07-08-2020, 04:26 PM
#16
Originally Posted by scionicboom
I just put ATX 285s on mine and it shook slightly at 40-65mph. It wasn't bad enough for me to worry too much about it but after about 500 miles of driving around town the shake started to go away.
I run mine at 36 psi and have just front Bilstein 5100s
at at 1.75".
I don't know about you but I had to trim quite a bit to get these tires to fit. I removed the mud flaps, moved the fender liners forward, and trimmed the bottom of the bumper close to 2 inches.
I have 5100's in front and rear, fronts at 2.5". Ran may falken 265's for 2 years without a single wobble.
I too modded the liner and removed the mudflaps
07-08-2020, 04:29 PM
#17
I know this is a longshot but I recently removed the toyota logo centercaps on the rims prior to installing them....possible can be related to the wobble?
07-09-2020, 11:01 AM
#18
No, shouldn't cause a problem. I ran my stock rims with no centers and now with my aftermarket rims with the ATX tires I run them without centers, but I did run them with the centers for a couple days. Doesn't make a difference at all. Just aesthetic.
07-09-2020, 11:35 AM
#19
Will try this thanks for the tip
32 seems low. For C rated I run 40psi.
07-09-2020, 02:54 PM
#20
used to run 40 for c load 285, dropped it down to 35/36 for the last few thousand miles and havent noticed any issues with wear and the ride is significantly better.
07-09-2020, 03:11 PM
#21
So many topics about this issue, I wonder if there has been any analysis on the wheels? The stock Toyota wheels and SCS are manufactured by the same company. I have SCS wheels, I have had balancing issues with KO2's. However, it's not 100%, I have had 2 balances work just fine and 3 that were off. Was it the person, tire or wheel, seems like a mystery still.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
07-09-2020, 04:07 PM
#22
Real Name: Tyler
Real Name: Tyler
Originally Posted by AZ Craig
That's actually really crazy since the Duelers fit since the tires are so damn small for a 265/70R17. You put any decent size AT or MT on there in 265/70R17 and you're going to rub.
Interesting... Surprised they are not trimming.
Agreed. After all the reading I did before buying, I was positive that I wouldn't have any rubbing with 265s. At least it's a fairly easy fix, I don't think I'll have to trim the fender but definitely move the liner forward. It only catches in reverse, but not at all going forward.
It could be a combination of those things, actually. Bigger tires are always going to be harder to balance, especially the more sidewall there is. I worked at Discount back in the day(03/04), and always hated balancing the 38" tires on like 15" wheels. It can take a lot of time, and some guys wouldn't have the patience to get it perfectly balance, so if it's "close enough" they'd send it out. Most of the time, though, it was either the wheel or tire being the issue that kept it from ever balancing on the machine.
22 TuRDPro
07-16-2020, 05:16 PM
#23
Just a final update, ended up getting them balanced on third try.
Shortly after my driver side front caliper froze up causing tremendous shaking off the steering wheel.
Thankfully was within a few miles of a local shop to get the caliper replaced without causing too much damage.
My gut is telling me the Grabber's were balanced the whole time and it was just the caliper on its way out.
07-16-2020, 08:12 PM
#24
You can "balance" almost anything. We have a saying in the driveline industry. It goes, "You can 'balance' a banana, but it still doesn't mean it's going to run right'"
Translate that over to wheels and tires. Road force is the only true way to see what's up for potentially square/out of round tires.
07-17-2020, 10:28 AM
#25
Real Name: Tyler
Real Name: Tyler
Discount uses road force balancers, so the wheels/tires wouldn't ever balance if there was an issue with the wheel or tire. I'd say most of the time, it was the wheel being jacked up that was the problem. New wheel, same tire would balance perfect on the first attempt a lot of times.
The huge, aggressive mud tires on tiny wheels were also an issue to balance. I think it's probably just due to pure physics. The diameter of the wheel is so much smaller than the tire, that putting weights on the wheel seemed to do nothing to all that rubber spinning around it. The weights, ideally, need to be as close to the outside edge as possible. Big wheels with low profile tires are cake to balance, but once you start adding a lot of sidewall, you run into the issues.
22 TuRDPro
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
General Grabber AT2
Diver Deuce |
5th gen T4Rs |
5 |
08-07-2015 11:06 PM |
General Grabber AT2 on a T4R
clem18 |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
45 |
04-03-2013 10:56 AM |
General Grabber AT2
smallfry |
4 |
09-24-2012 06:12 PM |
General Grabber AT2
Maritimer |
6 |
09-24-2010 09:50 AM |
BFG A/T KO Vs. General Grabber AT2
benk777 |
6 |
08-22-2007 06:34 PM |
