Old 07-08-2020, 05:44 PM #1
702_SR5 702_SR5 is offline
702_SR5 is on a distinguished road
Angry Yet another 4Runner wheel balance problem...
My basic question: How do I determine if a stock rim is defective (out-of-round, whatever)?
Full story:
I have a 2018 SR5 4WD that I bought new in November '18.
I'm a fan of the BFG TA's after running them on my two Xterras. (I also had BFG MT's on my Wrangler Rubicon, never had trouble with those.) So I had a set of KO2's (LT) installed the day after I bought my SR5.
They were purchased and installed at one of several local Discount Tire locations. They are the OEM size, 265/70 R17, and installed on the stock rims.
Everything seemed okay at first, though I did at times feel a little vibration. I wasn't sure of the source though I felt it mostly right in the driver's seat...
A few months later I had the first rotation/balance. Immediately, I had a noticeable steering wheel shimmy at highway speeds.
Thus followed several attempts by different DT shops to sort this out. Including rebalancing, roadforcing, and force matching. The shimmy persisted.
At one point while all this was going on, I numbered the rims so I could keep an eye on things...
Eventually I ended up back at the DT where I bought the tires. They spent a few hours on the job, with me in the shop watching. Eventually they determined that one of the tires was out-of-round (OOR). But also stated they suspected the rim it was on is also OOR.
They replaced the tire under the certificate, but I didn't do anything right away about the wheel. It was the rim I had written #4 on. It ended up on the right rear.
Everything was okay for awhile. I had another rotation, and this brought rim #4 up to the left front. No problems, no return visits. The next rotation sent rim #4 to the left rear. No problems I can recall, no return visits.
Then it was rotation time again. #4 ended up on the left front. I left the DT shop and got on a road with a 55 mph speed limit. The steering wheel shimmy was so bad, it was frightening.
I immediately went back and this led to another saga of balancing, roadforcing, and force matching at two DT shops. The shimmy lessened, but persisted.
I took it to a Toyota dealer and explained what had been going on. All they did was rebalance and roadforce all four wheels. Then, without telling me, moved the wheels around, placing the #4 troublemaker in the back. I had them put the wheels back where they had been. The steering wheel shimmy may have improved slightly, but was still there.
I've returned to the local DT. They dismounted the tire from the #4 rim, and spun the naked rim. I looked at it from the side while it was spinning. And it sure looked to me as if the rim edge was going up and down slightly, suggesting to me the wheel is OOR. But they told me that's not a valid way to evaluate it, that the machine would tell them if it was OOR.
They put it back together, and balanced/roadforced it while I watched. The balance was fine. The roadforce reading was 17, and the machine suggested it could get down to 16 if they force matched the tire/rim. I told them to just leave it.
Thoughts? I strongly suspect there's a problem with the rim. But how can that be verified? Other than by replacing it with a new rim?
If I were going to replace the rim, I would probably do it when I buy new tires. These now have nearly 32K on them, and I typically replace my off-road tires early.
Also...perhaps it is time to move on from BFG to something else?
If you took the time to read all this, thank you!
702_SR5 is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 05:58 PM #2
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Quick answer: go to Amazon, buy a dial indicator with a magnetic base, and Youtube how to use it. Dead simple. That will tell you whether you have a rim problem.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 06:39 PM #3
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
This, or borrow a rim from one of your buds and see how it works for you.
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
RedSled is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 06:47 PM #4
rightyouareken's Avatar
rightyouareken rightyouareken is offline
rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about rightyouareken has a spectacular aura about
Or even throw on the spare if you're still running stock size tires.
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
rightyouareken is offline   Reply With QuoteReply With Quote
Old 07-08-2020, 08:07 PM #5
08TxRunner's Avatar
08TxRunner's Avatar
I actually bought my indicator/base setup for this exact reason. A vibration that would not go away and I discovered that one of my aftermarket wheels was badly out of true.
Old 07-09-2020, 10:03 PM #6
Fermn's Avatar
Fermn Fermn is offline
Fermn will become famous soon enough
Fermn's Avatar
I say its probably the tires. I'm having a similar issue. My 4runner was driving perfect before lift and tires. After the tires were installed, I have a shimmy that I can't get rid of. Checked, balanced, rebalanced, road force balanced, everything checks out good. The problem is one of my rear tires because whenever I rotate them, the shimmy moves. Yet, they're all perfectly fine according to the machine. I'm switching out of KO2's after this set.
In the mean time, I'm just going to live with it and probably not rotate the tires. Not sure what I'm gonna do yet.. lol
Fermn is offline   Reply With QuoteReply With Quote
Old 07-10-2020, 01:04 AM #7
Deep_palancar's Avatar
Deep_palancar Deep_palancar is offline
Deep_palancar will become famous soon enough
Since you observed the work, did they use a lug adapter plate to mount the wheel?
