the lock button on the remote, it locked but the lights stayed on. I started the truck and shut it off, tried again and it worked. This is sketchy.
Instagram
Do the headlights shut off automatically? Y2KSR5 3rd gen T4Rs 27 12-26-2022 02:42 AM
Brief AC Shut-off Muddy Duck 5th gen T4Rs 4 07-23-2014 11:58 AM
Air box boredom (and how to keep it shut) mtthwdotcom 3rd gen T4Rs 9 04-29-2012 12:27 AM
Shut off in traffic, please help! benhar 4th Gen T4Rs 1 07-07-2010 10:20 AM
Auto shut-off headlights Koz 4th Gen T4Rs 7 02-12-2005 03:15 PM