I have one problem wheel that has been trouble since my '10 was new. If that one wheel is balanced with only a cone mount it will be perfect on the machine but will shake on the truck. See Toyota TSB SU002-96 (revised '12). I have to request that the adapter be used since most Techs are not aware of the TSB.
In my experience most Discount Tire places have an adapter plate of some brand. Even my local Wal-Mart has a lug adapter and one specific tech that knows how to use it.
In all of this marking and swapping I'm surprised that wheel #4 has not been swapped to Tire #something else. At least that should point to the problem following a tire or a wheel.
Once upon a time I had a set of tires that did not like being cross rotated. The woven belts would become directionally deformed. Michelin replaced them and said do not cross rotate if you ever run deflated.
File Type: pdf Toyota TSB SU002–96 (REVISED) Wheel Balance Haweka.pdf (144.9 KB, 1 views)
Deep_palancar is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 12:35 AM #8
I see videos that describe using one to check rotors, hubs, and other things. But not a rim. I've never used such a tool and have no idea how I would check a rim with one!
Do you have a link to a page or video that demonstrates this?
Old 07-12-2020, 12:38 AM #9
I've seen the threads here talking about adapter plates, etc. But I'm not an authority on these things. It seemed like they used multiple pieces when clamping the rim to their machine. I don't know if that tells you anything.
As mentioned in the long version of the OP, the tire on that rim was replaced once, because supposedly the tire was OOR. And things were okay for awhile, but now I'm again having trouble. Suggesting to me the rim is defective and is screwing up the tire.
Old 07-12-2020, 12:43 AM #10
Unfortunately I don't know anyone who has a 4Runner with the same stock rims.
And my spare is a Bridgestone tire on a steel rim. Are you saying to take the tire off the suspect rim, mount it on the steel rim, mount the assembly on the front, and then test drive the vehicle that way?
Old 07-12-2020, 12:48 AM #11
No I mean take the wheel and tire you think are the issue off and put the space wheel and tire on to confirm it’s really that pair and not something else.
1998 BMW M3/4/5
Old 07-12-2020, 01:48 AM #12
pableaux's Avatar
pableaux pableaux is offline
pableaux will become famous soon enough
pableaux's Avatar
I rotated my Wildpeaks for the first time at 5k miles and instantly noticed a shimmy at highway speeds that I didn't have before. I have aftermarket wheels so they're lug centric. I took them off and put them back on again as centered as possible. Looks like my issue has been solved. I haven't been able to drive it much yet but the one test run I did seemed a lot better.
pableaux is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 02:53 AM #13
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
They key number is under 15 lbs of road force to be vibration free. Even if your wheel/tire assembly balances out perfectly after road force balancing, it will still cause vibrations if road force is over 15 lbs because of how sensitive 4Runners are. I figured this out after going through numerous balancing and sets of tires.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 09:29 AM #14
CutthroatSlam CutthroatSlam is offline
CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold CutthroatSlam is a splendid one to behold
I recently took the 2014 4Runner in for road force balancing. When the shop owner asked for the Make and Model, he grimaced and shook his head when I said Toyota.
CutthroatSlam is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 11:01 AM #15
seatia seatia is offline
seatia will become famous soon enough seatia will become famous soon enough
Here are a couple of things to read.
Trade magazine
A Mounting and Balancing Act - Retail - Modern Tire Dealer
Dial indicator with pics
Measuring Wheel Runout
If you want to check the rim , the tire should be off and the rim mounted to the truck, slowly turn the rim and test for both runouts.
The hub/bearings could also be suspect.
I'm old school so I won't cross rotate any tires.
They only get moved from front to back or back to front same side.
In other words, they always rotate in the same direction.
These days the tire manufacturers say it doesn't matter, but on my vehicle it does, I don't cross rotate.
I also don't rotate tires unless I see some abnormal wear, usually the front tires show first.
It seems to me you are wasting a lot of time, energy and money by rotating your tires so much, but it's your call.
You may be spending more money with all this balancing stuff than you would by never rotating and just replacing the tires when needed, even if it may be a few thousand miles early.
seatia is offline   Reply With QuoteReply With Quote
back , balance , oor , rim , shimmy , vibration , wheel
stock stereo speaker fader/balance problem ChewysT4R 4th Gen T4Rs 2 07-20-2017 02:02 PM
ET lugnuts solved wheel balance/vibration problem 65-72 mph Arv 3rd gen T4Rs 18 08-02-2012 07:15 AM
balance problem Gstick Engines / Suspension / Wheels / Tires / Audio / Accessories 10 09-16-2011 05:45 PM
Wheel Balance Question Bftfan 4th Gen T4Rs 12 03-21-2011 09:03 PM
2005 Toyota 4Runner, Wheel Balance/Alignment Issue kgatch Problems & Warranty Issues 17 08-31-2005 10:37 PM
